Converting dry to wet?
Old Feb 17, 2005
SLO REX's Avatar
250+ awhp Stage 2
OK what all is needed to convert a NOS dry kit, to a NOS wet kit. Can someone list everything I will need and how much that is going to cost...THanks in advance, and yes I did search, but my search isn't working right for some reason
Old Feb 17, 2005
mxcivic's Avatar
mxcivic is an unknown quantity at this point
gas line, gas selenoid, fogger, jets .... etc... im not sure....
Old Feb 17, 2005
djmota's Avatar
thats pretty much it. I think that they may offer a conversion kit. just not sure.
Old Feb 17, 2005
Pb4uGo's Avatar
Pb4uGo is an unknown quantity at this point
both NX and NOS offer dry->wet conversion kits. NX has better solenoids if you care about that sort of stuff
Old Feb 17, 2005
SLO REX's Avatar
250+ awhp Stage 2
Will the NX solenoids fit a NOS kit?
Old Feb 17, 2005
SLO REX's Avatar
250+ awhp Stage 2
Here is what all it coems with:
15lb NOS bottle
Bottle Brackets
50HP shot already on it
steel lines
Wires
Selenoids
switches
Old Feb 17, 2005
Pb4uGo's Avatar
They should as long as you have the same sized AN fittings to the lines. Probably the same between the companies.
Old Feb 17, 2005
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
^^Its not a good idea to mix match nitrous kit parts like that, especially stuff like solenoids and jets, etc. Thats asking for trouble......
Old Feb 17, 2005
Based on the difference in looks between the NOS and the NX solenoids, plus from what I've heard and learned, I seriously doubt that the solenoids are manufactured by the same company. Both solenoids are gonna flow differently and both NOS and NX suggest certain sized jets to reach the "shot" rating based on their own solenoids, not someone elses which is why it is not a good idea to mix-match different brand nitrous kit parts. You mix up the parts and you're gonna be more likely to run into a/f problems and possibly causing engine damage as a result.
Old Feb 18, 2005
Pb4uGo's Avatar
eh, on the fuel side arguable, but I think it'd be less important on the nitrrous side as despite solenoid flow, until you're in the upper reaches of the solenoid itself, the delivery will be based on pressure through a pill with significant step down from the -2 fogger lines. Even most basic kits flow well enough through the solenoids to support 150+ worth.
I do however agree that mix and match is not necessarily the best setup, but at the tolerences of a stock d17 I'd think the differences would be far less important as long as you stick to the manufacture's reccomended sizing per solenoid.
Old Feb 18, 2005
^^ok then I agree, you MIGHT be able to get away with using mix match solenoids, but when it comes down to the injection nozzle (fogger) I think its definitely imperative that you must use the right jets with the right nozzle. Meaning if you use an NX nozzle, you better be using NX nitrous jets with correct numbers instead of using an NOS nozzle with NX jetting of various sizes and/or vice versa or even mix-match jets (meaning NOS for fuel and NX for nitrous). Me personally would never use a custom nitrous kit comprised of mix match brand parts because of the possible complications and repercussions involved unless you're just talking about a switch or a bottle heater of course, but thats just me.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
jtcavey
Sep 30, 2015 02:18 PM
Luluharp
Sep 27, 2015 11:56 AM
General DIY
Sep 25, 2015 08:02 PM
NROD315
Sep 12, 2015 02:46 PM
