Got My Motor Done! (Pics & Specs inside)
Old May 6, 2004
Mirage's Avatar
Mirage is an unknown quantity at this point
I am in the process of swapping a B16A into my 2001 LX Coupe for racing (no street/smog). It's a 1,500cc class so the bore was reduced. It will get an Edelbrock nitrous kit after I shake it down and then a big turbo later this year (along with a lower CR).
I finally got the motor completed last weekend and hopefully the prototype HASport mount kit will arrive so I can start the install this weekend (thanks Brian!).
Let me know what you think!
SPEC SHEET
Short Block Blueprinting by: Golden Eagle Manufacturing
Cylinder Head Porting by: R&D Dyno service
Intake Manifold Porting by: Edelbrock
Engine Base: B16A, I4, DOHC 16V VTEC
Bore: 78.0mm (3.071")
Stroke: 77.4mm (3.047")
Displacement: 1,479cc (90.3 cid)
Shift Point/Redline: 10,000 rpm / 10,300 rpm
Block: Password:JDM supplied 91 B16A
Sleeves: Golden Eagle Mfg. HD iron sleeves
Crank: 91 B16A micro-polished & chamfered
Bearings: ACL
Block girdle: Golden Eagle Mfg. 3-main girdle kit
Oil pan: 5.5 qt deep sump
Windage tray: Modified Acura GSR
Connecting rods: Eagle H-Beam
Rod bolts: ARP Custom Age 625 Plus
Pistons: Arias custom 2618
Compression ratio: 13.3:1
Head gasket: Copper coated w/copper o-ring in sleeves
Head studs: Golden Eagle Manufacturing
Cylinder head: Password:JDM supplied 1991 Honda B16A
Porting: R&D Dyno CNC porting
3-angle valve job: R&D Dyno
Intake valves: Ferrea 25 degree Super Flo, 33.5mm, P/N F1446P
Exhaust valves: Ferrea 25 degree Flo, Super Alloy, 28mm, P/N F1449P
Valve springs: Crane dual springs, P/N 903-2006
Retainers: Crane titanium P/N 903-2006
Valve locks: Ferrea P/N K10034
Cams: Crane Stage 3, P/N 253-0014
Cam gears: AEM adjustable (-1/-1)
Header: DC Sports custom 1.75"/1.875" stepped w/4-1 merge collector
Exhaust: 3" open
Intake manifold: Edelbrock Victor Jr w/staged injection
Intake manifold porting: Edelbrock R&D
Throttle body: Edelbrock 75mm
Primary (low) injectors: RC Engineering 440cc (x4)
Primary fuel rail: AEM
Secondary (high) injectors: RC Engineering 650cc (x4)
Secondary fuel rail: Edelbrock
Crankshaft Dampner: Honda Civic Type R single groove (factory underdrive)
Alternator: Stock Honda B16 w/AEM underdrive pulley
Water pump: Golden Eagle Manufacturing electric water pump, P/N GWP100
Engine management system: AEM EMS, P/N 30-1900
Ignition: AEM 4 channel CDI, P/N 30-2801
Coils: "Coil on Plug" CDI Coils, Honda Motorcycle P/N 30700-MBW-611
Manifold pressure sensor: AEM 2 bar sensor, P/N 30-2111
Fuel pressure sensor: AEM 125 PSI sensor, P/N 30-2114
Oil pressure sensor: AEM 125 PSI sensor, P/N 30-2114
EGT sensors: AEM RTD type EGT sensors (x4), P/N 30-2050
AFR sensor: AEM UEGO gauge, P/N 30-4121
Crankcase pressure sensor: AEM 2 bar sensor, P/N 30-2111
PROJECT SPONSORS
Advanced Engine Management
Edelbrock
Password:JDM
Arias Pistons
DC Sports
Ferrea
R&D Dyno
RC Engineering
HASport
Honda Tuning Mag documented the engine build for an upcoming article. Probably will hit in the September issue.
Old May 6, 2004
maxsin's Avatar
No Title
maxsin is an unknown quantity at this point
That is cleeen.!
Why not drop it into a 6th gen hatch?
Old May 6, 2004
Spider883's Avatar
9K Redline Owns U
nice.. cant wait to see the mounts for this.. will be interesting.. keep us updated
Old May 6, 2004
Mirage's Avatar
Originally posted by maxsin
That is cleeen.!
cuz it's already been done. plus, I like the looks of the 7g coupe.
Old May 6, 2004
Spider883's Avatar
9K Redline Owns U
amen to that
Old May 6, 2004
Texas Rice's Avatar
Texas Rice is an unknown quantity at this point
Good build up, I bet it hurt the pocket book hehe.
Old May 6, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
holy f*cking sh*t... that is hella nice! keep us posted... 10,000 rpm redline ... holy cow
Old May 6, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Quite the motor ya got there....
Old May 6, 2004
Mirage's Avatar
Read it again. 10,000 RPM shift point 10,300 redline
Old May 6, 2004
Civryder02's Avatar
Civryder02 is an unknown quantity at this point
thats crazy dude ... cant wait to see it in a 7thgen coupe.
Old May 6, 2004
Hawk's Avatar
You boost, I-VTEC
wow that list of mods sounds expensive
Very nice, can't wait to see it in the thing, and hear what it does.
Old May 6, 2004
Mirage's Avatar
why yes, yes it did.
Not pictured is the flywheel/clutch/pressure plate, the custom radiator & fans, the full interior safety equipment, the custom welded in 10pt cage, the onboard fire system, the custom 11,000 rpm / 220 mph gauge cluster, coilovers and a million other things. Not least of which is the low mileage, very clean 01 NBP Coupe I used as a donor.
It's simply amazing how easy it is to spend tremendous amounts of money on something so basic as a race car. If it weren't for the help of the project sponsors, it would not have happened as would have run out of money long ago...
So one again, thanks to:
Edelbrock
Password:JDM
Arias Pistons
DC Sports
Ferrea
R&D Dyno
RC Engineering
HASport
American Honda Motors
Sparco
ACT
Fluidyne
JD Performance
^^ Buy stuff from these shops ^^
^^ They are good people who ^^
^^ helped a brutha out ^^
Old May 6, 2004
cambo's Avatar
I wish I was asian
so uhh...how much power is she supposed to put out?
Old May 6, 2004
Mr.Modify's Avatar
werd! definitely keep us updated!
Old May 6, 2004
abmerop18's Avatar
Jam out with your clam out.
wow thats awesome man. cant wait to see the results
Old May 6, 2004
Mirage's Avatar
I don't really know yet. Once installed it goes straight to the dyno for tuning.
It's actually quite a unique motor. It's built as a serious "all motor" engine but because it's only 1,479cc it's not going to be a powerhouse but I do expect at least 200-220 to the wheels in this configuration (this motors "big brother", a 1.8L made 260 whp). Once I get the thing dialed then it's going to get a 125+ shot of nitrous.
Both of these configurations are really just warm up's. The real test comes when I put the turbo on where I want 500+ sustainable HP to the wheels at 20-22 psi. To get this I will change the pistons & rods and switch to methanol but everything else will stay as is.
500 whp should be enough to push my 7th Gen to over 200 mph at Bonneville, and thats the whole point of this exercise. The only problem is going that fast, at nearly 10,000 RPM, for 7 very long miles.
Old May 6, 2004
guamcivic2k1's Avatar
YoUnG N SuXsExFul
awesome!!!
Old May 6, 2004
Ershall's Avatar
Ershall is an unknown quantity at this point
Your motor
Holy fart nuggets...that's one nice piece of work right there.
Old May 6, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
looking really good. Good Luck
Old May 6, 2004
RiceBuRNeR's Avatar
Turbo Member
thats awesome man. I always wanted to do a b16 swap but I didnt think it was possible w/ a 7thgen.
Old May 7, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Wow, definately clean.. Way to go buddy! imp:
Old May 7, 2004
ImportRacer2123's Avatar
K20 Member
damn sounds like my buddies motor.... here is a pic of the block
Old May 7, 2004
Green Civic's Avatar
Nice. So your doing all this for racing on the salt?
Old May 7, 2004
Mirage's Avatar
Yup.
Not alot of imports running there. Alot of old school stuff, low tech V8's with carbs. Thats one of the reasons I chose such a small motor class (1.5L). I wanted to go very fast with a very little powerplant.
It's sort of a "welcome to the 21st century" shout out to all the lakesters, coupes, roadsters and yes, even the Ford flatheads that are still running there. They are the norm there, the imports & fwd's are the newbies.
It will also run at El Mirage & Muroc dry lakes.
Old May 7, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
HOLY F'IN ****.
ALL I CAN SAY IS BLING BLING!!!!!!!!!!!!!
Old May 7, 2004
Jodster's Avatar
Post Whore General
I want to do a B16 swap. I know that its illegal in my car, but honestly how many cops are going to pull me over have me open my hood and know that the motor swap is not legal in Ohio? hahaha
Plus the motors are cheaper and everything is out for them. I would love to have a K20, but I'm not made of money.
Old May 7, 2004
C2i0v0i1C's Avatar
SuperMODrizd
is that b16 block decked out to a b18?? looks like it
Old May 7, 2004
NoFriends's Avatar
I like ruining your threads.
and your adding boost?? my word, cant wait to see it.
Old May 7, 2004
Mirage's Avatar
I'm running the 13.3:1 only for the next few months, all motor and Nitrous. When I tear down in the off season to put the turbo on, I'll either toss in a new set of flat tops (9.5:1 or so) and a new set of rods or I might just build another shortblock for the turbo. We'll see how the $$ holds out
Old May 7, 2004
kelemi821's Avatar
kelemi821 is an unknown quantity at this point
yea i was thinking the same thing when i read that
