11.7 or 8.2 lb flywheel for turbo setup?
Old Sep 29, 2004
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
hey guys I'm gonna be boosted soon. I bought 2K2REDCIVIC's turbo kit. I plan on ordering the ACT stage 1 street clutch kit. my question is which flywheel should I get? the 8 or the 11 lb?
Old Sep 29, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
if it were ME, I'd go with the 8 ;P
Old Sep 29, 2004
Barney's Avatar
Barney should not be trustedBarney should not be trustedBarney should not be trusted
The heavier one is for N\A applications. The lighter one is better for turbo. Less rotating mass = more hp. I have an ACT with 2000 miles on it for $200 plus shipping. Let me know.
Phil
(321)-403-7833
Old Sep 29, 2004
civic01vtec's Avatar
heavier for drag
lighter for auto/x
Old Sep 29, 2004
lighter provides faster reving but heavier provides more momentum
Old Sep 29, 2004
dragoon's Avatar
if it's daily driven, i would go for the heavier one
Old Sep 29, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Exactly. Lighter is better for N/A as it helps the mid-range.
Old Sep 30, 2004
HyaBoosta's Avatar
yeah if you daily drive the car go with the 11.7
Old Sep 30, 2004
XSRCivic's Avatar
11.7 it is thanks for your help guys
Old Sep 30, 2004
Your Parts Guy
The good thing about it is it's quite a noticeable difference over stock.
Old Sep 30, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
I would probably go for the lighter one. Look at this way, buy the lighter one and put it in. You like it, good. If you dont then put in the stock one back as its just 2 or 3 lbs heavier than the Streetlite (11.7 lbs vs 14 lbs, if I am not wrong). Also, for the clutch kit why not go for Stage 2, HC5-XTSS. If you are spending your money, do it right the first time. But it really depends how much boost you are planning to run. Everyone wants to go higher and higher one way or the other, so just make sure you put your money in the right place.
Old Sep 30, 2004
exclusive_vtec's Avatar
^^^ agreed
Old Oct 1, 2004
DodgeNeonSRT-4's Avatar
DodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of light
lighter. between the two weights there really isn't that much difference for how much HP you're putting out
Old Oct 1, 2004
civicskater's Avatar
Chicks dig my scent
dont make it too light, i seriously would not go under 10, theres problems with the flywheel being too light seriously...i cant exactly remember why i think the faster it spins the hotter, etc. a lot of physics involved...any other knowledgable people know what im talkin about?
Old Oct 1, 2004
MadWheel's Avatar
Premium Boosted Member
It's not the fact that it spins faster, they both spin the same per rpm. The lesser amount of mass is the cause for the increased heat. There's less metal to help absorb and dissapate heat.
I had the 8.2lb flywheel in my turbo D17. Great once you're in gear and pulling through some long turns, but other than that, streetlight is what you want. I couldn't launch for sh*t with my pro-lite. I would either bog down or make too much power and light the tires up. So yeah, unless you're doing nothing but road racing, stick with the street one.
BTW - The ACT Extreme Stage 2 clutch setup is the bomb! I got mine from dezod fast, and the clutch has held up to about 75-100 boosted launches with drag radials.
HondaGuy7
Feb 22, 2016 01:00 PM
beanhead
Sep 24, 2015 12:04 PM
