so my shop called me about my turbo
Old Jul 18, 2004
bakablo's Avatar
bakablo is an unknown quantity at this point
they installed my turbo but he says there are alot of problems
they told me, running very lean.. he cant go in the boost.. he says the stock injectors cannot support the boost... he says its running well tho... he says our motors are the only ones to run 95 injectors..
Old Jul 18, 2004
HTOWNBOY's Avatar
HTOWNBOY is an unknown quantity at this point
Old Jul 18, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
lol i still have the stock injectors. what kind of fuel management do u have?
Old Jul 18, 2004
civic01vtec's Avatar
ummm........i'd find new shop
99% of us boosted members are running stock injectors
Old Jul 18, 2004
HTOWNBOY's Avatar
i am using 310cc injectors from a VW 1.8T
Old Jul 18, 2004
abmerop18's Avatar
Jam out with your clam out.
^ direct swap for those injectors or did you have to modify the fuel rail?
Old Jul 18, 2004
I think he is using the VW fuel rail too.
Old Jul 18, 2004
HTOWNBOY's Avatar
just fit right in. i just used some spacers and longer bolts to hold down the fuel rail. thats all.
Old Jul 18, 2004
abmerop18's Avatar
the vw fuel rail fit right in? where can i get one and how much did it all cost you?
Old Jul 18, 2004
so, u are using a D17 fuel rail with the 1.8T injectors ?
did u get the injectors used or new from the dealer? What i really wanna know, is the price.
Old Jul 18, 2004
abmerop18's Avatar
htownboy - i just looked at your ride gallery and the turbo install looks really clean! what manifold and wastegate are you using?
Old Jul 18, 2004
HTOWNBOY's Avatar
d17 fuel rail, custom built manifold and Tial 35mm wastegate.
Old Jul 18, 2004
bakablo's Avatar
ok let me say everything he said....
your car is done its runnign very lean.. your cant go in the boost
your gonna pop your notor. these 1.7s have such a high bigger cycle on the injectors
we have to do a couple of things. either a super afc hacked, which is what were doing on the honda clubs. or do a proper some form of management with injectors..
1.7 are the only motors that run at 95 "duty cycle"? otherwise ther car is runnign very well you can tell theres acceleration, etc.. theres no boost guage, in here.. theres all these engine lights n ****, you got wiring in your car everywhere. this car is a fukn mess, so all of this has to eb cleaned up and its gotta come back for a couple of days once u figure out which way ur gonna go as far as your management system goes...
bye
Old Jul 18, 2004
bakablo's Avatar
i fidn this **** fishy.. if he says it was runnign well.. good acceleration etc... why did he turn the boost down again???
hummmmmmmm
Old Jul 18, 2004
z00mX's Avatar
z00mX is an unknown quantity at this point
where did you get the manifold and ic pipping done? i live around your area too and would like to know thanx.
Old Jul 18, 2004
bakablo's Avatar
essential speed...
they did everything.. all installed...
around 6 grand.. external wastegate, front mount intercooler.. T25 dual ball bearing turbo GT series I think... tial bov.. etc etc... oh yah.. also installed a clutchmaster stage 3 clutch
Old Jul 18, 2004
abmerop18's Avatar
what kind of fuel management are you running? if you dont have any, i would suggest a piggyback system like the greddy e-manage
Old Jul 18, 2004
bakablo's Avatar
I dont have a fuel management...
Old Jul 18, 2004
bakablo's Avatar
i heard hondata is the best
Old Jul 18, 2004
abmerop18's Avatar
no hondata for the 7thgen. get the gredyd e-manage or at the very minimium an apexi safc. that is your problem right there, you dont have any fuel management.
Old Jul 18, 2004
bakablo's Avatar
how much is an e-manage?
Old Jul 18, 2004
deciuss's Avatar
Boosted Auto
350 plus you need a lab top or an e-01 wich will run you 450 or the profec e-01 wich is a boost controller plus controlls the emanage system wich will run you about 560 so almost almost 900 for both
Old Jul 18, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
-HTOWNBOY
I know this is off subject but i will be down in the H-tizzel the first week of august. I will bring my car by.
Old Jul 18, 2004
Havok2k1's Avatar
Wicked Pissah Admin
95 means 95% duty cycle...
Yes you need something to up the fuel, the stock ecu won't help... Search around on here for fuel setups, there are a few...
Old Jul 18, 2004
don't get the e-manage unless your shop is familar with it........it is a bitch to figure out.
Old Jul 19, 2004
HTOWNBOY's Avatar
My shop.
Speed Fetish Performance
Old Jul 19, 2004
dezod's Avatar
7thgen Power Maker
I recently cracked it for an 01 EX this last weekend. Took a lot of toying.
Old Jul 19, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
You can use an FMU / AFC with RSX injectors in the meantime until Hondata releases the proggy.
Old Jul 19, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
^^that might be a long wait
edit:what the hell is a proggy?? I assumed a piggy back system for our cars, but maybe its something else!!
Old Jul 19, 2004
hey htownboy.............u still running open breather ?
