td05=t25???
Old Nov 25, 2004
navyedoc's Avatar
navyedoc is an unknown quantity at this point
td05=t25???
i have a td05 turbo. i am getting a hks cast mani for a t25 will this fit. also what does the td05 footprint match up to if this does not work? thanks for your help. i will be boosting for under 1500 dollars. custom kicks azz. happy thanksgiving.
Old Nov 25, 2004
navyedoc's Avatar
.......ttt
Old Nov 26, 2004
nshaw's Avatar
nshaw is an unknown quantity at this point
what is the tdo5 off of?? if its a mitsu tdo5 it could be a 14b, small 16g, big 16g, or an evo III 16g. this will bolt to a mitsu t-25 exhaust mani..
also you need to see what the numbers are on the turbine housing and measure the outlet of the turbine
Old Nov 26, 2004
navyedoc's Avatar
thanx i already knew that
Old Nov 26, 2004
nshaw's Avatar
so you already knew the answer to the question why did you ask it... or better yet why didnt you put more infor in your post
Old Nov 26, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Like people are really going to try and help you if you're like that to them......
Old Nov 26, 2004
navyedoc's Avatar
sorry, that was my boy nick's reply. he's an a$$. i need a mani that will fit in our 7th gens. i have a adapter for a cx mani. i also have a ex auto stock header i am going to try and use for the turbo. do you think this will work? it is a 14b.
Old Nov 26, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
no. a ex stock header will not work for any turbo app.
HKS make a turbo manifold for D17, that is in T25 footprint
Old Nov 26, 2004
navyedoc's Avatar
the question i have is can i use that tdo5 14b with the adapter plate for a cx mani on the hks mani
Old Nov 26, 2004
import2nr's Avatar
awd pwnz j00
i dunno what a cx adapter is but i will tell you that the 14b will not fit the hks manifold
Old Nov 27, 2004
navyedoc's Avatar
ok, so can i get a adapter to make it fit?
Old Nov 28, 2004
import2nr's Avatar
awd pwnz j00
i dunno, i have a 14b, id like to know also.
Old Nov 28, 2004
cdmx's Avatar
You can get SFP to make you one...they have the flange for the Td05
quick its on sale for 475...in the retail section
Old Dec 8, 2004
NashVegasEX's Avatar
NashVegasEX is an unknown quantity at this point
hell, I have a td05 turbo I'll sell you for $50, a td05 flange I'll sell you for $15, and a d17 head flange for $25 .... All the flanges are 1/2" mild steel ....
Old Dec 9, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
FYI, the Garrett and Mitsu T25 flanges are different.
Old Dec 9, 2004
HondaLuver's Avatar
Its a celebration bitches!
get custom equal lenght turbo header, they will produce alot most power than the log manifold, i got a video of this b18 making about 275 hp with equal length tubeing and they they changed the header to a log mani and it only produced 210 hp with everything else the same...
SpdRcrChk
Turbo
20
May 26, 2010 09:07 AM
02boostlessCIV
Mar 24, 2005 11:06 AM
KalliGarri
Engine Swaps
Dec 15, 2004 08:08 PM
Big Baller L
Engine Swaps
21
Jul 13, 2004 07:26 PM
SpeedRacer
Apr 25, 2004 02:42 AM
