missing link?
Old Jun 3, 2004
carbonrevo's Avatar
carbonrevo has a little shameless behaviour in the past
missing link?
can someone tell me what does missing link do again? I forgot, much appreciated
Old Jun 3, 2004
civic01vtec's Avatar
Eliminates MAP sensor related Check Engine lights
for turbo/supercharged Honda and Acura cars.
Produces infinitely adjustable boost pressures requiring
no adjustment to Missing Link Valve
Smoothens vacuum to boost transition, eliminating MAP
sensor related misfires and hiccups
Eliminates numerous check valves for a show quality,
professional appearance
Eliminates the costly chance of a destroyed MAP sensor
due to boost operation beyond sensor design parameters
Old Jun 3, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
this is the synapse engineering missing link
ML004B
Applications
Acura RSX K20
Honda Integra K20
Honda Civic K20
Honda Civic D17
Available Finishes
Aluminum and Blue Anodized
Old Jun 3, 2004
jwcardy's Avatar
haha post ***** you suck...beat me to it by a couple seconds.....hahahah
Old Jun 3, 2004
that's cuz i own you Wes
Old Jun 4, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Is the one that you get with SF kit good enough or do you have to buy something like this at the end?
Old Jun 4, 2004
dezod's Avatar
7thgen Power Maker
We will be carrying the missing in stock next week or so.
Old Jun 4, 2004
SF's map sensor is good enough, but still garbage.......i highly recommend the ML.
Old Jun 4, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
this replaces the check valve right??'
the little white/black plastic piece...
Old Jun 4, 2004
this question has nothing to do with this but, what diameter silicon couplers do the SF kit use??
Old Jun 4, 2004
yes sir
Old Jun 4, 2004
i ordered my silicone couplers from www.atpturbo.com
You will need about (7) 2.25", (2) 2.5", (1) 2.0", (1) transition coupler.....2.5" - 2.25"
btw, make sure you get T-bolt clamps to fit all of these
Old Jun 5, 2004
dezod's Avatar
7thgen Power Maker
We will have some missing link pieces for the K20 & D17 late next week in stock & ready to ship.
Old Jun 5, 2004
civicskater's Avatar
Chicks dig my scent
Definately get the Missing Link over the SF unit...not hating on SF but the missing link is worth all of the $55
Old Jun 5, 2004
Ahtasham's Avatar
I dont have my SF kit yet so I dont know, but if I get the missing link would it work with the SF unit or replace it? Thanks.
Old Jun 5, 2004
yeah, u just take SF's map sensor which is really made by Ford and throw it in the garbage and put in the ML.....takes 2 minutes.
Old Jun 6, 2004
Ahtasham's Avatar
Whats the best place to get the ML from? Where did you get yours Mr. dialup? $?
Old Jun 6, 2004
http://www.nipponpower.com/forced_in...ssinglink.html
$69.95 plus shipping
Old Jun 6, 2004
Ahtasham's Avatar
Its for $55 plus shipping here:
http://www.racingworks.com/missinglink.htm
Old Jun 6, 2004
Ahtasham's Avatar
Dial up, is there anything else you need to change from the SF kit?
Old Jun 6, 2004
you need to get a gasket for the oil return on the T3, exhaust inlet gasket for the T3 and a OEM exhaust manifold gasket. And you will need to get some fuel line for the fmu.....i used 5/16's and double clamped it.
you can get the gaskets for the T3 here........ www.atpturbo.com
Old Jun 6, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
On my SF kit the link was missing. So I bought a missinglink. The only problem is you have to clean it ever couple of hundred miles or your map sensor does not read correctly and your car will run like crap.
Old Jun 6, 2004
MadWheel's Avatar
Premium Boosted Member
I've never heard that before. What do you do to clean the thing?
Old Jun 7, 2004
i am having that problem now........i am thinking the small filter
Old Jun 7, 2004
guns's Avatar
Skyline R33
I clean the little filter with soap and water and spray out the unit with WD-40.
Old Jun 7, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
Dezod... how much can we get discounted on ur price being 7thgen members? and is there a possibility of getting a group buy on these items???
Old Jun 8, 2004
andyman97's Avatar
Turbo Guru
I have a missing link for sale. Only used for about two weeks. Click the link in my sig.
Old Jun 8, 2004
maiden4ever's Avatar
maiden4ever is an unknown quantity at this point
is missing link universal, or do they make one specifically for the d17
Old Jun 8, 2004
dezod's Avatar
7thgen Power Maker
I'll look into it....I'd need 10 people to make it work.
Old Jun 8, 2004
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I need one.
