gauges and exhaust gas temperature
Old Jan 19, 2004
kikoman0's Avatar
kikoman0 is an unknown quantity at this point
i'm wondering what kind of gauges you guys have for your turbo and what do you consider normal exhaust gas temperature with turbo?
Old Jan 19, 2004
trashguy's Avatar
trashguy is an unknown quantity at this point
Man i did all this research on fuel injection (Bosh has osme books out good price with good information. They own the rights and hardware to ALL fuel injection systems) I recall if you have the perfect stoichometric ratign of 14.7 Kg of air to 1kg of fuel you are roughly around 500c Im not sure 100% i will research it again when i get home from work.
Old Jan 19, 2004
civic01vtec's Avatar
boost, a/f and water temp.......i prolly should have gotten oil pressure instead of water temp.
Old Jan 19, 2004
trashguy's Avatar
Air fuel is a MUST if you do not wanna burn holes in your pistons or do other nasty ****... Normal operation you want to be running at 14.7: 1 Air fuel ratio. High performance applications is 12:1 air fuel ratio.
Exhaust temp is another good precaution to burning holes in your pistons.
Boost gage is standard If you are really bad *** invest in an absolute pressure gage. Vacuum really does not exists. You have lower the Atmospheric pressure.
At sea level Atmospheric pressure is 14.7 PSI which should be 0 on your boost gage. Most people live well above sea level, and if you want to see really how much your motor is boosting then get a Absolute pressure boost gage. (FYI: 1 BAR = 14.7 PSI = 1 Atmosphere)
Oil pressure is another must. You wouldn't want oil system failure and have pressure drop to your turbo and then have the shaft seize at 100,000 rpms. I haven't really ever seen this but it is another good precaution to protect your investment.
Old Jan 20, 2004
kikoman0's Avatar
alright thanks for the info. Am I gonna need an air fuel gauge AND exhaust gas temp?
Old Jan 20, 2004
Quiksilver09's Avatar
Quiksilver09 is an unknown quantity at this point
actually a/f ratio is only good if you have a wideband O2 sensor. Other wise it's just for looks because it does not measure the ratio correctly.
If it were me I would go with boost, oil pressure, and then probably oil temp, or water temp. EGT is nice but they have also been known to be inacurate.
-Nic
civic98?
Jun 27, 2015 06:02 PM
Bruce.Ringler
Jun 18, 2015 08:12 AM
Rushfan1
May 6, 2015 01:20 PM
tylerginevan
Apr 27, 2015 12:29 PM
aultman1990
Apr 19, 2015 07:14 AM
