K20A2 change to 5 lug?
Old Apr 10, 2005
civicrider01's Avatar
civicrider01 is an unknown quantity at this point
Hey guys. If you swap a k20a2 engine and tranny, Do you have to change from 4 lug to 5 lug, or can you keep the same 4 lug pattern?
Old Apr 10, 2005
QBoi's Avatar
I believe all you need is stronger axles. People just opt for an rsx or si axles which are 5 lug
Old Apr 10, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
02-03 Si axles are 4lug. so yes you can keep the 4lug.
Old Apr 10, 2005
ragingSPAM's Avatar
I just burnt my tongue
acutally the lug pattern is on the brakes...the axles have nothing to do with the bolt pattern other than the fact they are connected when u have everything setup...a 5 lug conversion is only an ascthetic thing or if u want rsx brakes and strut towers...from my experience si axles are recommended for the passenger side and rsx axle for the driver side
Old Apr 10, 2005
HondaLuver's Avatar
Its a celebration bitches!
Yup if u wanna keep 4 lug. U need 02-03 axles or base rsx axles
Old Apr 10, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
Or...you could do what I did and buy Driveshaft Shop Stage II axles and be in like flint.
Old Apr 10, 2005
how much did they cost you? cheaper than si ones?
Old Apr 10, 2005
Um, no. I paid $680 for them and that was discounted. But, I aint lookin to cut no corners (go cheap) on my car.
Old Apr 10, 2005
HondaLuver's Avatar
Old Apr 12, 2005
DJ_NILOCIVIC03's Avatar
DJ_NILOCIVIC03 is an unknown quantity at this point
Axles have nothing to do with your brakes....the only time when we talk about getting SI instead of RSX is when doing the rear brake conversion.....
doncarbone
Jun 8, 2015 03:37 PM
cmart1209
May 29, 2015 04:52 AM
Ninetyatecivic
May 9, 2015 07:48 PM
Jc20unc
Jan 1, 2002 06:46 PM
Jc20unc
Jan 1, 2002 12:53 PM
