B18 Motor mounts
Old Oct 27, 2004
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
B18 Motor mounts
Does anyone know where to buy them for our civic's?
Old Oct 27, 2004
Mr.Modify's Avatar
there aren't any....
[/Thread]
ibtl
Old Oct 27, 2004
Blahman2's Avatar
Some one has to make some. Or does a B18 fit no problem? I'm clueless here!
Old Oct 27, 2004
HyaBoosta's Avatar
doesn't fit in. companies won;t make them because it illegal to swap and older motor to a new car.unless it's a 2001 B18.
IBTL
Old Oct 27, 2004
4bangin's Avatar
as everyone always says on here...with enough money anything is possible...but as for someone making mounts for the b18....nope, for it fitting right in....nope, for it being legal.....nope. you have to have an engine the same year as your car or newer.
Old Oct 27, 2004
opto_isolator's Avatar
1 member here had some - can't remember his name off the top of my head right now...he was making a custom setup for a speed record of sorts I believe.
Old Oct 27, 2004
HyaBoosta's Avatar
yeah but that was all custom made and only for off road use
Old Oct 27, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Mirage has a b16 in his 7thgen ... but his is a bonneville car
Old Oct 28, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Mirage, PM him...
Old Oct 28, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
yeah, you pretty much have to go to a racing team to get them. some pro drag racers use the b-series with 7thgen bodies. oh, and that crao about it being illegal, plz, cops rarely check under hoods unless ur obviously flaunting it or at the street races.
Old Oct 28, 2004
cambo's Avatar
I wish I was asian
what are you going to do when inspection time come around?
Old Oct 28, 2004
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Custom is the only way to go. Companies won't produce them cause they will only be good/legal for a 2001 civic.
Old Oct 28, 2004
Blahman2's Avatar
Go some place that doesn't care.... Also i doubt most places would check out the engine for a year it was made.
Old Oct 28, 2004
andyman97's Avatar
Turbo Guru
It's only illegal in states with emmissions laws. Making a set of mounts wouldn't be too tough for someone who knows how to fabricate. I'm sure with a set of b series and d series mounts, it wouldn't be too tough.
Old Oct 28, 2004
Blahman2's Avatar
Can you prove its only illegal in states with emisions laws?
Old Oct 29, 2004
andyman97's Avatar
Turbo Guru
What state are you in? If you're that worried about it, check your state statutes. Think about it, by you opening your hood, there is no way for an officer to know what engine is in your car unless he runs the vin, first off. Secondly, if there are no emissions laws in your state, what would be the issue with having an older motor, other than it doesn't pass smog? That is the reason that law is in place. I was in Colorado for about four years where there are emissions and nobody cared what year car or motor you had as long as you could pass emissions standards.
BTW, just an FYI, I am a paralegal and there is no way to prove a negative. If there isn't a law, there isn't a law. There is no way to prove there's no law other than to check the state's statutes and find there isn't one, but I don't really consider that proof.
Old Oct 29, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
take las vegas for example.. not a single place out here checks ubder ur hood.. if you have an obd2 in ur car all they do is hook up to the car and see if its running clean and stuff... if it not then they stick the sniffer in the exhaust and run tests from there... no such thing as engine inspection here... yes we have emissions law here but its very not so strict... as long as ur car doesnt smoke and has a cat that does its job then u should be fine... but other than that if you dont pass just hand the guy an extra $50 and he passes you... shesh...we got more than 70% or racers out here who either dont have a cat or have a motor swap.... and most of the motor swaps are engines from older cars i have lived in cali and hawaii so i know how strict emissions can be... in hawaii they have a thing called RECON..anytime u modify ur car it has to pass the reconstruction requirements then they give u this sticker to put on ur car...if not and a cop pulls u over ur gonna get a big *** ticket fine...its funny cause here in vegas u can drop ur car and drive around while its hitting the ground and the cops dont care.. but in hawaii ur car frame cant be lower than 6inches off the ground...
mistermenphis22
Jul 13, 2015 04:43 PM
manfredww1
Jul 12, 2015 07:31 PM
671civicLX
Jul 9, 2015 03:22 PM
