fuel system upgrade question
Old Jul 1, 2004
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
I have the TD extreme kit that comes with two extra injectors and controll unit so I don't need to get bigger ones. I want to be able to run 16 psi. I know the stock fuel pump will never handle that so what should I do. I was thinking of doing something like the SF kit did with an inline pump and FMU and Vafc. But one problem. If the inline pump just ups pressure to the fmu then won't it eventually just out pump the stock one and try to take fuel That is just not there. I really need help with this cause I have all the internals now just waiting to go in and I just need to get the fuel setup worked out.
Old Jul 1, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
You will probably be better off converting to a return fuel system.
Old Jul 1, 2004
Yup. That's the best and hardest way. Return style fuel system and fuel pressure regulator with larger injectors.
Old Jul 1, 2004
ImportRacer2123's Avatar
K20 Member
Street Level Performance is making a return and selling them all ready converted all you need to do is hook up lines and install the rail and your set. They are finishing up testing them as we speak. Thats what I think im going to wait around for.
Old Jul 1, 2004
Wow, that's good news!
Old Jul 1, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
^^^very good news!! When did this happen?
Old Jul 1, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Um....I guess the cat is out of the bag.
Old Jul 1, 2004
CrewChief's Avatar
ok like I said I do not need bigger injectors due to the two extra and the stand alone fuel computer tha comes with them. I have searched and came to this conclusion. I will run an inline fuel pump, bigger intank fuel pump and a vafc II. That will make it ready for 16 thanks for your info though. no need to go to all that trouble. there is always ways around the obviouse you just have to research.
Reginator
Jun 17, 2015 07:54 PM
vtecbrah
May 31, 2015 01:24 PM
blackbullet
Sep 15, 2005 06:49 PM
viper775
Dec 9, 2001 10:52 PM
supercivic01
South
Nov 30, 2001 11:27 AM
