How hard is it to swap a RSX Type R (k20a)
Old Mar 4, 2004
KYjerry414's Avatar
KYjerry414 is an unknown quantity at this point
I will soon have enough money to afford a K20A motor swap. I own a 2001 honda civic EX auto. How hard will it be to swap the transmission and the engine in my civic. I heard you have to use some of the RSX to make the engine fit. Will the transmission be easy to swap too? Do i have to replace the center console and odomoter after the manual transmission is in place? If anyone did the RSX Type R swap in their civic can you please send me the links. I'm really not that smart when it comes to motor swaps and auto to manual transmission swaps.
Old Mar 4, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Yeah.,....people are gonna tell u to search. There must be about 298739834638647366 threads about this stuff here.
Old Mar 4, 2004
Gecko's Avatar
^^agree.......
Old Mar 4, 2004
PunkingCivic's Avatar
I need TP for my bunghole
http://www.7thgencivic.com/forums/sh...32#post1832132
Old Mar 4, 2004
sspem2's Avatar
em2
1st 7thgen to have rsx r engine
Old Mar 4, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
^ holy sh*t, i want it. that things gotta move @ 25psi... how much whp does it crank out? gotta be close to 500 if not over right?
Old Mar 4, 2004
oh nm, i read the article, only 420 at 25 psi? i was thinking it would be quite a bit more, oh well still fast as h*ll.
Old Mar 5, 2004
bickford05's Avatar
bickford05 is an unknown quantity at this point
the swap wont be to bad, its going to take alot of work to swich from auto to the 6speed tho
Old Mar 5, 2004
Hawk's Avatar
You boost, I-VTEC
actually the auto to manaul conversion is not bad at all cause your taking the manual trans and computer from the RSX, the only thing you need to do is figure out how to mount the new pedals.
Hasports car started out as a auto.
Old Mar 5, 2004
actually, switching from auto to 6 speed wont be that much work since honda uses the same body for manuals and automatics. so all the holes are already there for the shift linkage etc... and theres also a spot for the clutch pedal inside the car, youlll just need to get all the mounting brackets. if you check under the wheel where the pedals connect you cant miss it.
Old Mar 5, 2004
KYjerry414's Avatar
thx for the info...sounds easy...when the transmission swap is done do i have to change the center console and the odometer since mine is an automatic..More than likely I will get a new tacometer that will read higher RPMS. Just wanna know if its necessary to change the odometer and center console.
Old Mar 5, 2004
odometer no but the speed it reads might be a little off due to change in tire size, but that would happen if you were to simply get bigger rims so not much you can do about it. and center console no, youll just need to get a manual shifter.
Old Mar 6, 2004
HondaLuver's Avatar
Its a celebration bitches!
^^ don't for get a new tach, something that goes past 8k
Old Mar 6, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
above 8,000 RPM is a good thing........
Old Mar 10, 2004
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
its the hardest thing ever
Old Mar 10, 2004
Hawk's Avatar
You boost, I-VTEC
8,000 rpm the thing sounds like its gonna blow up, it won't but it gets a tad loud
Old Mar 11, 2004
StLVtec's Avatar
StLVtec is an unknown quantity at this point
yeah i love shifting at 8 grand it sounds so nice going up there
Old Mar 15, 2004
joedc5's Avatar
joedc5 is an unknown quantity at this point
It's complicated very complicated unless you know exactly what to do step by step. Just look at my type-r Swap I think I metioned things in there. If you need help since I already did the swap email me at montuori@comcast.net and I will give you all the info to make your swap extremly quick and easy but for me it took 2months to get everything working right.
ClutchMasterOG
May 31, 2015 03:25 AM
em2_k20a
May 19, 2015 03:36 AM
TaiChi
Dec 17, 2001 09:09 PM
Ichiban
Nov 18, 2001 12:13 AM
Vtecpwr
Nov 11, 2001 10:17 PM
