Wastegate Acuator Spring?
Old Aug 1, 2004
ImportRacer2123's Avatar
K20 Member
OK My new wastegate acuator is set at 7psi I one that is at 5 or 6psi. Anyone know where I can find one at?
Old Aug 1, 2004
abmerop18's Avatar
Jam out with your clam out.
eBay?
Old Aug 1, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
what type of wastegate do you have?
Old Aug 1, 2004
SODJAZERO's Avatar
if you are refering to a external wg spring, i got mine here, it is a 5.83psi sping.... http://www.forcedperformance.net/
Old Aug 1, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
If you have an internal wastegate, try bending the arm of the wastegate actuator. Or bend the mounting bracket of the actuator.
Old Aug 2, 2004
K20 Member
i have internal wastegate so bending it changes the amount of boost i can push?
Old Aug 2, 2004
HyaBoosta's Avatar
if you have a internal wastegate that comes set at 8psi. can you leave it set at 8psi and just control it with the boost controller??
Old Aug 2, 2004
First to spool
Boost controller can go up from the set boost, but not below.
You can bend the actuator arm, or depending on how the actuator is mounted, you can move it back and forth... it's kinda a guess and check kind of procedure.
Old Aug 2, 2004
K20 Member
well here is a pic of my new turbo can you help me out?
Old Aug 9, 2004
reytito's Avatar
mine's a t3/t4 with internal wastegate set at about .5bar or about 7 psi. i'd like to know how to lower the base boost amount as well, so please help!
Old Aug 9, 2004
HyaBoosta's Avatar
So if i set the interna wastegate to 5psi and add a boost controller, then I can go up from there by using just the boost controller, right?
Old Aug 9, 2004
K20 Member
yep you can.
Old Aug 9, 2004
reytito's Avatar
so how exactly do you go about setting hte boost controlelr down to 5?
Old Aug 9, 2004
K20 Member
Re-read what he said.
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
