K20A2 Engine Swap
Old Jan 7, 2005
standalj's Avatar
standalj should not be trustedstandalj should not be trustedstandalj should not be trusted
K20A2 Engine Swap
I am gettin ready to do a K20A2 engine swap on my '04 LX. My whip doesn't have ABS...will this be a problem when I use Type S axles, hubs, etc.? Ultimately, I don't want ABS.
Old Jan 7, 2005
HondaLuver's Avatar
Its a celebration bitches!
no, don't worry abou it...
Old Jan 7, 2005
exturbo6's Avatar
nice man...congrats..
Old Jan 7, 2005
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
You wont have any problem at all.
Old Jan 8, 2005
standalj's Avatar
For all those of you out there who have done the K20A2 swap, can you please tell me what RSX suspension and brakes components you used (if any). I need to know what Civic components I can retain when doing the engine swap. Thanks in advance for your replies!
Old Jan 8, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
NONE!!!
Old Jan 8, 2005
standalj's Avatar
Originally Posted by xproductionz
NONE!!!
R U saying none to RSX components you used, or none to me being able to use any Civic components?
Old Jan 8, 2005
you asked "can you please tell me what RSX suspension and brakes components you used (if any).".... i said none.. lol.. any questions
Old Jan 8, 2005
standalj's Avatar
Ok...but you are gettin ready to do a K20A swap right? When you do so, will you be using an RSX suspension and/or brake components?
Old Jan 8, 2005
allmotor's Avatar
nor cal 7thgens
u do know that u can just use the si axles and keep 4-lug nut
Old Jan 8, 2005
standalj's Avatar
Please educate me here....does the Si have five lugs?
Old Jan 8, 2005
dude.. for a complete swap you dont even have to worry about ANY brake or suspension components... all you gotta use is the 2002 si axles.... who cares about 4 lug cause it has nothing to do with that... now if and only IF you want to use the rsx axles you have to use the hub and knuckes
Old Jan 8, 2005
in one of your suspension posts i already tried to explain this same thing... like i also said in your other post is that hasport.com has a complete step by step guide on doing the swap for our cars... its pretty much plug and play for a k20 in our cars and so forth
Old Jan 8, 2005
standalj's Avatar
Dude...no need to get so uptight. I appreciate all your feedback, but you don't have to be an azz.
Old Jan 8, 2005
standalj's Avatar
I understand this...I have gone to their website and saw that information. I just need to decide whether I want four or five lugs. If I want five lugs, I believe I will need RSX suspension and brake components. This is all I am trying to get confirmation on.
Old Jan 8, 2005
dude.. im just typing... shesh and now you think im an ***.. i think your reading into my words to much.. i was just giving an explanation
Old Jan 8, 2005
you should have stated that you wanted a 5 lug setup in your first post instead of asking about you needing rsx suspension and brake parts to do the swap
Old Jan 8, 2005
oh yea.. they do sell 5 lug conversion kits
Old Jan 8, 2005
standalj's Avatar
Ok...I am not trying to start an argument here. I have been asking several questions in several different threads. In one of those threads, if not this one, I stated that I would like to end up with 5 lugz after the engine swap. My understand is that if I want to use the RSX hubz...and ultimately end up with 5 lugz...then I need to use the majority (if not all) of the RSX suspension and/or brake components.
My concern is that if I use the RSX hubs...or any other hubs that will result in me having 5 lugz...is that the aftermarket parts that I already have for my car (i.e., coilovers, sway bars, x-brace, etc.) will not be compatible with RSX components.
I am simply trying to get a definative answer as to whether I can continue to use these Civic parts if I end up using RSX axles, hubs, brake components, etc.
Old Jan 8, 2005
Barney's Avatar
Barney should not be trustedBarney should not be trustedBarney should not be trusted
Just stick with four lug. Use the 2002 si axels and you can keep everything the same. If power is an issue then use upgraded axels from ENJO or drive shaft shop .com and get upgraded axels for a 2002 si that are good for 500 to 1000 hp. You do not need 5 lug for any reason except if you just want to have them. As far as four lugs holding the power, yes, they will hold more than you will ever make, Trust me. If you get axels from an si that 2003 or newer they are 5 lug so be carfull what you get.
Phil
Old Jan 8, 2005
allmotor's Avatar
nor cal 7thgens
what i am saying is if he wants to keep 4-lug nut and not worry about gettin the rsx hubs and knuckles then he can just get the si axles and make it easier
Old Jan 8, 2005
standalj's Avatar
Phil
Thanks for the info! Besides 5 lug hubs being able to hold more power, I figure there are more aftermarket possibilities with 5 lug rims. That being said, I will probably stick to the 4 lug and keep it simple.
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
