Whered you get your pistons?
Old Mar 14, 2005
turboengnr's Avatar
DONT PANIC
I am tired of having soo much crap on my car that i cant use. I am finally building up my block so i can actually use them.
I have a GT3071R waiting to go on, along with a stainless equal length 1.5" ID primary manifold, 450cc injectors, and an NOS wet system to top it off.
My question to you guys is: Where did you get your pistons and rods, and how much did you pay for them?
And please dont lecture me on nitrous with boost. Ive done it before, and i already have the second fuel tank built with its own pump & return line.
I just need to get some prices. Is Crower still the only company that makes the rods?
I need part numbers as well please. Thank you in advance!
Old Mar 14, 2005
C2i0v0i1C's Avatar
SuperMODrizd
http://www.7thgencivic.com/forums/sh...t=piston+specs
Old Mar 14, 2005
turboengnr's Avatar
DONT PANIC
thank you very much!
say.... didnt you have a set of crower rods you didnt use?
Old Mar 14, 2005
C2i0v0i1C's Avatar
SuperMODrizd
say yes i did, but i will be using them sorry
Old Mar 14, 2005
turboengnr's Avatar
DONT PANIC
what were the specs on those?
Old Mar 14, 2005
C2i0v0i1C's Avatar
SuperMODrizd
Old Mar 14, 2005
turboengnr's Avatar
DONT PANIC
Old Mar 15, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Call Darius at CP.
Old Mar 15, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
how much were they and what is "CP"?
Old Mar 15, 2005
C2i0v0i1C's Avatar
SuperMODrizd
www.cppistons.com
Old Mar 15, 2005
civic01vtec's Avatar
did u get a new tranny mike ?
Old Mar 16, 2005
turboengnr's Avatar
DONT PANIC
yes i did. I attempted to do a 96 civic ex conversion, but got too lazy to build the post shifter assembly, so i ended up abandoning the project and put another 02 lx tranny in. Afterwards i found out that the input shaft bearing in the 96 ex tranny was bad anyway.
i did also manage to shell my turbo today while going back to work after lunch. That was not fun. Good thing i have a backup in my garage. Looks like friday night will be spend pulling the turbo off, swapping exhaust housings on the turbos, then putting it all back in.
I also have been on another project with one of my friends. He has an 03 si with a Kpro and 550 cc injectors. I just finished his intercooler piping, and i will be building the manifold soon. The intercooler is the same size as mine. We are going with a large T25, because we are going to evolve it into a twin turbo setup later on (when he has more $$$).
Old Mar 17, 2005
bradmanuwf's Avatar
Its not going to put out enough power for how much he spends on it. A single t3/t4 will cost less and put out more power. I saw a guy that did twins on a B18....cost him a **** load and had to tach up to 6000 for turbos to spool and he still had less power than a single t3/t4. Twins not worth it on a 4 banger unless you are only using it for a show car and not driving it around all the time.
Just as a show car would be pretty sick...too bad the turbos would be on the back of the motor and hard to see
Old Mar 18, 2005
turboengnr's Avatar
DONT PANIC
ok, you are dumb. You forget that i am building the turbo setup. Everything from the manifold and downpipe, to the intercooler piping, and the return line setup. So basically, it will cost him whatever i charge him. And since hes a good friend of mine, it will cost about $1000 for a twin turbod 03 civic Si, fully tuned.
Also, i did a twin turbo setup on a STOCK B16, it made 10 psi of boost at 1600 rpm and held it all the way to redline. Which is what, about 8200?
I have turbocharged more cars than most could ever dream. Please dont argue with me about this. Many many people on this board know who i am, know what i have built, and some even have some custom parts i have built for them.
Old Mar 19, 2005
TheSmuggler's Avatar
What can I say, Mike owns us all
Old Mar 19, 2005
turboengnr's Avatar
DONT PANIC
sorry, i didnt have any caffeine yesterday. I got a lil testy.
Skillzzz
Jun 16, 2015 08:45 PM
Waldo
Nov 28, 2001 07:55 PM
buddy
Nov 15, 2001 08:20 PM
MooCoW
Nov 15, 2001 10:58 AM
andylao
Nov 4, 2001 01:19 PM
