uberdata...
Old Apr 27, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
uberdata...
Ok, uberdata is just like Hondata only it's free. I am speaking with several knowledgable individuals who seem to think that if we convert to OBD1 we shouldnt have any problems using uberdata. Check out my post on the uberdata forum for more details.
http://www.ecimulti.org/uberdata/for...y;threadid=564
To use uberdata you will need to modify your ECM and purchase a burner so you can burn your .bin files onto a chip. They seem to think that we could use a p28 OBD1 ECM. Anyone else have any thoughts?
Go ahead and download the latest version of uberdata it is a windows based application that is very user friendly.
Old Apr 27, 2004
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
well consider this, with obd 1 u have alot of electronics to worry about less, meaning less things to try and fool the ecm with. with obd1 its alll lesss, less hassle, less problems, obd2 on the other hand contains more options to just modify electronics on the vehicle, not neccessarily just that, but u can do alot more with obd2, i havent heard of anyone running obd1 in their civic before, it might be hard to rewire up the harness to the new ecm, but im sure someone will do it.
why do you want to go obd 1, is there a point around this, maybe becuase its less to work with as far as engine work goes, easier to test and tune
Old Apr 27, 2004
Mirage's Avatar
Mirage is an unknown quantity at this point
When you remove the factory ECU and replace it with an OBD1 you will have at least 2 issues to deal with.
1. The coolant gauge in the factory cluster gets it's data from the mutiplex controller, which gets it from the ECU via the datastream. The OBD 1 ECU does not have this so the gauge will not work.
2. The ECU increases the idle motor position when the A/C turns on. This information also is on the datastream so the ECU will not increase the airflow to the engine in preperation for the A/C compressor to kick on. So in short, the engine will likely die, or almost die every time the A/C cycles on. I dont remember but the A/C compressor may actually be controlled by the ECU, which may not work also. Not sure on that last part.
Old Apr 27, 2004
Your Parts Guy
They made a suggestion to convert to OBD1 and I know that people are looking for tuning alternatives that is why I brought this up. Plus you can't beat the fact that it is FREE.
Old Apr 27, 2004
Your Parts Guy
1.) There has to be alternative coolant guages on the market.
2.) I'm not positive but I think OBD1 ECU's had to deal with A/C too <wink...wink>
Remember I would not be using an OBD2 ECU I would be using a p28 OBD1 ECU. The d17 engine itself is not much different from the d16 engine. I would love to see a newly created uberdata basemap work on a d17.
Old Apr 27, 2004
Mirage's Avatar
uhhhh Yes, I would think so... Just factor in the cost.
uhhhh yes again. But the switch cluster on the dash does not simply have wires coming out the back of it that you can tap into. The A/C switch states are now carried through the new multiplex databus, not on discrete wires as in the past (2000 and earlier Civics). So if you wanted to have A/C you would have to figure out a new A/C switch which is not hard, it's just more work (especially if you want it to not look like ***) that you may not have counted on.
Old Apr 27, 2004
Mirage's Avatar
One more item. The D17A1/D17A2's have a different cam/crank tooth pattern than the earlier Hondas. At the very least, the trigger wheel on the cam gear would have to be modified to be the same as the OBD1/2 engines. You would have to check on the crank trigger & TDC trigger patterns as well.
Old Apr 27, 2004
Mirage's Avatar
Dont forget the distributor. The OBD1/OBD2 B/D/H series engines only had 1 coil output from the ECU so you would have to add a distributor. While that may sound like alot, it may actually be a good thing since the cam/crank/tdc sensors are inside the distibutor so you could get the proper engine position signals for the early Hondas. I dont know, can you mount a distributor on the D17's? the mounting boss is still there and the holes are tapped, just a rubber plug is installed where the dist goes intop the head?
Anyone know this?
Old Apr 27, 2004
Your Parts Guy
I've been reading up on the differences since I posted I'm not sure it's feasible to convert to OBD1 like they suggested. Based on what I've found and what Mirage is saying, it's going to be costly.
Good info Mirage.
Old Apr 27, 2004
Mirage's Avatar
I think it would be possible, but it would be alot of work. Unfortunately.
Still no good fuel/spark control options for the 7th gen...
Old Apr 29, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Our cars are obd3 I thought. If this is possible I'm not convinced yet that it would be easy to do
Old Apr 30, 2004
Nick's Avatar
Formerly 2blu
I don't think that obd3 has come out yet
Old Apr 30, 2004
I could be wrong, but if you want to find out the real answer to which version of on board diagnostics our 7th gens use, u might have to do some thorough searchin. I heard from someone, plus I know for a fact I read it in a swap thread somewhere that 5th gens= obd1, 6th gens=obd2 and 7th gens use obd3 unless that was a complete error and honda just continued to obd2 with a more complex set up.
Old Apr 30, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
I think it is. obd3, but again, I think.
Old Apr 30, 2004
Mirage's Avatar
Currently, the On Board Diagnostics (OBD) level is 2. OBD-3 is not finalized and there is no schedule for implementation yet.
Remember, the OBD rules are governmental requirements and have no direct coorelation with Honda's model releases.
Old Apr 30, 2004
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
with ob1, hondata will be really easy to install and make happen.
Old Apr 30, 2004
Ahh ha ok, so we are obd2 then....thanks for the correction
