Motor Took A Shit!!!
Old Apr 28, 2004
bac7213's Avatar
bac7213 is an unknown quantity at this point
Motor Took A ****!!!
hey guys well, i dont know if you people read my previous post but that rattling noise wasa broken bearing, well my mechanic told me that just from hearing it, BUT **** that is killing me is that he told me that if the actual block was damaged cuz of the busted bearing that it would be a real bitch because more money to spend on fixing it and all that crap. well i need you guys opinion? what are the chances that the block could be damaged??? i mean when my car is on ideal it sounds perfect, but when it goes up on rpms like past 3000 it makes that rattling noise. i mean wouldnt my car be sounding worst is the block was damaged or wouldnt it just not turn on or not run??? i got my JE pistons today and eagel rods, (high compression) i also got my greddy e-managment. those are my plans so far. i hope nothing more is needed. i mean tell me is there any way to know if my blokc was seriously damaged cuz they told me that a peace of the bearking could have broke loose but they are not sure until they actually open up the engine. well let me know what u guys think.
Old Apr 28, 2004
C2i0v0i1C's Avatar
SuperMODrizd
u got high compression pistons with a turbo, uh not a wise move but whatever, also if ur bearing was broke, id take the whole engine apart, take everything out and have it inspected to make sure there are no scratchs,u might as well sleeve the thing since its going to be out the car anyways
Old Apr 28, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
Damn man that sucks.....
Old Apr 28, 2004
tfnaaf's Avatar
BLDNPSI Mod
im curious how he was able to diagnose a broken bearing???? Me thinks this would need to have the engine tore down to be able to determine whats bad for sure. I wouldnt get too woried until its torn down
Old Apr 28, 2004
Havok2k1's Avatar
Wicked Pissah Admin
You would be able to tell easily if the bearings were going, it's a distinct sound...
I would STRONGLY consider having the block refreshed. Bad bearings, especially broken ones, can cause a ton of issues. When a bearing is broken, the crank can not rotate as smoothy. Things like crank walk, main cap issues, crank line distortion, or even broken cranks or rods. This is just the effects on the motor.... Not good.
The problem is whether you want to take a chance and throw a new rotating assembly in and have even more issues a year from now.... In the grand scheme of things, it's not all that much ($500 maybe?) for prevention of future problems.....
Old Apr 28, 2004
civic01vtec's Avatar
well, the motor will have to be ripped out and a whole new bottom end will have to be put in. So, send back you high compression pistons and get low compression ones. And if you have the extra money, i would definitely sleeve the block
Low compression for forced induction
High compression for All Motor
Old Apr 28, 2004
abmerop18's Avatar
Jam out with your clam out.
lol own3d
Old Apr 28, 2004
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
hey man.. this is what happened to me before i blew a rod thru my oil pan... take it from me, dont drive your car at all.... i had that same noise and on the way back from the honda dealership (btw, they dont know shi.t) they said it was my valves that needed adjustment, they adjusted it and that noise was still there... yea i know that same noise... anyway, on the way back from the dealership to my house boom, oil all over my windshield... stuck on the side of the road for hours... not cool at all. DONT DRIVE IT! do what they said, take it apart and change that crap out...
Old Apr 28, 2004
yourinmyw0rld's Avatar
does the noise go away after u warm up the car and been driving it for like 10min ??? or u could still hear it?
Old Apr 28, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Tear it down replace the bearings install your rods and pistons (keep the pistons) and tune the FUG out of it. Higher comp pistons can be good if your tuner is good.
Old Apr 28, 2004
tfnaaf's Avatar
BLDNPSI Mod
Re: Motor Took A ****!!!
There is a difference between broken and worn out......... And he also refered to possible block damage????? this would mean a bad main bearing not a rod bearing .......... And i know what a bad rod bearing sounds like, Havok2k1 maybe you can tell me what a bad/broken/worn out main bearing would sound like.
From what he has describbed as the noise i would tend to think its a rod bearing worn out. And unless the rod were to break in the mean time i dont see how it could cause block damage.
Rod knocks are loudest at higher speeds (over 2500 RPM) Feathering the gas pedal may result in a distinctive back rattle between 2500 and 3500 RPMs.
Bad rod knocks may double knock if enough rod bearing material has been worn away allowing the piston to whack the cylinder head in addition to the big end of the connecting rod banging on the crankshaft rod journal. It will sound like a hard metallic knock (rod) with an alternating and somewhat muffled aluminum (piston) klock sound.
Wrist pin knock in modern engines is very rare today but is a favorite for the misdiagnosticians.
http://remanufactured-engines.com/page4.htm
Old Apr 28, 2004
oh yeah, i just thought of something........maybe the cause of your problems was from the DH Racing single groove crank pulley that you installed 3 months ago.
Old Apr 28, 2004
C2i0v0i1C's Avatar
SuperMODrizd
YOU MY FRIEND have JUST MADE the MOST VALUABLE POINT in this thread. FIND a shop and see if they can diagnose the pulley as the problem creator, if that is the case, all hell will break loose. consider yourself lucky that u didnt **** up the turbo
Old Apr 28, 2004
bac7213's Avatar
hey guys thats for ur responses, well what my mechanic told me (DRT racing) was that i spun a bearing, he said not to drive it hard to just keep it mad stupid slow. but he said their might be a chance of other damage but hes not sure until he takes it apart. he said the cause could have been not enough oil or the pump took a **** or something. i highly doubt its the pully from DH, i hope not lol. well any way im waiting for my mechanic to give me a date to go in, well i dont know but dont you guys think that if something worst was damaged in the engine that my car would run like ****?? i mean when my car is on idel it sounds perfect. no noise nothing. well answer back thanxs
Old Apr 28, 2004
the DH pulley messed up your crank which in turn messed up your oil pump........we shall see
Old Apr 28, 2004
Jrfish007's Avatar
Where did you get your JE high compression pistons? Wanna sell 'em?
But yeah, I go with the pulley not being balanced. Take it to a machine shop and have them spin it and see if it is ballanced, and if it flies off the machine at 1500 RPM, then you have your problem solved. Or at least the cause of it.
Old Apr 28, 2004
Sorry man, DH messed you up good!
Although many DSM owners have removed the harmonic dampener crank pulley without incident, doing so almost certainly increases crank bearing wear, and COULD lead to early failure of the crank or crank bearings. Just how much the life of these parts is shortened is unknown.
I personally know five people that have ruined their main bearings after about 15K miles of non- OEM pulley use. Main bearings on Hondas don't normally fail; it's usually something else. Two main causes of bearing failure are lack of oil and excessive vibration. Since the bearings didn't spin, lack of oil can be ruled out, and since all five cars had underdrive pulleys, and all five failed right around 15K miles after the install of the pulley, through process of elimination, I've decided that the underdrive pulleys were at fault.
Make sure whatever pulley's you decide to use that they have some type of dampener.
Without a dampener the pulley may create excessive vibration in the crank causing damage to internals or oil pump failure.
This may happen even as a result of a lightweight pullet regardless of dampening.
I ran a lightweight OEM Civic Type R crank pulley on my Integra GSR block. (The GSR crank pulley is huge, and has slots for PS, AC, Alternator compared to the CTR Crank Pulley with just a slot for the alternator).
Even though the CTR Crank pulley is dampened, I still managed to shatter 2 oil pump gears!(which lead to spun bearings & blown turbo! ) I had no clue why. When I changed back to the stock GSR Crank Pulley, I never had the problem again.
Old Apr 28, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Dude, from the thing post topic, i thought you might have had carbon deposit building up on your tailpipe or something.. sorry.. just thought i'd let you know
Old Apr 29, 2004
Havok2k1's Avatar
Wicked Pissah Admin
The vibration from a warped pulley WOULD cause it, although I wouldn't jump to conclusions...
Irregardless, good luck with it....
Old Apr 29, 2004
Hawk's Avatar
You boost, I-VTEC
maybe you should have beefed up your lower end a tad before you slapped the turbo on....just a thought.
Good luck getting it fixed, hope everything turns out ok.
Old Apr 29, 2004
bac7213's Avatar
thanxs, well i dont know if its the pully i mean everything has been already i had the pully even before the turbo so i wouldnt start to blame it on that but i will have that checked out, also i use to have an oil leak when i installed the turbo so that may be a cause, since a main cause of a spun bearing is not enough oil, so there could be many things, also heat, but i dont know we will see, as of now im juts worried shitless cuz i mean i have the money to get pistons n rods and all that and installed, im getting a hook up, 1000 bucks for installation of rods pistons n bearing and whatever else. but im scared that once they open the block they tell me i have to get a new one cuz there was more damage, i dont want that. PREY for me lol that hopfully wont happen. we will see.
Old Apr 29, 2004
here's what you do Byron.......take your car to your mechanic, show him the DH pulley and he will do this.......
I am telling you, put back on your OEM crank pulley.
Old Apr 29, 2004
Old Apr 29, 2004
Mirage's Avatar
Mirage is an unknown quantity at this point
... well what my mechanic told me (DRT racing) was that i spun a bearing ...
Ralphie at DRT is very good. Just drop the car off and have them fix it. While you are at it, ask his opinion about the pulley. But most of all, DONT DRIVE THE CAR UNTILL IT'S FIXED!. If you think you got damage now, just wait till a rod ejects itself from the engine, then you will want to put a gun in your mouth...
Old Apr 29, 2004
Mirage's Avatar
Also, I wouldn't stress over the pulley just yet, chances are that the boost just overworked the bottom end or you had knock and it pounded the bearing to death.
The torsional vibration concern with the lightweight crankpulley is a very long term issue and would not bomb your motor out in 3 months, But a turbo just might. Either way, it's easy to determine once you crack open the motor.
btw, whats the most boost you have run?
Old Apr 29, 2004
Jrfish007's Avatar
^^^ very true. I think everyone here is blaiming a pulley when that is minor thing compared to a turbo. Think of all the places the car can now lose oil and all the fittings and if one of those gets plugged or the turbo frags becuase of a bad wheel, you get the idea, there's a lot of places to go bad.
Old Apr 29, 2004
well, he was only boosting around 6 lbs daily, when others are running 10 or more.
I am willing to bet the pulley caused his oil pump to take a ****.
Old Apr 29, 2004
Jrfish007's Avatar
True 6 lbs isn't much, but I'm talking about the set up and installation of the system it's self (not trying to rip on him or anyone else) but everyone makes mistakes. If there was some crap in something (like shaving in the turbo or something) it could have cause a oil line to block up, just thinking though. I'm not saying it wasn't the pulley either, I sure can't tell just from this thread, but his mech hopefully will.
Well, good luck with it man.
Old Apr 29, 2004
Jrfish007's Avatar
Oh yeah, you won't see me running the DH pulley anytime soon, not because I think it bad, but becasue I think all these pulley's are bad for long term, I want my car to go for at least 150K (that's why I bought a Honda), its got 12K now, so I don't want to put anything like that on my car.
Old Apr 29, 2004
C2i0v0i1C's Avatar
SuperMODrizd
my opinion=PULLEY, nothing more nothing less!
no one else here has psun bearings or anything of the likes with boost, for crying out loud, i hit 1 bar, so why arent my bearings spinning.....................................
