Do's & Dont's
Old May 15, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
Question Do's & Dont's
okay finally my turbo kit is coming in so for all u guys that are either boosted or have experience with FI cars...what are the do's and don'ts of driving a boosted car...PLEASE DONT FLAME ME....I'M NEW BOOTY AT THIS...We gotta start somewhere so I rather pick u guys brains' than go out and mess something up....I'm posting this on another site also and I'm gonna put both of the responses I get together...thanx
this is my kit...Ive added upgraded turbo ( T3 Super 60), equal length manifold and alcohol injection
http://www.staffordfabrication.com/m...=4&s=&menu=302
Old May 15, 2004
civic01vtec's Avatar
honestly, if you have to ask this question, then maybe you shouldn't be boosting at all.
if you need any help with the install, then PM me or hit me up on AIM
Old May 15, 2004
dragoon's Avatar
Do: Use common sense.
Don't: Not use common sense.
Old May 15, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Just keep it under 8 psi and you'll be straight. Any higher and you should get some sort of EMS and get it tuned. Good luck!
Old May 15, 2004
yourinmyw0rld's Avatar
just make sure u install the kit right the first time and take ur time on it.
Old May 15, 2004
JetBlu01's Avatar
New Member
thanx guys...so not over 8psi without tuning? anything else...what should i run daily, stock psi? I was told I could run 9psi at the track....also right now, I use medium grade unleaded so when I boost, use super unleaded right? any special oil type/weight recommended? I've also heard about driving it in EXTREME heat is a ? sorry I'm new to all of this but it will look good in my engine bay...I'm learning as I go along, trust me...I've searched and didn't find anybody talking about this stuff
Old May 15, 2004
MadWheel's Avatar
Premium Boosted Member
Colder spark plugs help. 9psi is still a no no without alcohol or retarded ignition timing.
daily drive at 6ish and you'll be fine, about .5-.52 bar is fine for the track, that way you can still drive it home later.
.52bar = 7.54psi btw...
