F*** up TURBO?????????
Old Mar 11, 2005
BudDyLeEBoOsteD's Avatar
BudDyLeEBoOsteD has a little shameless behaviour in the past
For some reason, when I am on Idle..
It still tends to trow out white smoke....
Only after you've driven in it for a while....
I have no Idea what this could be ....
I am thinkin it could be S-AFC wrong Air Connection or something, but i seriously doubt it!. because there' should be plenty of fuel going in there!...
I'am now starting to think, that it could be the TURBO.
When I leave it on idle, *when white smoke commin out*, right before any smoke comes out the car kinda chokes or something, It does a lil lil choking sound and then the smoke comes out!> Turbo I believe is my last resort on everything... *(are those, ****ed up turbo symptoms)* or could it be a clogged up PCV valve... Dont really knw!.
PS> dont mention Headgasket,or Blow bye,
1.My car aint overheating
2.I've already done compression test's on all cylinders, and there all 100% perfect...
What does this crap sound like???????????????????
Old Mar 11, 2005
Also, dont we have like 1 year or 2, Warranties on our Turbo's From TSI?
Old Mar 11, 2005
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
Mine used to do the same thing and it was the seals in the turbo. I could be your return line backing up with oil. If the return is mounted to low in the oil pan it will do that, it should be mounted up high. Maybe try a larger return line.
Old Mar 11, 2005
You mean Return on the OIL pan right?
not the Return Fuel line!?
It should'nt be nothing w/ the SAFC right?
Old Mar 11, 2005
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
if theres white smoke.. im guessin it has something to do with the oil
Old Mar 11, 2005
Daemones6's Avatar
Daemones6 is an unknown quantity at this point
That sucks man. Glad to know before I install mine so I can make sure the shop drills the hole up high.
Old Mar 11, 2005
civicly's Avatar
civicly is an unknown quantity at this point
Most of the time white smoke means coolant/water, Blue smoke it oil and black is fuel. have you tried to do the compression test when the motors hot?
Old Mar 11, 2005
TheSmuggler's Avatar
Blown HG...
Old Mar 11, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
ha, sounds like ur gettin compression test and cylinder leakage test mixed up there buddy
Old Mar 11, 2005
Boosting Daily
WRONG
burnt oil = blue smoke
burnt coolant = white smoke
Old Mar 11, 2005
Boosting Daily
Old Mar 11, 2005
Damn triple ownage
Old Mar 11, 2005
Boosting Daily
Originally Posted by TheSmuggler
Blown HG...
My only other guess would be a hairline crack somewhere in your head that expands when ur engine warms up and leaks coolant into the CC
Old Mar 11, 2005
^^+1
Old Mar 11, 2005
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
1st of all just because your ride isnt overheating right now doesnt mean you dont have a blown head gasket. 2nd, neither does good compression check. White smoke tends to mean coolant burning and I have never heard of anything else causing white smoke so I wouldnt rule it out as being a possibility just yet until you find out more.
Old Mar 12, 2005
civicly's Avatar
Very good point! hair line crack in your Head could be the problem. One of the ways to find out if this is your problem Is get access to a gas analyzer for smog. first remove radiator cap, warm the car up preferably when your car has white smoke coming from the tail pipe. careful not warm up too much you don't want to over heat the motor. once you start seeing steam from where you removed you radiator cap it should be good to go. what your going to do is check for Hydrocarbon (HC) at the radiator cap inlet with the sample probe from the gas analyzer. the reason you are checking HC in you coolant is when you have a hair line crack in you head you are not only sucking and burning coolant but also pumping combustion gasses though your head into your coolant. Their are few other ways to diagnose "white smoke" this way is just the easies for me.
Old Mar 12, 2005
SkyGuy86's Avatar
SkyGuy86 is an unknown quantity at this point
Yeah my friend drives an eclipse and he was driving real hard over to my house pulls up with white smoke comin outa his hood. He blew a head gasket, also a sophomore at my school his BMW had white smoke and pretty sure its a head gasket there too.
Civilcly where do you think he could get a gas analyzer for smog?
Old Mar 12, 2005
civicly's Avatar
if you know somebody with one or your smog shop will have one. I have access to one at school and at work thats why its easy for me
Old Mar 12, 2005
SO is this coolant problem shop fixable...
Or is this something that I'am going to to replace heads?
cuz if so..lol THERE AInt no way I am getting a new head, Itll be worthless, I might as well get a new car...
Old Mar 12, 2005
I doubt it would be a hair line crack, cuz if it was .. I think i would've blow my engine by now....... My car does not over heat at all... I dont have any SMOKE comming out the engine. It could be some coolant leaking into the combustion or something, maybe headgaskets.... but I am going to cut it down to
1. Oil Pan, make sure thers enough oil going into the turbo
2. Leaking coolant some where..
3. Headgaskets...
lol, I always have serious amount of bad luck when it comes to my 7th gen car.
But i think this time, I might be lucky, and i dont think it could be a crack anywhere on the HEAD. Cuz 1. the highest I've ran on boost is 8.5 psi.. and thats only on the DYNO.
Daily driving, I always drive at stock 6-7 psi's...
So I've doubt I've done any serious driving that could've ended up f**** my head!
+ its a civic.. THey last long as f****
ps...... Even when the car is really really hot, it wont always trow white smoke,, It only does it sometimes....
I actually think it has to do with the OIL... I may be wrong.
Sometimes I trow just white smoke, and sometimes it comes out bluesh
Old Mar 12, 2005
Well honestly I'm gonna say replace your headgasket. It's not to expensive and then you can see if it works.. if it dosen't then your gonna run into serious problems.. if it does than you can have a beer
Old Mar 12, 2005
Yea iam gonna do my headgaskets,. i thnk if that doesnt work then Ill go ahead and check my turbo out,.!
Old Mar 12, 2005
Boosting Daily
My final prognosis:
screwed
Old Mar 12, 2005
haah yea man....
I am gonna call you
that way you can drive from Orlando to here.
and Ill buy you some Corona's!...
You gotta come up here d00d!.
Ill show ya around!...
Old Mar 12, 2005
Oh Eternal VIC...
I just saw your RIDE.. and i wanna give ya props on keepin it CLEAN..
Looks real good!< keep it up
I luv the inside and the wideband looks bad *** .. all clean...
One of the cleanest Turbo' cars i've seen./
Old Mar 12, 2005
Boosting Daily
Oh Eternal VIC...
Thanx! I really appreciate that
Old Mar 12, 2005
Boosting Daily
And let me clear up what i meant by screwed:
We've narrowed it down to two possible problems:
-Blown HG
-Hairline cracked head
I still stand by the cracked head
but EITHER WAY, ur screwed with having the take off the head. For anyone that's ever done it, it's not hard, but takes time.
Old Mar 12, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
There are a couple of things it could be, if its blowing white smoke, it is NOT the turbo. In a turbo there is no physical way for water to get into the exhaust. You will need to pull the head in any case, wether or not it is a blown head gasket or cracked cylinder head. My friends BMW has cracked 3 heads, didnt't overheat, just blew smoke. Pull the spark plugs and see what they look like.
Old Mar 12, 2005
Havok2k1's Avatar
Wicked Pissah Admin
All (including buddy),
Don't post in this thread unless you have something worthwhile to say please.
Old Mar 13, 2005
NashVegasEX's Avatar
NashVegasEX is an unknown quantity at this point
unless you have stacked 2 headgaskets, you are gonna do your headgasket... only 1 gasket unless you have a longblock in your trunk
