boost leaks
Old Jun 11, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
boost leaks
How do you know if you have a boost leak? What are some symptums?
Old Jun 11, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
no boost
Old Jun 11, 2004
but say you use to reach a 7psi and now ou only get to like 4
check your pipes
Old Jun 11, 2004
SODJAZERO's Avatar
well, it will hit 5psi, then it will drop down to like 4 or 3. It doesnt stay at 5 thru the whole rpm range....
Old Jun 12, 2004
what's your fuel management?
Old Jun 12, 2004
SODJAZERO's Avatar
mf2....
Old Jun 13, 2004
bic's Avatar
bic
bic is an unknown quantity at this point
check all your piping connections. if youre running a manual boost controller that could be it. whats the wastegate set at? fueling wouldnt affect how much boost the turbo was making, if the engine is turning more rpms there is more exhaust gas.
Old Jun 13, 2004
SODJAZERO's Avatar
have a mbc,.... im running 5lbs
Old Jun 13, 2004
andyman97's Avatar
Turbo Guru
Not really. Think about it. Your motor's exhaust powers the turbo. When you're filling the engine with more air, you have to add more fuel to burn the mixture properly. If you don't have enough fuel, the mixture won't burn, therefore there won't be anything to push the rpm's higher and you're car will stall and sputter.
If you can still push the engine to higher rpms, all the way to redline, it shouldn't be a fuel delivery issue, somehow the air isn't getting from the turbo to the intake, either by a piping leak, wastegate leak, leak from the bov or maybe the turbo is gone. It could very well be the boost controller as well. I would try to bypass the boost controller and run at the wastegate spring setting and see if it holds the boost all of the way through the powerband.
Old Jun 13, 2004
im think MBC now but you should still check your pipes.
Your stock wastegate Actuator should be around 5 psi
the only thing that could raise it would be your boost controller unless you have an adjustable wastegate arm( which im assuming you dont)
Is is a Homemade MBC and did you ever get around to checking your pipes?
Old Jun 14, 2004
SODJAZERO's Avatar
When i was tesing it out the other day one of the pipes came off. When that happend of corse i was making no boost at all. Its a tail ext wastegate, it default is 4psi, but ive cranked it up to 5. It usual stays at 5psi untill like 5.5rmp and then 6 rpm it drops to 4psi. Its getting enought fuel.... Mabey too much, ill just take it back to the shop and have them look at it.
Old Jun 14, 2004
ImportRacer2123's Avatar
K20 Member
how do you like the mf2?
Old Jun 14, 2004
SODJAZERO's Avatar
At first i didnt like it. But i read up on it and ive been tuning it myself. I like it! I would rather have something like a sf fuel set up tho, cause evertime you up the boost it has to be retuned, unless you have a wide band.
Old Jun 14, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Check the BFV.. I dunno how it works, but my friend's bov was ghetto rigged and he suffered from almost 5 lbs of boost leak.. he would hit about 15 and then it would slowly fade down to about 10-11 lbs.. He said the bfv was too lose and it caused it to leak out at high boost apps.
Old Jun 14, 2004
SODJAZERO's Avatar
Thanks for that info, ill see if i cant borrow someone elses bov to test.
Old Jun 15, 2004
No problem.. What bov do you have?
Old Jun 15, 2004
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
could be pressure drop from the intercooler. Im betting though its the MBC leaking.
Old Jun 15, 2004
iamboo's Avatar
Retired - SoCal FI Mod
i had a really bad boost leak... i found out it was my boost controller... make just the ball and spring and screw are finely threaded and do leak out of the sides of the screw... make sure the bleeder hole on the boost controller isn't too big... try swaping your boost controller with someone elses for the day...
Old Jun 15, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Use silicone couplers on your piping connections and switch to a Hallman Pro Series MBC
Old Jun 15, 2004
SODJAZERO's Avatar
I i think i was having this problem before i got the boost controller though......... The bov is some generic brand from maxrev.
Old Jun 15, 2004
Yea, it could definately be that then. If it's poor construction..well let's put it this way.. You get what you pay for Not knocking maxrev.. I like their kit.
Old Jun 16, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
run a air compression test on it and u will find your leak
JDMnoob
Aug 2, 2015 02:38 PM
cukaracha
30
Jul 26, 2015 12:01 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Causemo
Jul 5, 2015 06:42 AM
