SF Fuel System or Fuel return line?
Old May 20, 2004
ImportRacer2123's Avatar
K20 Member
OK I have been thinking about this for the whole day today and I need your guys/girls help. Should I buy the SF fuel system or should I do a return fuel line? In the long run I plan to get a Turbo Cam, and Pistons, rods.
Old May 20, 2004
maxxam25's Avatar
maxxam25 is an unknown quantity at this point
get a fuel system..
Old May 20, 2004
HyaBoosta's Avatar
depending on the kind of numbers you want to make in the long run you probably will need the return set up(if your wanting to go higher than 300hp)
Old May 20, 2004
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
I can get you the fuel system no problem-- just let me know. I am an authorized SF dealer.
Eddie
Old May 20, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
what's the price???
Old May 20, 2004
K20 Member
SF Fuel System is $600
Old May 20, 2004
orso's Avatar
orso is an unknown quantity at this point
correct me if i am wrong but isn't the sf fuel system just an inline fuel pump attached to a vortech fmu.
Old May 20, 2004
K20 Member
not sure kinda looks that way.
Old May 20, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
it is a inline fuel pump connected to a fmu, htownboy can tell you how exacly it works, but it simulates a return line fuel system, the little "piston" inside the fmu acts as a falve to let more fuel to be pushed into the engine by the extra fuel pump, the valve is controled by vac/boost pressure, if your wanting big numbers i would go return, if your planing to run no more than 12psi i would go with sf and alcy injection, it realy depend on your needs, me personaly i dont plan on running no more than 5-6lbs, ive been thinking of custome fabricating one of those sf kits for myself, it would be way cheaper than 600 bones,
Old May 20, 2004
truehonda's Avatar
I got the SF sysemt for 550
Old May 20, 2004
Samari's Avatar
how fast can u get an sf system to me for?
Old May 20, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
IMO I'd go return. It costs about the same and gives you a much better system to start off with. Once someone comfirms the injector theory you will be set.
Old May 21, 2004
K20 Member
True dober but someone needs to write up a DIY Fuel return system..
Old May 21, 2004
truehonda's Avatar
I can have it to you in 1-3 weeks. I can make sure of that too now.
Eddie
Old May 21, 2004
Your Parts Guy
What needs to be done:
- Modify fuel rail to accept fuel return line
- Upgrade stock fuel pump located in the gas tank
- Bypass FPR in the gas tank
- Run return line back to tank from modified fuel rail
- Use aftermarket FPR (I recommend Aeromotive) and set to stock fuel pressure
opto_isolator can probably offer you a more detailed DIY but this is the basics. If you are not mechanically inclined or don't feel comfortable with doing it yourself take your car somewhere and get an estimate. This process is not a big deal for a true mechanic.
Old May 21, 2004
K20 Member
I am not that mechaniclly inclined but with my 2 Buddys that always help me with every project that I do to the car. IE Nitrous install, dual purge, VAFC II, Ported Head..
Old May 21, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
yep, that is it...that is all that you have to do..and i will be doing this very soon for my custom turbo setup...i just sold my sf kit and i am almost done piecing my custom setup together...and i am getting all my stuff for my return fuel conversion from dober...
CarStuff
Dec 6, 2020 12:52 PM
RIPSAW
Nov 6, 2015 04:36 AM
vtecbrah
May 31, 2015 01:24 PM
TaiChi
Dec 17, 2001 09:09 PM
supercivic01
South
Nov 30, 2001 11:27 AM
