Complete Turbo Kit?
Old Mar 11, 2005
ShadyImprtracer's Avatar
ShadyImprtracer is an unknown quantity at this point
Complete Turbo Kit?
Need ur opinion if im missing anything...
HP Performance kit -
Garrett T3 AirResearch .50 compressor .48 exhaust turbine
Jet Hot coated charge pipes
Jet Hot coated full tubular manifold
FMIC
Bosch blow off valve
External .38mm Tial Wastegate
Oil Lines
Hallman manual boost controller
Battery relocation kit
Clamps, nuts, bolts, etc.
Stuff i bought seperately -
RSX Type S 340cc injectors
NGK Iridium plugs
SF FMU / Fuel pump
Gauges - Boost, Oil pressure, A/F
Old Mar 11, 2005
tfnaaf's Avatar
BLDNPSI Mod
You will need some sort of fuel management computer if your running larger injectors
Old Mar 11, 2005
word...i doubt ill install the rsx injectors considering stockers can handle up to 8 psi i hear
Old Mar 11, 2005
HyaBoosta's Avatar
^I would rather spend the 15min it takes to put the injectors in then kick myself in the @$$ when my motor blows. One thing you'll learn fast...... Nevr cut corners on a turbo setup. It will always cost you more time and money in the end
Old Mar 11, 2005
dezod's Avatar
7thgen Power Maker
Couldn't agree more. +1
Old Mar 11, 2005
Michalo187's Avatar
Abortion Survivor
Thats very very True when your messing with stuff like turbos you can just half *** it unless you have enough money to replace the engine.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
GotSiR
Jun 23, 2016 04:06 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Theshwartz35
Jul 18, 2015 10:49 PM
chrisjackson321
Jul 12, 2015 03:00 PM
