Exhaust problems..TURBO
Old Nov 16, 2004
Civic02playa's Avatar
Civic02playa is an unknown quantity at this point
Hey I was wondering if anyone else has problems with the exhaust ratteling against i can only guess the front strut bar..it doenst stop and it is really annoying it happened after we were finished installing the TSI kit...but if so lemme know i have the DC tcs....so if anyone has an answer it'd be cool to hear what you did....i think i might just go under and space some stuff out or try to figure something out but if there another way around it lemme know. thanks in advance
Old Nov 16, 2004
MadWheel's Avatar
Premium Boosted Member
Your exhaust is no where near your front strut bar. Maybe your front sway bar? The most common thing I noticed, is when you put a turbo manifold on, your exhaust pipe is slightly moved... You should check your rear sway bar and you rear heatsheild and find out if it's rattling against that. That is your most likely point of rattle lol... good luck
Old Nov 16, 2004
i meant sway bar my bad....but yeah i know its hitting against the front sway bar i just need a way to adjust it so it stops....thanks anyways
Old Nov 16, 2004
abmerop18's Avatar
Jam out with your clam out.
mine was hitting my rear sway bar so i took some rubbery tube cover things and zip tied it to my sway bar so it hit that instead of sway bar and it stopped the noise.
Old Nov 16, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
exactly what I did.
Old Nov 17, 2004
MadWheel's Avatar
Originally Posted by RiceRocketeer
exactly what I did.
Ditto here! I cut up a mountain bike tire tube haha...
Old Nov 17, 2004
johnnyslil01ex's Avatar
Soon to be Mr. GST
johnnyslil01ex should not be trustedjohnnyslil01ex should not be trustedjohnnyslil01ex should not be trusted
front or rear.....rear then these guys covered it...if its coming from under your seat slightly to the pass side, then look at the tunnel where the exhaust offsets over and the unibody humps to accomondate, odds are it hitting there. I just used a mig welder and welded a brace onto mine....
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
jtcavey
Sep 30, 2015 02:18 PM
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
