OK: Building Engine
Old Mar 20, 2004
MadWheel's Avatar
Premium Boosted Member
OK: Building Engine
After PWing in many threads I made the final decision. I am now looking for suggestions and personal opinions...
KMS Head Gasket
KMS Block Gaurd
JE Pistons (8.5:1)
Forged Eagle rods
Either Polk Performance or DH Racing PnP head
Does this sound good? I figure for the money it should be pretty reliable and handle a decent amount of boost.
I finally got my Apexi VAFC2 now, you think that with this setup, and upgraded injectors 15psi is a safe number? Thanks in advance.
BTW- Feel free to comment on what I went with, and/or make suggestions. I'm looking at an AEM cam gear is well to help cope with the thicker HG.
Old Mar 20, 2004
cambo's Avatar
I wish I was asian
have you seen ricerburner's PnP Headwork done by DH?
http://www.7thgencivic.com/forums/sh...hreadid=145271
looks very nice if you ask me.
Old Mar 20, 2004
MadWheel's Avatar
yes it looks pretty nice, Just dont think I can afford that kind of job, and still be able to upgrade the internals I NEED to run higher, safer boost...
Old Mar 20, 2004
Touge_Motors's Avatar
Touge_Motors is an unknown quantity at this point
You should be able to run 15-18psi safetly if tuned properly... I would watch out for our plastic intake manifold though... Not sure how much boost it can take at the end of the day...
Old Mar 20, 2004
C2i0v0i1C's Avatar
SuperMODrizd
u dont have to touch the head in order to run a lil higher boost, i did 14-15psi and i havent done anything to the head, i dont like block guards, and id go with polk
Old Mar 20, 2004
tfnaaf's Avatar
BLDNPSI Mod
just curious about the rods ive been looking around for info on who makes what but can never seem to get a reply from the manufactures and i work ALL the damn time it seems. Are the rods that your going with an off the shelf made for the d17 or are they a rod that fits our dimension requirements? if you have part numbers that would be very benifical and maybe a link to a site that has them listed? I'm thinking about building a second motor in the future and just want to get my ducks in a row.
Old Mar 20, 2004
C2i0v0i1C's Avatar
SuperMODrizd
ROD PART NUMBER
Old Mar 20, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Do they make all the parts to fully build our engine?
Rods, Retainers, Valves, Valve springs, Pistons, Rings, all that stuff?
Old Mar 20, 2004
RiceBuRNeR's Avatar
Turbo Member
I bought the KMS block guard. Its kinda flimsy comapred to one made by STR for a d16...I hope it holds up.
HEY C2i0v0i1C: Im not trying to start a brand name war Im just curious......but Why would you recomend polk over DH?
Old Mar 20, 2004
RiceBuRNeR's Avatar
Turbo Member
Oh and one more thing I called crower about thoose rods about a month ago and they said that they cannot be used w/ stock pistons. Not that I would upgrade one w/out the other but just trying to let everyone know.
Old Mar 20, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Where are you getting the JE pistons and the rods from? price? link?
I too have been doing a little research for internals but cant seem to make up my mind. Anyway, let us know how all this works out if you go ahead with it!
Old Mar 20, 2004
tfnaaf's Avatar
BLDNPSI Mod
The pistons madwheel went with are a dished piston correct? Im assuming to lower compression so that you can run higher boost? Has anyone run across an aftermarket piston thats equal to stock compression but more along the lines of being able to handle more boost/NoS ?
Old Mar 20, 2004
tfnaaf's Avatar
BLDNPSI Mod
Re: OK: Building Engine
KMS Head Gasket
KMS Block Gaurd
JE Pistons (8.5:1)
Forged Eagle rods
Why the thicker head gasket? I can understand how it would lower the compression ratio, but wouldnt it also increase the possibility of blowing the gasket out? I've read of people stacking head gaskets and i still dont understand why they would do that or what the realistic benift would be.
Im by no means a engine building god, but from what i have read and my understandings the items that you have selected sound like a good combination that should give you many years of service. From what i've been seeing recently it seems like a lot of head gasket failures on boosted and NoS cars. Maybe its just dumb luck. Is this the main failure that should be expected on a boosted / nos D17? And has anyone found a tried and proven solution to this issue? Im looking to build a LONG term reliable engine and i may go boosted but for the mean time im staying on the bottle until C.A.R.B. is passsed by someone on a turbo kit.
Old Mar 20, 2004
HondaLuver's Avatar
Its a celebration bitches!
any kind of FI is better with a lower compression ratio, any type of NA requires high CR
Old Mar 20, 2004
cambo's Avatar
I wish I was asian
Re: Re: OK: Building Engine
there are techincally like 2 schools of thoughts on head gaskets.
1. Some people want a thicker, stronger head gasket so that it wont blow and take their car out of service for a little while.
2. Some people like using OEM head gaskets. Why? Its usually the weakest link, which can be good and bad. Good that it'll blow before anything else, like a rod or the block. Bad that you might be replacing it a lot for no reason. It is A LOT easier to replace a head gasket than it is to replace a broken rod/piston, or fix a hole in the block.
Old Mar 20, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Joe, looks like you have covered pretty decently the basic stuff...
The only thing I would add would be a good set of piston rings. Talk to the piston manufacturer and see who they recommend for rings and ring gap on a high boost motor... Nothing is worst than building the motor up to handle 20 psi than having severe blowby and having to rebuild it all over again...
Also, make sure you use top quality bolt hardware... I use all ARP studs, but I know a member or two have had some bad experiences with them... I haven't though....
Good luck with it
Old Mar 20, 2004
MadWheel's Avatar
OK guys thanks for yoru responses... I am ordering my parts throughout the next few weeks and should have a built beast within a month or so...
I will let know you what I bought, how much, and my results including dyno numbers...
Old Mar 21, 2004
tfnaaf's Avatar
BLDNPSI Mod
i for one look forward to the info, good luck!
Old Mar 21, 2004
MadWheel's Avatar
thanks
OptimisticWay
27
Jul 6, 2015 12:56 PM
Aball93
May 16, 2015 10:11 AM
OptimisticWay
May 12, 2015 01:30 PM
cloudguy
Apr 28, 2015 05:02 AM
