turbo problem ...
turbo problem ...
i just instaled the turbo, missing link and all stuff... but when i floor it the car is likke it can goo faster o strnger but somehitng happen that it stops it, like a gobernor... and there is a smoke white/gray in the stoopssss... what can be..
goberver.. you mean like it pulls hard then all of a sudden stops pulling like a speed governor.... if thats the case you might have had the same problem i had.. the motor wasnt getting enough fuel
You might be too rich up top and the smoke out of your exhaust is the unburned fuel.
Does it pop, can you hear what sounds like premature detonation or knock?
i dont think too r rich cause im whit the stock injectors and pump on 3 psi, im just going to upgrade my fuelk system whit a return.
abmerop18: sorry about my english, im not too good about, anyway thanks for the ones that help me ...
i dont have fuels system yet.... the missing links is installed, i install theturbo cuase someguys saids that whit minus 4 psi i dont need fuel system .,...
That is your problem right there. even though your at 3psi and some people say it's safe to run that it's not. the missing link is hiding the boost from the map so it's running the same settings as it would stock. Any time you add more air(even 3psi) you have to add more fuel or theres no way your going to have a the proper A/F ratio. Im sure you don;t have a system to tune it with right?(emanage,fmu or at least vafc?)This is a must with any turbo set up. Theres no sence in spending all that money to boost your engine and go cheap on the most essential part.(Turbo,fuel system and tunning....IMO)thats like paying someone 2g's to blow your motor for you.
. My advice is to pull the wastegate spring(if it's external) so theres little to no boost and get yourself at least an fmu but pref. an emanage(not the greatest IMO but the best for us for now)and an msd inline pump. that would be the least expense way to go. RSX-S injectors would also help alot but not too neccesary if you want to run 6 to 8 psi. So park it till you get more fuel and some sort of tunning equipment.
ok so al people that said that i cna run less than 4psi w/o fuel upgrade r wrong ,,,,
Hey MX what's up?
Do you have e-manage or any other electronics for your engine?
Cause you'll need to get it tunned, any change in boost on the system can make your cars computer do funny things.
Is there a tunner with a dyno where you live?
My advice is to get e-manage
Bigger injectors RSX-S
Fuel pump
Return fuel system if you can
Then get it tunned.
Fuel pump
Then get it tunned.
noup theres no tunner whit dyno here im oing to do that in phoenix i guessbut when my car can run lol... so whit a bigger injectors and a vafc2 ill be fine ¿
But is not going to work 100%
Get at wide band gauge or at least the air to fuel gauge
Is better to run rich than lean
Don't blow your engine.
Originally Posted by Supermex
If you can tunne the vafc2 you may be ok.
lol ill tray to keep my engine safe i just have a bad start so i think im going to do that and take it to phoenix to tune it by an expert....
some one told me that the jetta 1.8t may fit, its that true ?
u can fit the fuel rail on.........but i believe that it has to be slightly modified
