What do i need to finish my custom turbo kit?
Old May 20, 2004
ImportRacer2123's Avatar
K20 Member
Here is what I have priced out so far.
Turbo
Manifold
Intercooler
Intercooler piping
Missing Link
BOV
SF fuel System
Boost Gauge
Turbo Timer
Oil Lines
Down Pipe
Old May 20, 2004
jsammari's Avatar
jsammari is an unknown quantity at this point
Intake piping?
Old May 20, 2004
Samari's Avatar
looks like u got it all.
Old May 20, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Turbo
Manifold
Intercooler
Intercooler piping
Missing Link
BOV
SF fuel System
Boost Gauge
Turbo Timer
Oil Lines
Down Pipe
It would help to have a gasket for the return line off the turbo but you could just make one with gasket maker. Also you will need oil pan fittings for your return line and a T fitting for the feed line from the oil pressure sensor location. Do you have silicone couplers and clamps?
Good luck bro.
Old May 26, 2004
civic01vtec's Avatar
like dober said, gaskets........ OEM exhaust manifold gasket, T3 inlet gasket (if using T3), oil return gasket, oil pan fitting, vaccuum lines, fittings for oil feed line, high temp silicone, silicone couplers and clamps, get a couple ft. of 5/16th's fuel line, and some gauges (a/f, boost, EGT, oil pressure).
and what are you doing for a wastegate ?
Old May 26, 2004
Did you port match the exhaust mani gasket and header to match the head ports? If not, see my DIY.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
bhollie
Aug 12, 2015 09:58 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
