boost backfireing?!?!?!
Old Dec 2, 2004
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
ok so when im low gears like 2nd and i nail the gas when the boost climbs over 5psi i get some hesitation/backfireing/hiccuping from the engine, almost like the boost is goin in and out or spiking, but its not. mabey the engine cant keep up? but if that was true it would be a common problem and i havent seen it yet, anyone have the same thing goin on?
Old Dec 2, 2004
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
your clutch isn't slippin is it? Otherwise, maybe your wastegate is flippin open and close...thats a hard one...
Old Dec 2, 2004
Titleist71's Avatar
mu car would do that too...hesitate and studder a bit at like 5 psi. So I checked my fuel pressure and I wasn't getting the fuel I needed under boost. Waiting on new FMU so I can get it going again and then tune with my emanage.
Old Dec 2, 2004
robo1040's Avatar
yes you know what it might be my clutch slipping, i mean i just bought the ACT clutch to put in cause my stock one took a ****. but funny thing is when i watch the digital boost reading its not really dropping that much? it is a hard one
Old Dec 2, 2004
robo1040's Avatar
what fmu did you have??? i got the stafford one
Old Dec 2, 2004
C2i0v0i1C's Avatar
SuperMODrizd
if ur clutch is slipping u can press the gas and go no where, since ur moving i doubt it, ive had this problem so MANY MANY MANNYYYYYY times, its strictly a fuel issue, if ur moving the boost up, and not accounting for that with fuel, ur **** is leaning out and its falling on its face. and doing exactly what u are doing. its all tuning my friend do it and do it better
Old Dec 2, 2004
Titleist71's Avatar
i have the stafford...waiting on my 4th actually....yes 4th new FMU from SF.
Old Dec 2, 2004
Titleist71's Avatar
each one had had problems with multipliying fuel
Old Dec 2, 2004
C2i0v0i1C's Avatar
SuperMODrizd
ok i rethought my statement, is the car spitting black smoke out when this happens. considering the quote my rethinkin was right, RICH, need to ditch this inline pump right next to the FMU, and that vortech fmu SF uses is horrible, i have one under my bed in my room, my shop refused to use it for that reason, AEROMOTIVE is what i have right now, and an intank PUMP
Old Dec 2, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Bad tuning will cause hesitation.
Old Dec 2, 2004
Titleist71's Avatar
yes I think we know this.....thanks for the help tho.
Old Dec 3, 2004
robo1040's Avatar
ok so the fact that is untuned and also the fact that im using a stafford FMU will cause this hesitation? you guys got a link to another FMU, im kinda in the dark about them...
Old Dec 3, 2004
He asked why it was hesitating. I told him.
Old Dec 3, 2004
dezod's Avatar
7thgen Power Maker
Adjust fuel & timing appropriately. You may need to retard the timing a couple degrees.
Old Dec 3, 2004
exturbo6's Avatar
i had to retard my cam gear 2 degrees for my setup.
Old Dec 3, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Its not the clutch, its either fuel or timing (i know it was mentioned)
Hook up a fuel pressure gauge to see if its the fuel. This will narrow it down. Is pressure rising correctly? Does it peak and drop, does it keep rising? Did you screw with timing at all?
Cam gear timing has absolutely nothing to do with it. Thats cam timing, not ignition timing. Did you put one on and not time that right?
questions questions.
And I would argue that Vortech FMU's are not a POS, the SF design is a POS....
Old Dec 3, 2004
drjvic04's Avatar
drjvic04 is on a distinguished road
Wouldn't the EGT gauge be reading the lean condition? Why is this such a mystery for this guy.(Not trying to flame or put you down Im just wondering if you don't have that gauge or something to that affect.)
Old Dec 3, 2004
C2i0v0i1C's Avatar
SuperMODrizd
EGT= exhaust gas TEMPERATURE
needs a wide band O2 to really tune it good, a basic AF guage aint gunna cut it for ya
Old Dec 3, 2004
robo1040's Avatar
yeah i got a cam gear, i installed it when i did my head gasket, but i had clearence issues, the bolts on the back of the gear were hitting the head! so i put the stock one on..... i havent got it tuned at all, i have no air and fuel computer, im just goin ***** to the wall with a boost controller. Exturbo, did you have the same problem as me? hesitation under heavy boost?
Old Dec 3, 2004
robo1040's Avatar
and no i dont have a egt guage, all i got is a cheap autometer af guage with no wide band sensor, so i cant really tell whats goin on in the exhaust. i imagine its a fuel problem, or timing, mabey i f-ed somthing up when i did the headgasket - - ?
Old Dec 3, 2004
C2i0v0i1C's Avatar
SuperMODrizd
ok dude stop right there, u have no fuel computer and u HAVE A BOOST controller, both of those are huge problems one the AF computer means u cant tune and two the BC means u can increase at will and that is obviously not working to well right now for u. first off u need a fuel computer to start with. then u should have went and got the boost controller, to heck with the cam gear for now, IMO sell that and use the money for a AFC or something that u can tune urslef if u know how, if not get emanage and then ull be set
Old Dec 6, 2004
AceAltima's Avatar
AceAltima is an unknown quantity at this point
Retarding timing however may not be the best solution for his problem...if he is certain that his car is running rich (which in all honesty he probably doesn't unless he's got a wideband meter), pulling timing will multiply the problem he has wouldn't it??
First things first -> it never hurts to get out the timing lamp to check base timing (I assume you've done this...well hopefully!!)
Secondly: is the problem occuring at partial throttle or WOT..??
Being to rich will cause the car to buck and car on, as well will a lean condition...the only way you can truthfully tell is by purchasing a wideband 02 meter and using it's display to tell you..300 bucks for a PLX meter is what i call 'cheap motor insurance'
Your MAP sensor could also be reading a wierd voltage, causing the the ECU to pull timing as well...this would cause the same problems you ahve
Old Dec 6, 2004
robo1040's Avatar
good advice, i think my problem lies more in tuning then anything else, i think i will invest in a fuel and air setup. the problem is at wide open throttle, and no where else. i mean dont get me wrong, i aint boostin like 500 psi, im only running like 8 or 9. i have the synapse missing link so i dont think that is the problem, i had the stafford one, and i know what it feels like when the map ****s up....i aint messin with the timing, i think its a fuel computer for christmas for me!
Old Dec 6, 2004
AceAltima's Avatar
Good choice...remember even at 4 or 5 pounds, a poor fuel setup will be your daddy!
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
