Turbo injectors
Old Jul 18, 2004
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
Turbo injectors
I was wondering it is possible run 4 rc rsx injectors or greddy rsx injectors and upgraded fuel pump? with out doing return fuel for turbo.
Old Jul 18, 2004
tfnaaf's Avatar
BLDNPSI Mod
i could be wrong but i would think with a return fuel system you would getter better results, specialy if your boostin
Old Jul 19, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
If the aftermarket rsx injectors are the same size as the stock rsx injectors (dimensions, i.e. height) then they should drop right in like the rsx injectors do. However....try not to go too big unless you have fuel management otherwise your car wont idle if the injectors are too large and you can't trim the fuel.
Old Jul 23, 2004
HyaBoosta's Avatar
you don;t have to have the return fuel conversion but Im not sure if aftermarket rsx injectors are gonna fit without some modification to the rail.
runawaykinms
15
Mar 22, 2019 10:32 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Dave Brabant
Sep 27, 2015 09:43 PM
Luluharp
Sep 27, 2015 11:56 AM
Bruce2
Sep 21, 2015 08:01 PM
