Nitrous Oxide Roll call
Old Apr 29, 2005
ajhdragon's Avatar
7thgens official a$$hole
they have a boosted roll call lets do a nitrous roll call. im one i'll start a list.
NOS 50 shot dry kit, dual purge
ajhdragon
killacamshaft
1siksivik
djmota
NashVegasEx
BRcivic
Jeromie
flowerpowerlove
drunkenmagnum
scansel912
thiscrackerntam
DJ NILOCIVIC03
tfnaff
big daddy b 99
allmotor
el ben2
myGFgottaCIV
Civic Redline
Jeromie
mndthegapls
Knocturnaltkr
BoostedCivicZex
042dr
joshb
CivicSouldjaEX
Old Apr 29, 2005
sspem2's Avatar
em2
NX kit 75 shot with purge and NX direct port system. i have (2) 10 lb bottles, and i have 3 purges. one out my fender wells, second thru the washer nozzles, third under the headlights, so i got one going out like a "v," shape out the fenders, 2nd one straight up thru the nozzles, then straight at you under the headlights. once i do my rebuild on the bottom end and turbo it i will run 100-110 shot.
02 civic coupe EX 5spd
Old Apr 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
currently 75? shot NX kit, but boosting sooooooooon!!!!
Old Apr 29, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
NX 50 Shot, going to 75 once I refill my bottle
Old May 1, 2005
big_daddy_b_99's Avatar
big_daddy_b_99 is an unknown quantity at this point
NX 75 wet with purge, warmer, opener on its way, and the nx 3 switch panel with a pnp head and cam regrind on a a 02 4door automatic. yes automatic but hey it hauls *** for an auto.
Old May 2, 2005
scansel912's Avatar
What plugs are you guys running? I'm personally using the NGK Brk7e plugs.
Old May 2, 2005
i use the NGK V powers that are two step colder ^ i think it's the ones you are usin.
Old May 2, 2005
djmota's Avatar
denso ik20 on a 65 shot. I wont spray 75 until I change my plugs to colder ones.
Old May 2, 2005
allmotor's Avatar
nor cal 7thgens
havent installed it yet but my setup is NOS 75 wet kit
Old May 2, 2005
el_ben2's Avatar
CivicMexicano Is My Daddy
el_ben2 is an unknown quantity at this point
zex with 50 shot....
i got a question
is necessary to retard the time for a 75 shot? i mean... what happen if i dont do that?
Old May 3, 2005
Killacamshaft's Avatar
G'z UP
Killacamshaft has a little shameless behaviour in the past
NX dry(yes i said dry)50 shot with purge and in dash nitrous pressure gauge runnin dry for about a couple months no probs
Old May 3, 2005
djmota's Avatar
i got a question
for a 75 shot you should be running 100+ octane gas and have plugs 2 steps colder than stock. since we can't adjust our timing these things are all we can do.
Old May 3, 2005
G'z UP
what do i need to run a 75 shot
Old May 3, 2005
scansel912's Avatar
People have been running a 75 shot as well with 93-94 Octane gas. Just be sure to check your plugs regularly for detonation.
Old May 3, 2005
myGFgottaCIV's Avatar
myGFgottaCIV is an unknown quantity at this point
i've got a NOS wet kit. 50 shot. that's all
Old May 3, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
ive got edelbrock universal wet kit with 80 shot... been spraying for about 8-10 bottle fill-ups. been fun while it lasted, now getting rid of the nitrous kit and installin turbo real soon...
none of that purge crap to show off, just a bottle blanket and a nitrous gauge.
PS might keep the nitrous kit with my turbo, but if I do, iwill lower to 40 shot instead of 80
Old May 3, 2005
G'z UP
so the stock fuel pump fuel pump can handle this with no fuel upgrade
Old May 3, 2005
NoFriends's Avatar
I like ruining your threads.
That "purge crap" is to remove any nitrous vapor/air in the lines so you get a solid and consistant stream of nitrous running through them.
Old May 3, 2005
im stock now! T.T
yes it definately can. just dont go triple digit hp and you should be fine.
Old May 3, 2005
im stock now! T.T
Originally Posted by NoFriends
That "purge crap" is to remove any nitrous vapor/air in the lines so you get a solid and consistant stream of nitrous running through your lines.
your right, although I what I meant was, people use it to show off.
Old May 8, 2005
suthrninca's Avatar
suthrninca is an unknown quantity at this point
Just installed my NX wet kit 50 shot with a NOS purge. It was a little harder install than I expected, but not to bad. If I had to do it again, I would go with a Zex wet.
Old May 8, 2005
in that case.. BOV's are the same thing.
Old May 8, 2005
NoFriends's Avatar
Shoot, id get a aftermarket BOV on my rex if it didnt fck up the computer. Next to power, the BOV is the 2nd best thing about a turbo.
Old May 8, 2005
if you've got it.. flaunt it.
Old May 11, 2005
Tomola's Avatar
Tomola is an unknown quantity at this point
Where online can I purchase some good one degree colder plugs?
Old May 11, 2005
dunno if this is the best place.. but this is a place online.. www.sparkplugs.com
you're local napa should carry a few options.. try staying away from precious metals as well. some ngk copper plugs would be fine
Old May 19, 2005
JxL_o2Lx's Avatar
JxL_o2Lx is an unknown quantity at this point
Using 50 shot (Cold Fusion) nitrous w/ CAI and Catback... Love the boost hate the $3.50 per lb :0
Old May 22, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
Direct port? do you have a y8 mani? or are you using the stock plastic one?
Old May 23, 2005
im stock now! T.T
um, I think all turbos have bovs, factory turbo and non-factory. Factory comes with internal one that doesnt spray into the atmosphere or so I was told, with a nitrous kit, buying a purge kit is *optional*
Old May 23, 2005
im stock now! T.T
direct port is the way to go, but how much are u planning to use? doesnt mean u can spray 100+ shot just because its direct.
