custom turbo..What else do i need?
Old Apr 18, 2004
maxxam25's Avatar
maxxam25 is an unknown quantity at this point
Sup guys, I need help in completing my custom turbo kit. This is what I have...
1. Garret/Turbonetics T-3 Turbocharger
2. 1.7L Turbo manifold
3. Tial styl billet 35mm wastegate
Comes with extra flange for dump tube, 2 gaskets and all necesarry hardware
4. Mandrel bent 304 stainless steel and turbo pipes
Includes silicone couplings with clamps, nitril reducer and elbows
5. Turbo intake
3" polished intake tubing
6. Oil supply and drain kit
includes all necessary hardware & fittings
7. Stage 2 Blow off Valve
8. Stainless steel downpipe
Steel 5 bolt downpipe flange
Steel 2 bolt cat flange
extra items include, a vacuum line kit with T fittings
9. High flow front mount intercooler
10. Vortech FMU 12:1 ratio
11. 255 lph fuel pump
12. variable boost controller 0-30 psi
13. greddy full auto turbo timer
Does anyone have an instruction manual on installing this parts and help is very much appreciated. Thanks!!
Old Apr 19, 2004
Havok2k1's Avatar
Wicked Pissah Admin
You may not want to run a 12:1 FMU, you'll be running WAY rich... Try and 8:1......
Old Apr 19, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
and you don't need a Turbo timer... just a waste of money.. save the extra money from the turbo timer and ugrade somewhere else on ur turbo kit... just take the extra 30 second to wait in ur car while running or don't boost it for the last 1 minute or so of driving to ur final destination...
Old Apr 20, 2004
maxxam25's Avatar
thanks you guys...anymore suggestions?
Old Apr 20, 2004
Project2k2's Avatar
Although ur right about the waste of money....only if u use it for a turbo timer.
I.E. I am using a Apex-i Turbo Timer for the a/f ratio that way I can not just see it but tune it. It's 100% more accurate then a stupid gauge.
Old Apr 20, 2004
maxxam25's Avatar
how much is that Apex-i Turbo timer?
Old Apr 20, 2004
civicskater's Avatar
Chicks dig my scent
you can find it and the Greddy turbo timer for about 100 bucks
Mad Dog Tannen
Oct 19, 2016 08:12 PM
rallyeredem0
Nov 2, 2015 10:56 PM
carid
Sep 28, 2015 10:13 AM
General DIY
Sep 25, 2015 08:02 PM
Jrosa
Sep 14, 2015 08:24 PM
