electronic oil pressure gauge
Do any of you guys have a electronic oil pressure gauge? If so how did you hook it up? Is it some how attatched to the sender? If so how is it attached to the sender?? What hardware did you use? ect ect ect. . .. ..
there is a diy on installing oil pressure gauges. you will need to buy a few fittings and some length of oil line. or you could just screw the sender into the block and not hook up the idiot light.
i got it working, i got a few t fitting and a small pipe from the local hardware store and it works, so now i have oil to the turbo, oil gauge and the stock sensor
Xuhme
21
Aug 7, 2023 03:40 PM
jbander
Jun 4, 2015 05:56 PM
jmythngdmb
Jan 24, 2002 03:10 PM
