Boost gods please help!
Old Dec 17, 2004
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
Question Boost gods please help!
I'm doing a custom turbo kit, with that said, i will instal rsx-s injectors and i need to know how much power can the stock fuel pump handle. What is it its max. I mean to what point is the fuel pump sufficient and in good working condition.
Old Dec 17, 2004
turboengnr's Avatar
DONT PANIC
well, even with the RSX injectors you are still limited to relatively low boost. You need either even larger injectors with an upgraded pump (maybe S2000?), or some sort of rising rate system (return line)
Old Dec 17, 2004
civic01vtec's Avatar
there is one member running 440's on stock pump with no return. Others are running Type S injectors or stock injectors on stock pump. But the real question is..........how long with that stock pump last under that stress. The answer...........nobody knows for sure.
Old Dec 17, 2004
C2i0v0i1C's Avatar
SuperMODrizd
if ur going this far custom what is a 150 buck pump
Old Dec 17, 2004
allmotor's Avatar
nor cal 7thgens
doesnt msd make a fuel pump?
Old Dec 17, 2004
C2i0v0i1C's Avatar
SuperMODrizd
im sure they make a pump, so does walboro
Old Dec 18, 2004
MadWheel's Avatar
Premium Boosted Member
yeah they both make pumps that can be fabbed to a 7th gen...
I would upgrade anyway if you're doing custom. You can tune it once, and have a nice reliable setup. You dont NEED to if you are building up the block, low boost levels have been fine with the stock pump
Old Dec 18, 2004
150 for a pump + modifiied fuel rail + hoses and fittings + fpr + plus piggy back computer + tunning = about $1,500
Old Dec 18, 2004
C2i0v0i1C's Avatar
SuperMODrizd
all he asked was about the pump
Old Dec 18, 2004
can't upgrade the pump w/o doing the rest
Old Dec 18, 2004
opto_isolator's Avatar
Uh...what do you quantify as relatively low boost? I've been tuned to 11 PSI of boost on them with no problems...
Yes - if you plan on going higher RC's are the way to go.....But for a simple direct replacement RSX injectors are the best.
Old Dec 18, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
stock fuel pump......for daily and reliability------>9psi tops IMO
Old Dec 19, 2004
Addicted To Boost
thanks alot guys, alot of help.
Old Dec 19, 2004
turboengnr's Avatar
DONT PANIC
those injectors with the otherwise stock fuel system wont flow a lot of fuel. I have seen only about 3 psi of boost on the stock injectors before it went dangerously lean. Now if you have some sort of return system, then i would trust them.
Old Dec 20, 2004
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
johnsoda
Sep 6, 2015 04:00 AM
