HKS Manifold & T28 Turbo??
Old Jun 4, 2004
HyaBoosta's Avatar
Unhappy HKS Manifold & T28 Turbo??
from what i got from my last thread the cast iron manifold is the way to go if you want durability. the only cast iron manifold i know of is the hks. it has a T25 flange on it. I've searched and heard that a t25 is gonna get me tq and low end but no top end or large numbers. So i wanted to know if a T28 will bolt on to the hks manifold.Anyone know? anyone have a setup with hks manifold? feedback? Holla
Old Jun 4, 2004
jsammari's Avatar
jsammari is an unknown quantity at this point
It appears the T28 shares the same flange as a T25.
http://www.honda-tech.com/zerothread?id=719285
Old Jun 4, 2004
HyaBoosta's Avatar
good link, thanks. but is that true that a t28 is gonna spike and loose efficency at 10psi? anyone out there running a t28 set up? what numbers are you putting down and what psi are you running?
Old Jun 4, 2004
civicskater's Avatar
Chicks dig my scent
I have that setup...and yes it bolts perfectly. It is the same flange on a T25 and T28. As far as consistency i havent ran 10psi but did run 9psi twice and loved it, the strongest pull was from 3500-5600rpm then it tapered off. I wouldnt run a T28 over 10psi just because it is a smaller turbo and isnt made to run high psi levels(15psi max i believe). If you are planning on running over 10psi down the road get a T3 or T3/T4, they're more laggy but can handle running high psi. I dynoed my car with a tuned SAFC at 6psi and made 166whp and 153lb ft torque. I was impressed, the low end is awesome. I slam the throttle cruising at 30mph in 2nd and the turbo spools instantly and the tires bark! its awesome
Old Jun 20, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
so the hks manifold wont work with a t3 turbo? I really want to get it, but i want a t3 turbo. civicskater what's the ar ratios of you're turbo. Its hard to figure out if a 60 ar is too big. I saw one turbo with a 48ar trim for the turbine and 60 for the compressor. I think that setup would be the ****.
Old Jun 21, 2004
Chicks dig my scent
No it will not work with a T3, the turbine is .48 a/r and the compressor is .53 a/r. I believe the Super 60 T3 that SF uses has the same a/r you are talking about, its spools pretty quick and makes big power
Old Jun 21, 2004
^yah i was thinking that, but it sucks cuz you cant use it with the hks manifold. I guess i could get the boost motorsports one, but i dont want to have to pay to weld the flange on. Kinda sucks.
SammySC
121
Apr 7, 2017 07:43 PM
HondaGuy7
Feb 22, 2016 01:00 PM
jdh022764
18
Nov 3, 2015 06:44 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
