need help
Old Feb 16, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
need help
i just installed my turbo, it has a serious oil leak, it is comin from the oil pan by the tranny, does this mean i need a new oil pan gasket? did you turbo dudes replace your oil gaskets when you installed your turbos?
Old Feb 16, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Re: need help
You need to use some sort of gasket maker to create a nice seal between the pan and the block. When dealing with oil related things take your time and think it out, I'm sure you don't want to buy another d17 because you forgot to use gasket maker.
Old Feb 16, 2004
Quiksilver09's Avatar
Quiksilver09 is an unknown quantity at this point
It would probably be a good idea for you to replace the gasket seing as how they are relatively inexpensive and seal it really well with Honda bond or something similar.
-Nic
dober as a side note how's your profec working now?
Old Feb 16, 2004
Your Parts Guy
-Nic
The Profec is working much better now thanks to your tuning suggestions. It is a very stable unit and I am glad that I purchased it. If anybody needs help with settings talk to Quiksilver09!!!!
