DH Racing Head Installed!
Old Apr 7, 2004
  #31
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
Originally posted by nivenmk1
My 04' won't even crank if the immobilizser isn't working...
I stepped on one of my keys accidently and it popped in half... I removed the chip from the key then tried to start the car. When you turn it to start, it won't even turn over.
The 04's may be different for some reason, though.
your 04' is hardly different as far as the ignition goes, same immobilizer key system, if u dont push in your clutch alll the way it wont start, not pushing the brake it wont start, weird honda, smart theft deterrents though.
Old Apr 8, 2004
  #32
ImportRacer2123's Avatar
K20 Member
Well good news after 2 weeks of my car not running it finally runs.. bad news i need to replace my VTEC solenoid gasket and my valve cover gasket and then im good to go.
Old Apr 8, 2004
  #33
obguam's Avatar
obguam is an unknown quantity at this point
Excellent news, lotta peeps wanting to know if DH's P&P makes big gains.
Old Apr 8, 2004
  #34
nivenmk1's Avatar
nivenmk1 is an unknown quantity at this point
Yeah, didn't figure it was all that much different, hell, everything else on the car save the nose is the same as any other 01+ Yeah, I tried getting it to turn over with the chip out of the key, then tried moving the chip around holding it different distances from the steering column. Unless the chip is within about 8 inches of the ignition, it ain't gonna do nothin' for ya.
And yeah, honda's have always been problematic to start if you're used to some of the american rides that will start with the clutch out in neutral or in Park... Never fazed me though, as I'd only owned Toyotas up untill I got my Vic; Toyota's have about the same compliment of no-start crap on them...
Congrats on getting your car running, ImportRacer. What was the problem and how much did honda drag out of you to get it fixed? Lets hope some others don't have the same issue, being without a car for a goodly length of time would kill some of us
Old Apr 8, 2004
  #35
blue_dlb's Avatar
blue_dlb is an unknown quantity at this point
Hrmmmm something doesn't sound right here.
Old Apr 8, 2004
  #36
djmota's Avatar
glad to hear it runs now.
those gaskets are fairly easy to get to. What was the problem after all.
Old Apr 8, 2004
  #37
K20 Member
Timing.... they said it was 1/2 a tooth off... not sure if it was advanced or retard... they didn't tell me... well the reason i need a new valve cover gasket is because i pulled it about 10 times in 1 day trying to get it to start... and im just going to replace the VTEC O-ring just to make sure.
Old Apr 8, 2004
  #38
RiceBuRNeR's Avatar
Turbo Member
^ cool, cant wait to read about the results.
Old Apr 8, 2004
  #39
civicstreetrcr's Avatar
civicstreetrcr is an unknown quantity at this point
i just turned my car over finally and i have the same problem . so can i just take it to hond and tell them to adjust the timing???
Old Apr 9, 2004
  #40
K20 Member
yeah
Old Apr 9, 2004
  #41
how much $$?? and time do they take?
Old Apr 9, 2004
  #42
djmota's Avatar
or you could take the belt off again set it right and put it back on. no charge.
Old Apr 9, 2004
  #43
the problem is i did line everythng up right. the little red line on the bottom has to be lined up with the pointer on the bottom cover and the top has to be TDC. i did all that is it me or did everyone that has done this get alot of smoke the firrst few minutes you turn on the car
Old Apr 9, 2004
  #44
ponyman's Avatar
ponyman is on a distinguished road
^^^If I am not mistaking there will always be some smoke, for a short time, anytime you install new or reconditioned metal parts on the power train...this is because the machining oil will be burning off...that is pretty normal from what I have experienced
Old Apr 9, 2004
  #45
djmota's Avatar
uhh the tdc mark on the crank pulley is the WHITE line.
The white smoke will go away after a few minutes.
Old Apr 9, 2004
  #46
K20 Member
oh wow Thanks i could have saved $255
Old Apr 9, 2004
  #47
hey so the tdc on the bottm is the one that has 3 lines or the one part on the pulley that has a single line? still co0nfused because i lined it up in the middle of the three line together not to the single line
Old Apr 9, 2004
  #48
djmota's Avatar
the big white line on the crank pulley is the tdc mark. It is the one to the far right of the 3 other ones. If you got this wrong and then adjusted your valves you may have to do it again.... or at least I would double check them again.
Old Apr 9, 2004
  #49
SO WHATS THE RED LINE???JUST CURIOS CUZ I GOT IT RUNNING SMOOTHER BUT THE BOLT FOR CAM GEAR BROKE AND NOW I HAVE TO DRILL IT OUT.
Old Apr 9, 2004
  #50
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
Just take your car to a certified mechanic. No offence to your or anything but it sounds like you have yourself in a bit too deep. Some things are not for the ave. DIY'er.
~nick~
Old Apr 9, 2004
  #51
If he got the head swapped, I'd say that's better than most average diy'ers. Let us know when it's all working. Have you been able to drive it yet, of is it still turning off?
Old Apr 9, 2004
  #52
but it does not run lease:
~nick~
Old Apr 11, 2004
  #53
~nick~
dude questins is the way ... I appreciate all your help and YES i did get the car running yesterday saturday!!! Beleive me if im not confident i wouldnt do it just i have to be 100% so i asked.
by the way theres no way in hell i got 30 HP im satisfied from what i expected in results not from what i was told.
Old Apr 11, 2004
  #54
K20 Member
What all is done to your car besides the ported head.?
Old Apr 11, 2004
  #55
just cause youd rather shell out the $$ and probably never even changed your own oil doesnt mean I cant do my $hit.
MagicRacing18 dont judge me by your experience in modding i wouldnt start something i cant finish.
Old Apr 11, 2004
  #56
just the cylinder head & kamikaze header i wolnt lie though the engine sound great nice deep tone kinda like a mustang
Old Apr 11, 2004
  #57
next step is turbo....
oh yeah expect DYNOS this friday.
Old Apr 11, 2004
  #58
So did you notice a power difference? I know Josh was saying 30whp, but that seems way too high for ported head.
Old Apr 11, 2004
  #59
yeah the throttle response is better and you can feel the extra pull.plus it sounds real deep tone i have to change my exhaust back to stock or something similar cuz now its too loud.
You might get better results cuz you have a vtec and vafc
Old Apr 11, 2004
  #60
So I'm assuming you have an lx/dx with safcII? Cause you're gonna need some way to tune your air/fuel curve at the dyno. The head flows more air, so you need to up the fuel to get more of a gain I believe. I'm glad I just have a rear section exhaust. It's loud enough, but we'll see after this thing gets installed.
