Question for all turboed people?
Old Apr 6, 2005
streetglower's Avatar
I am just curious, how many of you with turbos let your car idle for about 5-10 min. before you turn it off? or do you just turn the car off after driving?
Old Apr 6, 2005
civic01vtec's Avatar
well, i don't have a turbo timer.......but i let it idle for like 1-2 min.........depending on how hot it is or how hard i drove it. Sometimes longer.
Old Apr 6, 2005
skipbarber's Avatar
if you drive normally, i dont think you need to let it idle. and if you do, 1-2 minutes is sufficient. On the other hand, if you drive hard, youd want to let it idle for a good 10 minutes.
Old Apr 6, 2005
civic21's Avatar
civic21 is an unknown quantity at this point
for sure let it idle or your gonna be blowing it up!!
Old Apr 6, 2005
mallison's Avatar
mallison is an unknown quantity at this point
in most cases let it idle also pends on if its oil cooled and water cooled i'd bank on the safe side and always idle it for about a minute
Old Apr 6, 2005
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
the reason why it is reccomended that you let a turboed car cool down after running, is not to let the engine cool. it is to let the turbo cool. The best thing to do is to purchase a turbo timer. It allows your car to continue to run when you walk away from it, which in turn is circulating fresh oil through the turbo to help cool it down. Not letting your car idle after driving just lets Hot oil sit in your turbo which can ruin the seals...
Old Apr 6, 2005
deciuss's Avatar
Boosted Auto
i wate till the ET gauge is down to 600-700 for temp
Old Apr 6, 2005
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
If you let it idle for 10 minutes, you're going to be heating the turbo up MORE than if you just shut it off. You're also going to be ruining things and wasting gas.
The point of leaving the car on is to push enough oil through the turbo to cool it down some. Some. Not all. 30 seconds is enough, after a track run, 45 seconds and then turn the motor off and the fans on. I have an oil temp gauge and have watched it on cooldown, and if you leave your motor on for more than 1 min, you will be heating the turbo up more because you are no longer getting air flow over your motor and the hood turns the engine bay into an oven.
From tests using a laser pyrometer (temperature gauge thingy for those who don't know) on the turbo housing, and the oil temp gauge with the sender at the oil return line, this is what I found to be the best year round:
For daily driving, 30 seconds is more than plentiful.
For a drag race pass, driving back through the timing shack to your parking space and then another 30 seconds, shut it off, pop your hood and turn on your fans. A manual switch is great for this.
For road racing or endurance, drive back to the paddock, let run for 1 min, then turn off, pop hood, place fans in front of car, turn on car fans, and wait 5 min.
Old Apr 6, 2005
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
1-3 min is fine depending on how hard u drove 10 min is too long and id let it run more than 45 sec.
Old Apr 6, 2005
Shlomo's Avatar
Shlomo is an unknown quantity at this point
i've got a question, what about when you go fill up on gas AND have a turbo timer? your car will be running while your putting in gas, that doesn't sound too safe? is that the way it works?
Old Apr 6, 2005
you'll juts have to wait for it to shut off
Old Apr 7, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Most turbo timers have an override button that shuts the car off immediately.
10 minutes is excessive, run synthetic and water cool the turbo and don't worry about it at all. If you insist on turbo timing it, run it for 1-2 minutes.
Old Apr 7, 2005
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
Im installing my turbokit this week bro!
Old Apr 7, 2005
Titleist71's Avatar
I just shut it off....water and oil circulates a few minutes on its own without the car running
Old Apr 7, 2005
exturbo6's Avatar
[QUOTE=civic01vtec]well, i don't have a turbo timer.......but i let it idle for about 5 mins or so. depending.
Old Apr 7, 2005
exturbo6's Avatar
me 2
Old Apr 7, 2005
2K1Civic17"Gabe's Avatar
I set my turbo timer for about 40 seconds. I rewired some stuff, and need to fix it though, hehe. I figured it would do what it did when I rewired that sh**. But oh well.
40 seconds should be good. It should cool down by then. Getting gas sucks. Since you have to wait, but if you want to override it, a lot of turbo timers come with a ebrake override thing. Where you put the ebrake down and it shuts the car off. I think its to prevent theft, but they wouldnt get very far when it would cut off in 40 sec anyways. haha. Getting gas hella sucks for me, I have to reset all my settings for the ICU EVERY time I turn the car on. sucks a pain in my *** to wait 5-7 minutes everytime.
Old Apr 7, 2005
civic2k2's Avatar
civic2k2 is an unknown quantity at this point
I use a turbo timer on mine. If I have to get gas I just shut off my car before I pull up the e-brake so my turbo timer doesnt come on as long as I havent been driving it hard.
Old Apr 7, 2005
Shlomo's Avatar
ok, turbo timers usually have some sort of override/theft deterent thing that shuts off the engine, and if not you just have to wait. makes sense
Old Apr 7, 2005
TheSmuggler's Avatar
Let it idle for around 1 min. The last thing you wanna do is cook the oil...
Old Apr 7, 2005
Daemones6's Avatar
Daemones6 is an unknown quantity at this point
I just got my kit. Should be on in a couple of days. Does the Apexi turbo timer have a kill switch?
Old Apr 7, 2005
Titleist71's Avatar
the GReddy is nice...hehehe...buy mine!
Old Apr 8, 2005
I love my Greddy FATT lol
Old Apr 8, 2005
dezod's Avatar
7thgen Power Maker
Buy a FATT. I have a couple Blitz ones in stock.
Old Apr 8, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
I like my Greddy full auto timer. just put it on and it takes care of everthing. very smart little box.....lol
Old Apr 8, 2005
The only thing I like about TSIs is their turbo timer. Are you saying you have to turn it on every time you want it to stay work? Doesnt make sense.
So is your kit working out nicely for ya bradmanuwf
Old Apr 9, 2005
BudDyLeEBoOsteD's Avatar
BudDyLeEBoOsteD has a little shameless behaviour in the past
You need one? Pm mE?
Old Apr 12, 2005
bradmanuwf's Avatar
yeah, its working well. no problems. have one small little exhaust leak when the engine is cold. but its no biggie.
Old Apr 12, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
even friends with supras that have turbo timers dont let their car idle for more than 2 mins, and you know how hard they can drive their cars...normally id say a min or less is sufficient
Old Apr 12, 2005
glad to hear it. Im loving being boosted. I didnt even get on it too hard in the last month ive had it on. 2 nights ago, my friend was in my passenger seat picking on every car he saw. v8s, v6s, everything. it was crazy. I beat a v6 accord, the dude looked so pissed off afterwards. He wouldnt look at me. I raced a v8 impala, but he stopped when my tires started spinning like hell while pulling me through first. it was funny. Now I step on it a lot harder when I need too. Ive whooped on a couple hatches, I was catching up to a G35, and we hit a red light like 20 feet ahead, so we both slammed the brakes on, lol. Ive been having some major fun. I mostly wanted this for some more get up and go for my daily driving. Its works perfect. No more trying to pass in 4th on the freeway and going nowhere. 4th on the freeway at 2psi will pass so easily.
