Engine go Boom!!!
Old Aug 8, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Engine go Boom!!!
Well suposedly i got my E-01 to learn 6 psi yesteday, and weel it did not work, i went to pick up a frien to go have breakfast and show of my car, we where at a red light and of i when and first when of nicely but then second just blasted the car forward and i dont know how the hell it happend but a 16 psi spike blew my engine.......
i mean yesterday it was reading ok and would not overboost, and on my fist full boost of the day it whent over about 10 psi.....
what the **** cold be wrong.......
ok anyway does anyone know where i can find a ex engine for cheap??
thaks........
Old Aug 8, 2004
Wolfgang5884's Avatar
ouch sorry to hear that, don't know where to get a cheap engine, did you think of doing an engine swap instead.
Old Aug 8, 2004
yourinmyw0rld's Avatar
That sucks man. maybe u should just buy a new motor from ebay or something
Old Aug 8, 2004
it to much money....... i mean the replacemente coul not cost more than just the RSX or Si engine...........
Old Aug 8, 2004
xtreme26's Avatar
xtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura about
get a k20a2
Old Aug 8, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
try local junkyard. check out this link, worldwide junkyard. http://car-part.com/
Old Aug 8, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
Originally Posted by xtreme26
get a k20a2
why get a k20, when he already has a turbo kit for a d17. i think it is just a waste of money.
Old Aug 8, 2004
civicskater's Avatar
Chicks dig my scent
^^definately is IMO, just get a D17 for like $400 then use some extra cash to put in pistons, head gasket, rods, etc. The small things to help strength your motor...but im sorry to hear that, and hope you find a new engine soon
Old Aug 8, 2004
ImportRacer2123's Avatar
K20 Member
yeah get another D17 and sleeve it as well.
Old Aug 8, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
watafuk! how the hell did that happen? damn! now I'm skurd to put my turbo on! I spent all my dough up to the last penny on my kit... and if I blow my engine then, i'm in serious financial trouble
Old Aug 8, 2004
RedSpec02's Avatar
RedSpec02 is an unknown quantity at this point
I helped civicmexicano setup his turbo, the mechanics and electronics were installed perfectly we triple checked everything. This problem was for sure becuase of the electronic boost controler configuration, anyways we hope its only a blown head gasket...
Old Aug 8, 2004
K20 Member
What Boost Controller was he running?
Old Aug 8, 2004
abmerop18's Avatar
Jam out with your clam out.
im wondering the same thing.
Old Aug 8, 2004
Cocky's Avatar
Cocky guys kick ass!
yah.. don't wanna buy that controller. lol.
Old Aug 8, 2004
02sleeper's Avatar
Boosted Auto Sedan Project In Progress
02sleeper is an unknown quantity at this point
that sux sorrey to hear it
Old Aug 8, 2004
whitevic's Avatar
whitevic is an unknown quantity at this point
Damn, that sucks to hear. E-01's are tricky little devils. PM me if you are interested in an engine.
Old Aug 8, 2004
RedSpec02's Avatar
yeah it was that greddy profec E01, supposely that thing had already "learned" that it must only peak at 7 psi, and then it suddenly spiked 16 psi, dont buy that **** you are better off with a manual boost controler
Old Aug 8, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
MBC's all the way!!!!
Old Aug 8, 2004
abmerop18's Avatar
hmmm. im gonna have to say that the boost controller was improperly tuned cause thats a pretty nice one and it should not be spiking like that.
Old Aug 8, 2004
deciuss's Avatar
Boosted Auto
the e-01 also has a warning level and will start flashing when a spike is taking place if you actualy read the instructions not sure what page but its in there it even has an arrow that shows where the end of the line for safe boost at the level you want is.
page 28 i just looked it up
Old Aug 9, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
PROFEC!!
Old Aug 9, 2004
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
If your block is intact, just rebuild it.
Getting another with stock internals will be a waste.
Old Aug 9, 2004
dezod's Avatar
7thgen Power Maker
Check your Wastegate. Dou run an actuator or external wastegate? One of the vacumm hoses blow off?
Old Aug 9, 2004
its an actator, and suposedly the controller learned 6 psi corectly cause the day befor it wouldnt go higher than 7.5 psi when learning...
the next day on the first full throttle run it blew...
if it was the head gasket could it also loose oil pressure??
Old Aug 9, 2004
cause it kinda sounded only like a when you pop something and the pressure goes out..
and the engine kept running, till i got to a safe place......
Old Aug 9, 2004
also how do i adjust the waste gate so it closed to 5 psi (min on SF kits)
Old Aug 9, 2004
REDchirp's Avatar
do the SF kits have external gates??? I have a Deltagate and mine you turn the screw thingy into the wastegate more to let less boost in... i believe that's how is works at least... and the farther out it is the more boost it'll hold...
Old Aug 10, 2004
Whatthe's Avatar
Whatthe is an unknown quantity at this point
If you're lucky, it will just be busted ringlands on the pistons on the intake side. If it is, ask these guys http://www.theoldone.com/ to make you some new ones, if they already haven't made some for the D17.
Put new pistons in....
fix boost problem and tune well.
enjoy.
Old Aug 10, 2004
anyone know how to use this, aparently the Auto feature will not work, how do i program it for 6 psi, what GAIN value should i place......
Old Aug 10, 2004
Jaykuai's Avatar
ish...
{spanish}
muere zorra!!...
vendes el turbo {/spanish}
