What suspension are you FI members running?
Old Oct 4, 2004
abmerop18's Avatar
Jam out with your clam out.
PLEASE DO NOT MOVE THIS TO THE SUSPENSION OR TRACK FORUM, I WANT THIS IN FI SO I CAN GET AN IDEA FOR THE TURBO/SWAP MEMBERS. Thank You.
I am just wondering what kind of suspension for the drag strip you FI guys are running? I am currently on Neuspeed Race Springs and stock shocks and I have a hard time keeping the wheels flat on the pavement even without the turbo now.
I am considering some Tokico shocks with my Neuspeed Race springs. You think that will give me the firmness I need to get a good 60' time at the track and will mnimalize wheel hop and keep good traction with turbo? Thanks for the input.
Old Oct 4, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
still on stock baby
Old Oct 4, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Yeah I would like to know the same as well ....... Though I have my mind set on the B&Gs coilovers for now.
Old Oct 4, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
I run stock shocks with some aftermarket coilovers.
2.0 60/ft with azenis.
Old Oct 4, 2004
civic01vtec's Avatar
Tein SS.........but never been to the track
Don't worry about the track matt, get what is best for daily driving
Old Oct 4, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
tien s tech springs and upper strut bar.. no real problems
Old Oct 4, 2004
dragoon's Avatar
hayame coils, haven't had problems with hard launches yet
Old Oct 4, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
JIC Magic FLT-A2
Old Oct 4, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Stock springs and Koni's set to mid strength.
1.8-1.9 60ft.
Old Oct 4, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Drop zone springs and strut bar. Wheel hop and spin like a biatch.
Old Oct 5, 2004
Zzyzx's Avatar
Autocross Junky
THis may help....
Taken from Koni, and it illistrates how Adjustibel shocks can be used to help your ET
Drag Racing Setup
STEP 1:
Prior to testing make certain that the wheelie bars are raised as high as possible while maintaining control and eliminating their influence as much as possible on damper settings.
STEP 2:
Place all damping controls on minimum. Make a pass in first and second gears in order to determine that the car goes straight. If not the alignment, tire pressure, etc. should be corrected before proceeding any further.
Pay close attention to what occurs during gear change. If the car wheelstands or violently proceed to step 3 and then to step 4. However, if there is rear tire shake, wheel hop or excessive body separation proceed first to Step 4 and then to Step 3.
STEP 3: FRONT DAMPER ADJUSTMENT PROCEDURE
Pay close attention to what is happening to the front end during launch and the first gear change. Your goal is to eliminate all jerking and/or bouncing movements so as to obtain smooth transitions at all times.
Too Light of a damper setting allows violent chassis separation and may even result in jerking the front wheels off the ground during initial launch. Too light a setting allows the car, during gear change to bounce off its front rebound travel limiter and then bottom out in a continually oscillating manner.
Too Firm of a damper setting will prevent the tires from easily lifting off the ground and thus providing sufficient weight transfer. During a gear change a firm setting will also cause the chassis to bounce off the tire when the chassis settles down.
Adjust the damper by increasing the rebound damping in 1/4 turn (90 degree) increments until a smooth transition from launch through gear change has been achieved. If double adjustable KONI's are used, adjust the bump damping in three click increments to control the amount and the rate at which your front end settles during gear change. Watch your ET's and your times start to get slower back off the rebound adjustment by 1/4 turn and the bump adjustments by 2 clicks.
STEP 4: REAR DAMPER ADJUSTMENT PROCEDURE
Pay close attention to the rear of the car as your goal is to dampen the tire movements as firm as track conditions permit. Remember that the damper controls the amount and the rate of weight transfer to the tire.
Too Light of a damper setting allows excessive separation between the body and the tire.
Too Firm of a hamper setting allows high tire shock and causes extreme flattening of the tire.
Adjust the rear damper in 1/4 turn (90 degree) increments of rebound adjustment and if KONI double adjustable are used increase the bump adjuster by three clicks for each pass. Watch your ET's and if your times start to get slower reduce the amount of adjustment by 1/4 turn of rebound adjustment and 2 clicks of bump adjustment.
STEP 5:
When all adjustments have been completed reset your wheelie bars as low as possible without hurting your ET. Once you have completed this procedure only fine adjustments may be needed in the future due to varying track conditions.
Old Oct 5, 2004
civicskater's Avatar
Chicks dig my scent
eibach sportlines and tokico's, rsx type S rear sway bar
Old Oct 5, 2004
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
I want to get Skunk2 lowrn springs, with Tokico's. My buddy in a teg has em, real firm ride.
Old Oct 5, 2004
whitevic's Avatar
whitevic is an unknown quantity at this point
Toda Fightex DA's.
Old Oct 5, 2004
mksop's Avatar
mksop is an unknown quantity at this point
any body got turbo and air ride?
Old Oct 5, 2004
exclusive_vtec's Avatar
that would be a waste of money
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
supercivic01
South
Nov 30, 2001 11:27 AM
