were to put the intake air temp sensor
Old Mar 25, 2004
ramster's Avatar
ramster is an unknown quantity at this point
were to put the intake air temp sensor, befor or after the turbo??????
Old Mar 25, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
I think it should be before the turbo, somewere on the chargepipe before the throttle body. I could be wrong tho....
Old Mar 25, 2004
iamboo's Avatar
Retired - SoCal FI Mod
you are correct sir.... be sure that you don't make the hole too big for it... just enought for the rubber bushing to catch it and fit it snuggly...
Old Mar 25, 2004
ramster's Avatar
so he gonna reed the hot air from the turbo, not the air from outside, just to be sure
Old Mar 25, 2004
iamboo's Avatar
yes.... i've noticed that the car likes to stall and run pretty sluggish when the air temp sensor isn't in the charge pipe.. i had it hanging out and the car didn't like that...
Old Mar 25, 2004
ramster's Avatar
thanks a lot!!!
Old Mar 25, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
I pulled the sensor and put a resistor in the plu for the sensor. Taped it off and no problems or check engine light.. The car always thinks it has cool air coming in..
It works. Just search AIT sensor mod on google.
With this mod no need to run AIT sensor.
Old Mar 25, 2004
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
linkie for us fat and lazy people imp:
Old Mar 25, 2004
guns's Avatar
Skyline R33
This is for a Camaro but it is the same mod on my car.
http://www.installuniversity.com/ins...ricker_mod.htm
good luck. no check engine light.car thinks it is running on colder air and should run a little richer..
Any thoughts on this mod from others?
Input/Feedback please.
Old Mar 25, 2004
MadWheel's Avatar
Premium Boosted Member
That's a lil confusing, if it's before the turbo there isn't a charge pipe. and on a charge pipe before the TB is AFTER the turbo. I would think mounting it after the turbo near the TB is somewhat more accurate.
Old Mar 25, 2004
civic01vtec's Avatar
Old Mar 25, 2004
MadWheel's Avatar
You mah boy blue! haha
Old Mar 25, 2004
OMFG......that was my nickname in my fraternity, cuz i was the oldest out of the bunch and i have a slight hearing problem
Old Mar 25, 2004
MadWheel's Avatar
hahahah what are the oddds... oh well it's all good...
I'm actually bored tonight, I think I'll finally install the Intake AT sensor... Lol.. thanks ramster
Old Mar 25, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Air intake temp sensor needs to be after the turbo, as close to the throttle body as possible so that it reads the actual temperature of the air going into the engine. Before the turbo is almost as bad as not having it in the pipe at all, since the turbo and intercooler change the temperature so radically.
Old Mar 25, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Charger pipe is the one that goes from the intercooler to the throttle body. Which is of course is after the turbo.
Although, that's the reason all of my friend's turbo cars are running check engine lights. Because IAT is too warm. Seems even the intercooler isn't enough to cool it down.
Although I know for a fact earlier gens have a missing link that kills that or just an older computer that won't allow that type of code to be thrown. I'm not sure if we have anything like that..
Is there anyone on here that isn't running a check engine light with their setup?
Old Mar 25, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I never got a CEL for anything. Wait... once I did. Cuz the gas station guy left the gas cap a little loose lol.
Old Mar 25, 2004
MadWheel's Avatar
lol that'll do it...
Old Mar 25, 2004
Boosted2k2's Avatar
IAT placement on a FI car is a trade off between fuel and timing precision. By the TB is better for timing, before the turbo is better for fuel. If you have fuel/spark control, you can take care of either case.
Old Mar 25, 2004
I don't get what you are saying, could you explain?
Not flaming, but what do either of those have to do with IAT?
Old Mar 25, 2004
Boosted2k2's Avatar
What do you think the purpose of a IAT is?
Old Mar 25, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
dude...have a fitting welded onto the turbo manifold and then plug it into the fitting so that it will melt to the manifold create a secure bond and give you an acurate reading of 600+ degrees.....
Old Mar 25, 2004
MadWheel's Avatar
dunno if u were just plain makin fun or jokin around but either way lol...
I plan on putting mine right near the TB, as boosted said... I dont have timing control just fuel so putting it near the TB, then using the VAFC2 for tuning.
Old Mar 25, 2004
jwcardy's Avatar
yeah, i was jokin....i know that it was an honest but i had to say it
Old Mar 25, 2004
Boosted2k2's Avatar
The IAT has a purpose. It's not to just monitor intake air temperature for no purpose. What would be the point?
You have a MAP sensor that can read pressure, but not temperature. The MAP sensor ultimately controls the basis of the ECU's fuel map. But fuel is also dependent on temperature as well as pressure. There is more air in a colder charge than a hotter charge if both are read at the same pressure. Since the MAP only tells the pressure, something needs to be able to read that difference. The IAT does that. If the charge is colder, you'll need more fuel to efficiently combust it. If the charge is hotter, you'll need less fuel so you don't run overly rich.
That is what fuel has to do with the IAT.
As for ignition. A hotter charge is more likely to detonate than a colder charge. There are a bunch of sensor that work together to control the timing on this car. I'm sure we could throw the CPS and TPS in there. But ignition is also temperature dependent in a lot of cars. A lot of cars use the IAT for input in the timing.
The trade off I talked about is based on true temperature (throttle body) and intake temperature (before the turbo). Since the temperature before the turbo is generally a cooler temperature than the temperature at the throttle body, use the info above to see the tradeoff. If the temperature is cooler, more fuel is added. Hotter, fuel is taken away. (In most cases... I'd rather have more fuel than less) Depending on your fuel system... that might be the difference between running too lean, or running too rich. If it's reading the temp before the turbo, than it's cooler than at the TB (the true temperature), so the ECU would be changing the timing opposite what it should be if the IAT was before the turbo. That would make it more likely to cause detonation.
Surely I can't say that the IAT has any input on timing for our cars, but I can say that generally it does on most.
Old Mar 25, 2004
jwcardy's Avatar
guns...didnt you think that you blew a head gasket...could it be because of this mod and it did increase timing to much...and caused detonation....
boosted2k2- do you think that the increase of timing would be enough to cause detonation...
or did i totally miss understand what is being said here
Old Mar 25, 2004
bac7213's Avatar
bac7213 is an unknown quantity at this point
well i put it rigth on the air filter made a hole on it n poped it in, cuz its not good to put n e thing in the charge pipes, my opinion
Old Mar 25, 2004
MadWheel's Avatar
I just made a DIY to address this issue...
CLICK
Old Mar 25, 2004
Boosted2k2's Avatar
You understand. I doubt that the IAT would have that much control over the timing enough to do that. The cylinder pressure, fuel, and cylinder temperature could have caused it regardless. I just think of the IAT as a secondary sensor to help fine tune for conditions, not really overly control it.
Old Mar 26, 2004
Boosted --> Thanks for clearing that up..
