tsi kit/fully built d17 q?
Old Mar 25, 2005
bigsamdog's Avatar
k!llin al-queda since 2002
bigsamdog is an unknown quantity at this point
hey guys whats up ive decided to go with the tsi kit for my d17.i would like to run low-mid 12's on the track in the far future. i got 2 questions. 1. can a d17 withstand that much hp/trq to run those times even with rebuilding it(better piston,rods,sleeves,etc.) 2.im prolly going with the t25bb,would this turbo be sufficient or would i have to upgrade to the t28bb or even higher. thanx for the info
Old Mar 25, 2005
exturbo6's Avatar
SEARCH....there are so many threads on tsi, and bnuilding the motor.
Old Mar 25, 2005
bigsamdog's Avatar
dude im on page 18 out of 1xx lookin for it. i know eternalblue is runnin low 14's no 1 is any faster than him w/ that kit from what ive read so far
Old Mar 25, 2005
bigsamdog's Avatar
right now im on vafc vs. emanage
Old Mar 25, 2005
exturbo6's Avatar
well i have the tsi kit, and i got a t28bb. its a good kit thou.
Old Mar 25, 2005
dezod's Avatar
7thgen Power Maker
If your going to build it, why limit your platform with a T25?
Old Mar 25, 2005
tfnaaf's Avatar
BLDNPSI Mod
if your shooting for those kind of numbers id guess min of a GT28RS disco or bigger! Most likely would neeed to be custom kit all together. As i recall the GT28RS is capable of low 300's HP
Old Mar 25, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
I think only Catalyst break the 12's sec. mark on a d17.
list of : http://www.7thgencivic.com/forums/member.php?u=10817
Old Mar 25, 2005
bigsamdog's Avatar
does it really need to be custom.can the gt28rs just replace the turbo that comes with the tsi kit. remember that this is for the far future not right now
Old Mar 25, 2005
bigsamdog's Avatar
the reason i brought this up is bcause there is a d16 runnin 11'back in cali
Old Mar 25, 2005
2K1Civic17"Gabe's Avatar
I think we can get into 11's, but our tranny wont hold it, so until we can fix that prob, you'll be going through a lot of tranny's.
Old Mar 25, 2005
tfnaaf's Avatar
BLDNPSI Mod
Prolly the biggest bottle neck would be the tsi cast manifold. A custom equla length would be a big step. I suppose if you could order the tsi minus the t25 and buy a GT28RS its possible. But as said above the tranny/clutch wont take those kind of HP/torque numbers for long
Old Mar 25, 2005
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
You can leave out anything you like in the TSI kit when ordering.
To the original poster: The AFC will advance timing which limits the amount of boost you can run. With the emanage you can retard ignition timing so that you can run MORE boost.
Old Mar 26, 2005
MadWheel's Avatar
Premium Boosted Member
Yeah the TSI kit is not something you want to get into for 11 second passes. The kit uses a small turbo, a small manifold, and a limiting fuel system.
Go with at least the GT28RS or a T3 Super 60, T3/T04 E/B. Then use an equal lenght manifold, or at least one with a high effiency and air flow. Replace the stock injectors with at least 450cc+. Convert to a return line (best to tune). Use an Emanage so you can pull back ignition timing and tune the fuel curves.
Replace the axles. Add an LSD, a very strong clutch, and pray your tranny and synchros hold up.
I don't see how the D17 could run 11s without being built, regardless of the amount of money spent on anything else.
Hopefully I read the q's right, im tired and lazy right now haha...
Old Mar 26, 2005
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
you really havent searched then because I can bet you any amount of money if you go to track/street/strip, you'll see members who have claimed to hit mid 13's on the tsi kit.
Old Mar 27, 2005
Chris3k2's Avatar
Chris3k2 is an unknown quantity at this point
streetlevel, how much would it be if I left out the TSI kit's BOV, ICU, and injector interface block with 2 injectors??
Old Mar 27, 2005
allmotor's Avatar
nor cal 7thgens
crew chief hit low 13's on the tsi kit
beanhead
Sep 24, 2015 12:04 PM
Donahue
Sep 8, 2015 09:00 AM
redcloud
Sep 7, 2015 01:45 PM
KAMIKAZEEx
Aug 30, 2015 08:30 AM
Ccoop87
Jul 9, 2015 03:26 PM
