rsx swap cost
Old Aug 27, 2004
d17lpower03's Avatar
d17lpower03 is an unknown quantity at this point
rsx swap cost
sup fellas...people with rsx engine swaps in your 7th gen.....how much yall pay...for engine and the cost to put it in?? =D =D =D
Old Aug 27, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
k20 swaps are not cheap for out cars ... the prices go as follows:
engine
k20a3 - ~1500-2000
k20a2 - 3000-4000
k20a - 4500-5500
then you need:
02/03 Si axles (4 lug) - ~200 (?)
Mounts - ~$500
labor - (?)$ ... probably 500-800
so you're lookin anywhere from 4000-8000
or you could go turbo for ~4000 .. ;P
Old Aug 27, 2004
Jrfish007's Avatar
I've heard as high as 10K with lots of trubles, and as low as 4.5K for the K20a3
Old Aug 27, 2004
Hawk's Avatar
You boost, I-VTEC
$7800 here
(no labor costs though )
Old Aug 27, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^^ much of that is due to your 5 lug and wheels though, right ?
Old Aug 27, 2004
Hawk's Avatar
You boost, I-VTEC
well the whole donor car was 5500 bucks. Rest of that is rad/harness/mounts and little bullshit.
Old Aug 27, 2004
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
$3000 here, thats for an RSX K20A3 though. $1200 for motor and the rest in parts and labor.
Old Aug 27, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^^ nice! ... worth it?
Old Aug 27, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
dam some really cheap prices u guys got over their. 1 shop quote me 10k-12.5k for an Type S swap.
That is why i pick the turbo route
Old Aug 27, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
nevermind.
Old Aug 27, 2004
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
a shop quote me Usdm type s motor=3500 mount 500 Labor=600=800 =$4000
Old Aug 27, 2004
atl01's Avatar
yes, very worth it especialy with the little amount of money i have in it. I mean its not a type S but still better than a D17.
Old Aug 27, 2004
1llmatic's Avatar
1llmatic will become famous soon enough
$14000 CAD
AT to MT swap
jdm k20a motor
hasport mounts
Old Aug 27, 2004
Nitto's Avatar
gone
Nitto will become famous soon enough
I'm paying 6 for a new k20a from a type s with 6k on it, swap and all.
Old Aug 27, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
hey nitto, where you getting that done?
Old Aug 29, 2004
kcm's Avatar
kcm
kcm is an unknown quantity at this point
i got my k20a3 with axels and 5sp and ecu for $1325... now i need the rest of the stuff
Old Sep 13, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
Can you turbo a K20a3 after a swap?? I'm thinkin i'ma get a k20a3 since i reved my present engine (D17) past 8500RPMS! and i'm worried it won't hold with a turbo.
Old Sep 13, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
how da hell did u rev it past 8500 when limiter kicks in 6800 for dx.lx and 7200 for ex
Old Sep 13, 2004
Hawk's Avatar
You boost, I-VTEC
rev-limiters don't work if you downshift into the wrong gear say 5th to 2nd instead of 4th at 6k. Thats how people with RSX's are blowing their motors.
And yes you can turbo charge a k20a3 in a Civic
Old Sep 13, 2004
HyaBoosta's Avatar
im always so confused. Which cars are the K20's pulled from?(i know they are rsx and si and type r) but which engine code goes to each? and what is needed for the Si swap? do you need the subframe to mount it to?
Old Sep 13, 2004
nindoo's Avatar
Why is my vagina bleeding?
I was wondering if was worth to swap a K20A3 into my car if given the opportunity.
Its much cheaper than a k20a2, is it possible to later upgrade the engine to perform like a k20a2?
Old Sep 13, 2004
Jodster's Avatar
Post Whore General
K20A - ITR
K20A2 - RSX Type S
K20A3 - Civic SI/Base RSX
With any of the K-series motors you will need the following.
Motor
Tranny
ECU
Subframe
Hasports Mount Kit
HA Wiring Harness
SI 4 lug axels
SI Radiator and hoses
RSX PS reservoir and line(If PS is wanted)
Custom Clutchline
Custom AC Lines
And that should be it. Might be a couple of small things that you would need to go with it. But over all that the main things.
Old Sep 13, 2004
Ledbelly's Avatar
Im the man in the box
if you put a k20 and a turbo in a civic ..... its no longer a civic
Old Sep 13, 2004
ImportRacer2123's Avatar
K20 Member
Motor
Tranny
ECU
Subframe
Hasports Mount Kit
HA Wiring Harness
SI 4 lug axels
Custom Clutchline
Custom AC Lines
where might those be found?
Old Sep 13, 2004
Boosting Daily
Miss shifted like a **** into 5th at the top of 4th. That's the ONLY time i've ever miss shifted
Old Sep 13, 2004
Boosting Daily
If you got a K20a3 out of a civic SI and boosted it, it would still be a civic......only a boosted SI
Old Sep 13, 2004
2K1Civic17"Gabe's Avatar
Anybody get discounts on their engine? I can get an engine for wholesale from anywhere, but I havent called around yet. Just curious of what a wholesale engine/parts would run?
Old Sep 13, 2004
doubledeuce2k2's Avatar
you could change the head, transmission and ecu. maybe hondata the thing. that would be a start
or a small amount of FI will make it PERFORM like a a2 probably better actually
Old Sep 14, 2004
Jodster's Avatar
Post Whore General
An A2 head and ECU on a A3 Block at 8,000 rpms is pushing it. The stock A3 block will hold it, but not sure for how long. If you add Hondata to the A2 ECU and raise it to 8600, say good bye to your block.
Old Sep 14, 2004
Jodster's Avatar
Post Whore General
Junkyards, ebay, ephatch.com forsale section. I would start there.
