what kinda oil for turbo d17
Old Feb 28, 2004
kikoman0's Avatar
kikoman0 is an unknown quantity at this point
Hey I'm wondering what kinda oil you guys are using for your d17 turbos. I'm using amsoil 5w-30 and i smell burning oil so i was wondering if it is too thin. On cold days I smell lots of burning oil and people say my exhaust gas is blue!? Please answer..thanks
Old Feb 28, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Re: what kinda oil for turbo d17
I am using mobil 1 synthetic 5w30 and its getting past the turbo seals. I am going to switch to 10w30 and see if it helps any.
Old Feb 28, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Ummm yeah. If you're smoke is blue...you're burning oil...chances are....it's most likely NOT the TYPE of oil you're using, but the fact that you're burning oil somewhere. My suggestion is to pop open your hood and try to identify the source of the burning oil. Could be gaskets, could be your turbo. If your bearings are bad and you're burning oil..you're gonna blow up soon.
I really hope you've been checking your oil level too. If you haven't please do. If you're burning oil...chances are your oil supply is low by now and you might wanna replace it till you can figure out whats wrong. Keep checking it otherwise...kaboom.
If you cant figure out what the problem is.....take ur car to a mechanic/shop quick.
Old Feb 29, 2004
rscivic's Avatar
rscivic is an unknown quantity at this point
I use 5w-30 w/ no problems.
Old Feb 29, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
yeh
check you seals if you can get a good look at them with out takin the turboo off and see if its leaking around there
ifyou pick up the Lastest TURBO magazine it can tell you everything
you might want to check
got mine a couple days ago
good luck
Old Feb 29, 2004
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
<<<====== mobil 1 synthetic 5w30..... no probs so far...
Old Feb 29, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
royal purple full synthetic, 10w-30
Old Feb 29, 2004
RiceBuRNeR's Avatar
Turbo Member
All boosted civics will burn a little oil. I use 10-30 valvoline synpower. A few people have said that regular oil might work better.
Old Feb 29, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
weird ... Catalyst suggested that 10w30 works best ... and definitely not to use synthetic .... ô_o
Old Feb 29, 2004
SpdRcrChk's Avatar
BOOST JUNKY
It's not the "type" oil that's the problem here guys, so your tellin him what "kind" you use isn't helpin' much. Everyone w/turbo should be FINE w/10w30 or 5w30.
He's obviously got a more serious problem when he's being told that there's blue smoke coming from the car. And if it doesn't get fixed...kaboom.
Just spoke to MikeDaRippa too.....if your car isn't tuned...that may also be ur problem.
Old Feb 29, 2004
RiceBuRNeR's Avatar
Turbo Member
My car always make a little puff of blue smoke when I floor it but all the seals are fine. Our oil controll rings werent ment for boost so like I said burning a little bit of oil is normal, but if its happening all the time then you have a problem.
Old Feb 29, 2004
C2i0v0i1C's Avatar
SuperMODrizd
castrol syntec 10w-40
Old Feb 29, 2004
kikoman0's Avatar
i don't get blue smoke all the time. It's usually only when its kinda cold. Someone was telling me that my 5w-30 might be to thin and it might be getting thru the pistons and burning....weird. And yes my car is untuned...maybe thats why =\
brags
46
Jan 7, 2016 09:39 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
hoofboy
Jul 17, 2015 04:27 PM
EliseKStewart
Jul 15, 2015 11:11 AM
jzhartman
Jul 9, 2015 04:56 PM
