i need your opinion!!!
Old Apr 19, 2005
HondaLuver's Avatar
Its a celebration bitches!
well since ive done what i have done... now i don't know what i want for the future... should i get a custom turbo kit and later build the engine, or just build the engine for all motor... 12.5 to 1 compression, ips cams... all that good stuff...
Old Apr 19, 2005
C2i0v0i1C's Avatar
SuperMODrizd
build and turbo
Old Apr 19, 2005
tfnaaf's Avatar
BLDNPSI Mod
both motor and turbo
Old Apr 19, 2005
civicvtec1ps's Avatar
Search and Learn
Just put JRSC race kit and call it a day.
Old Apr 19, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
"custom turbo kit and later build the engine"
Old Apr 20, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
Well, you've already put this much money into it. You might as well go all the way and turbo/ build........TURBO IS BETTER
Old Apr 20, 2005
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
build the block and head, and go turbo...see if you can be the baddest
Old Apr 20, 2005
civic01vtec's Avatar
wtf u do for a living ?
Old Apr 20, 2005
allmotor's Avatar
nor cal 7thgens
go n/a.
Old Apr 20, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
you should really, really, really know what you're doing if you aren't going to build the engine first.
I say build first, turbo later... or, turbo first, tune next, build later.
Old Apr 20, 2005
N/A, then you'll be ready for turbo later.
Old Apr 20, 2005
04civicdx's Avatar
04civicdx is an unknown quantity at this point
Old Apr 20, 2005
HondaLuver's Avatar
if i build for na, its going to be high comression if i build for turbo its going to be 9 to 1 of course alsorts of secreat goodies.... i work at a law office
Old Apr 20, 2005
be different and build na
Old Apr 20, 2005
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
I agree with gearbox. As much as I like the sound of a turbo spooling and blow off valves, N/A is usually more reliable and IMHO more respectable.
Old Apr 22, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
N/a!!!!
Old Apr 22, 2005
illestborn's Avatar
illestborn will become famous soon enough
build ur motor......
Old Apr 22, 2005
djmota's Avatar
all motor. you have the dispacment for it. add some hi comp pistons, hd rods and those cams. you will be set to run. if thats not enough then a little spray goes a long way. I have gotta be there for the time this thing heads down the track.
Old Apr 23, 2005
HondaLuver's Avatar
The guy that dyno'ed n tunned my car said I will be able to hit 13.7 with my set up... If I get slicks I willlprobably get low 13.... I have so much wheel spin right now.... Its not funny
Old Apr 23, 2005
Alex1's Avatar
boost for sure!!!
Old Apr 23, 2005
HondaLuver's Avatar
There is a guy that is building a tsx engine in his rsx.... He is building it n/a I want to see his results are.... But with this much traction problem... What would happen if I turbo and have 400+ hp? It be pointlesss... I would have no traction what so ever....
Old Apr 23, 2005
doubledeuce2k2's Avatar
exactly. 1st gear is useless when you pass 250whp F/I. all motor might not have torque, but 20mph on up you will be owning a lot of vehicles once you build for some revs.
Old Apr 24, 2005
turboengnr's Avatar
DONT PANIC
heres a question for you...
do you want to go 10's or 12's?
Thats probably about the difference you will have when comparing NA to turbo. You would have to make a lot of power to go any faster than mid-low 12's. Do you think you can do it NA? The car will need the best porting money can buy (not KMS or any large company like that).
With NA, you will need pistons and rods, a ton of port work, and hours upon hours of tuning to go low 12's. With a turbo, you will need the turbo kit and some tuning to do the same. But then if you add pistons and rods and some portwork, you just got a hell of a lot faster.
My fastest NA civic friend went 11.40 (95 hatch, GSR)
My Fastest turbo civic friend went 10.20 (96 civic hatch, GSR)
Those are both "street cars". The NA one has a hard time on the street (detonation issues). But the turbo one drives 45 miles 1 way to work every day.
My fastest honda friend went 9.60 (96 hatch, GSR turbo)
Old Apr 24, 2005
HondaLuver's Avatar
doubledeuce2k2 : do u understand the amount of tq i am getting? its a 2.4 liter engine...
i would like 11 or 12's, you see those motors are 1.8 liters... i have a 2.4 i will make alot more tq and hp than they will ever be able to make, and easier. i don't have to rev to 11k to get my full hp... if i can make this much hp with bolt on's only, imagine if i build the engine.
those engines with bolt ons don't even make the amount of tq that i have. im making about 60 more tq than a k20 is making with the same bolton and tunned
218.3 hp and 185.5 tq
a k20a2 will be making about 215hp and 116 tq
Old Apr 24, 2005
iamboo's Avatar
Retired - SoCal FI Mod
you've already got the low end torque...
why not go turbo and make it even faster at the high end of the spectrum??
i say a mild bit of boost will do wonders on the car....
N/A is cool but it will cost a lot more to get that car where it would be with a little boost....
Your cars gonna sound like fart canon N/A... lol... j/p...
i say boost just cause of the easy HP and less downtime + cost
Old Apr 24, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
boost the **** out of it. thats the reason you got that engine. why not just go all out?
Old Apr 25, 2005
Vantage's Avatar
Vantage should not be trusted
Simply put. N/A = Expensive for decent gains.
Turbo = cheap huge power.
I regret going n/a on my old b18, i spent over 6000 canadian on the engine, and only hit 13.8's. Now if i went turbo i coulda went 12's for half that price. its a mistake ill never make again.
And no, u cant build an engine for n/a then switch to turbo, the internals for both engine are TOTALLY different. From cams to compression. N/A stuff with a turbo = bomb, thats y people that stick turbo's of Integra type R's with stock pistions are just dumb. its a bomb waiting to go boom.
Old May 18, 2005
HondaLuver's Avatar
lets just see what happens after i get itb's, lsd, and ips k2 cams
Old May 18, 2005
A quote from honda-tech
"When going N/A (allmotor) it's important to realize that you're choosing the hard way. There are no two ways about it, N/A is one of the most difficult routes to get extreme power out of a car, and respect for it by other importers. This is part of the draw to it. Everyone expects a turbo car to be fast, everyone expects that if you are on the bottle that you should turn good times, but when you bust out a mid 13 second run on full interior, or lay down a low 12 on a stripped out car, there's something about being able to say "hell yeah, that's pure motor baby... pure motor."
hondaluver props to you for going n/a, I can't wait to see what your motor puts out.
Old May 18, 2005
sspem2's Avatar
em2
in order
1. fully built head
2. fully built bottom end
3. then TURBO so u can run high boost and make high numbers.
thats what im doing with the d17. im on part 2 now. i wanna run 15-20 psi daily. its gonna take me alot of money and parts but i wont give up on the d17. imma try to get 300whp is my goal then i already of n20 so then 100 shot so 400whp. gonna take me a few yrs and alot of custom parts but im gonna try.
and dont tell me im wastin my time and money and its not worth it. thats the part of modding to try and research and i wanna be the one who successfully built a d17 with lots of power. we will see. in 2 yrs ill be a nurse so ill be makin 40/hr + so money wont be an issue just custom axels, tranny, etc.
