boost controllers
Old Jul 25, 2004
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
boost controllers
Hi, i was wondering, how does a boost controller actually work? I know what they do, but how do they actually work. Like if u raise or lower ur boost , what exactly does it do to produce more or less power? thanks
Old Jul 25, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
^^^well i'm not a boost expert but the controller senses the amount of psi, so if you set the amount to 15psi and it senses 15.0001 and above<<<somethin psi it activates and releases the air pressure...
more psi more power...
boost gurus correct me if i'm wrong...
Old Jul 25, 2004
ACURAwerx's Avatar
is that right?
Old Jul 25, 2004
civic01vtec's Avatar
The first thing to do when working with a manual boost controller is to understand how it works. I get more questions from people asking how to hook up a dial-a-boost because they do not understand what it is supposed to do or how it works. First, a VBC cannot raise the boost level higher than the Turbo is capable of making with the wastegate actuator disconnected. In other words, if your turbo only makes 12 psi wide open, a VBC will not allow it to go to 14 psi. Second, a VBC is nothing more than a controlled boost leak ,albeit a fairly accurate one. The way a VBC works is&
Your external wastegate or internal wastegate actuator has a base spring setting. For the sake of description lets say it has a 5 psi spring. That means that when 5 psi boost hits the diaphragm the wastegate opens. The VBC is installed inline with the hose that leads to the pressure side of the wastegate and the other side of the VBC is a vent. When the VBC is in the closed ( You cannot blow through it ) position, all the boost pressure goes to the wastegate and you have a stock boost level. As you open the VBC boost pressure that would have gone to the wastegate now diverts through the VBC. What this does is fool the wastegate. If you bleed off 5 psi on a 5 psi system it will take 10 psi to open the wastegate resulting in a 5 psi boost increase on your boost gauge and a lot more power from the engine. This is the simple version and results vary with the system, the size of the hose being used, the sensitivity of the wastegate spring. Manual boost controllers are also very prone to boost spikes. This occurs when the VBC is open all the way and small diameter hose is being used. The boost pressure builds faster than the hose can flow which lets the turbo spike up big boost numbers until the pressure fights its way through the small hose to the diaphragm, then the boost drops back down. This is a dangerous situation since the spike can blow up your engine before you know what happened. The best way to minimize spike is to keep the manual boost controller located under the hood with as short a length of hose as is possible. This is easily demonstrated by you picking up a piece of ¼" hose 4 feet long and trying to breath through it. Go ahead, try it. Pretty tough isn't it. Now cut the hose in half and try it. Much easier. Your turbo and wastegate feels the same way.
Old Jul 25, 2004
ACURAwerx's Avatar
kewl thanks civic
Old Jul 25, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
i have a turbo XS manual dual stage boost controller for sale in the marketplace
Old Jul 25, 2004
ACURAwerx's Avatar
kewl thanks jwcardy
Tommy Cohen
Jul 22, 2015 07:54 PM
