sf manifold....
Old Feb 8, 2005
prototype's Avatar
x-factor
sf manifold....
what is the stock sf manifold made of?
Old Feb 8, 2005
turboengnr's Avatar
DONT PANIC
40 guage black pipe weld l's
should never crack unless you wrap it with header wrap
Old Feb 8, 2005
C2i0v0i1C's Avatar
SuperMODrizd
im not sure i understood what kinda metal that was
Old Feb 9, 2005
Rotarynomore's Avatar
Rotarynomore is an unknown quantity at this point
Stock header materal
Stock manifolds are usualy made of Cast Iron, it's cheap absorbs sound, and holds up to heat well. On the other hand, it's heavy dosent flow well and not fun to weld to.
Old Feb 9, 2005
prototype's Avatar
x-factor
no the SF manifold....the turbo manifold that comes with the SF turbo kit...mine is rusting and i was wondering if there is n e thing i can do to it to make it stop rusting
Old Feb 9, 2005
dezod's Avatar
7thgen Power Maker
probably just run of the mill mild steel
Old Feb 9, 2005
turboengnr's Avatar
DONT PANIC
aka: "black pipe"
Mild steel coated with a corrosion resistant black paint.
Old Feb 9, 2005
deciuss's Avatar
Boosted Auto
other then the black paint flaked off after the first 2 weeks...
Old Feb 9, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
my paint flaked too, but it never rusted
Branscoset
May 28, 2010 01:26 PM
91 CRX gUy
Mar 29, 2008 04:24 PM
7psicivic
Dec 30, 2006 08:31 AM
gsniper666
Oct 28, 2006 07:09 PM
boxster02
Jan 12, 2006 03:56 PM
