SF turbo install...Problems with idling - Please Help
Old Dec 21, 2003
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Installed everything on the turbo. When i first start the car, it idles around 1500 to 1800. then when i rev it drops back down to 2500 and stays there. it continues to idle at 2500. does anyone know why or how to fix this??? its the last problem i need to fix!
Old Dec 21, 2003
civic01vtec's Avatar
sorry i can't help u and this is OT....but when did u get ur kit ?
Old Dec 21, 2003
Your Parts Guy
ordered on august 27th got my complete kit a week ago.
Old Dec 21, 2003
cool, i heard that the kits were done and they were waiting on turbos. That means that mine will be here very soon.
free bumb for ya
Old Dec 21, 2003
Samari's Avatar
its not the turbo. this is a known problem with our civics. go to the issues section. mine did it for like 3 weeks and corrected itself somehow and stopped doing it.
Old Dec 21, 2003
Your Parts Guy
sorry man it has to be a vacuum line or something because it didnt start doing this until after i installed the kit.
Old Dec 21, 2003
Elite's Avatar
Elite is an unknown quantity at this point
have u tried resetting your ecu?
Old Dec 21, 2003
maxsin's Avatar
No Title
maxsin is an unknown quantity at this point
This will sound like a newb answer.....
did you try checking your throttle cable?
Old Dec 22, 2003
C2i0v0i1C's Avatar
SuperMODrizd
could be a air bubble or something in the vaccum, otherwise, mine does the same thing when its cold, but it stops after its warm, does urs ever stop, if ur never going below 1800, ur throttle cable could be a lil too tight
Old Dec 22, 2003
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
yeah, adjust that cable. may have gotten jacked around during the install. only takes a sec,
Old Dec 22, 2003
dKj's Avatar
dKj
dKj is an unknown quantity at this point
my car duz that too, and i havent gotten my turbo yet. but only in the morning when its hella cold, but it goes away after engine warms up a bit.
Old Dec 22, 2003
Your Parts Guy
Thanks for the replies. The throttle cable seems to be fine in fact there is alot of slack in it. That is one of the first things I checked. Also, it idles at 2000 rpm all the time and never goes down after warming up. Even when i rev it to 4000 rpm it comes back down to 2000 rpm and stays there.
I will check the vacuum lines one more time. Could the map sensor have anything to do with this?
Old Dec 22, 2003
rscivic's Avatar
rscivic is an unknown quantity at this point
Look for the post from someone (forgot who) awhile ago on correctly resetting idle. I had been just unplugging and plugging in but there is more to it - giving the car gas for a while @ a certain rpm and what not.
Yeah I just looked in my files again and could not find it- can't hurt to try- I had an idle prob @ first but it was the opposite- too low @ around 500rpm and then would stall- fixed it.
Never had throttle cable trouble but check it out too- us past installers are a wealth of info imo....
Old Dec 22, 2003
MadWheel's Avatar
Premium Boosted Member
Cprob Map sensor. That's what my prob was. Make sure it's sealed REALLY well. I have the SF kit too. You need to jam the map sensor down for it to work right. I supposed resetting your ECU won't hurt, but, when you reset it it will naturally idle higher than normal becuase it has to relearn fuel maps.
To reset, in case you're not sure, leave a door open to speed up the process. Use a 10mm and loosen the negative terminal. Pull the terminal off and wait at least 10 sec AFTER the interior lights die out. GL, it fixed my problem.
Old Dec 22, 2003
Your Parts Guy
Ok I will reinstall the map sensor isolation valve and reset the ecu tonight. Did you have a high idle when you first started it up? I drove it a bit and it came down to like 1800 but thats still too high.
Old Dec 22, 2003
rscivic's Avatar
You should usually have higher idle in most cars when you first start it up. Then after it is warmed up it will "kick down" to where your normal idle is- do you have auto or man? There is a diff b/w the idle of auto and man- I owned both, my auto idled higher (over 1000) and now my man idles @ about 750 when warm...
Old Dec 22, 2003
Your Parts Guy
I have manual tranny. my car used to idle around 1k but now its at 2k after installing the turbo believe me it is not normal.
edit: it never "kicks down" it stays at 2k all the time
Old Dec 22, 2003
rscivic's Avatar
I am not sure then-
sounds like a too much fuel issue or something, maybe throttle cable like they said-
Not sure but once everything is fixed you will be happy w/ the turbo I am!
Keep us updated on what you find out
Melissa
Old Dec 22, 2003
Your Parts Guy
It drives normal ya know it makes boost and everything so I'm not completely bummed but I would really like to fix the idle. Where is Catayst????? lol
Old Dec 22, 2003
sspem2's Avatar
em2
sup jeff.
you finally got your turbo. man im gettin mine in april. we need to hook up man. i wanna sit in your car and hear the turbo and see how it pulls. maybe i can drive it to. hehehehe. havent heard from you in a longgggggg time.
Old Dec 22, 2003
Your Parts Guy
hey man i gotta get this thing running right first.
alright so i finally get the thing to idle around 1000 rpms and then when i rev it it shoots up to 2000 rpms and then the idle bounces around in a looping manner. i can mess with the map sensor and get different results. the vacuum lines arent leaking i clamped them down tightly. anyone have any clue what i should do?? im very close to buying a missing link from synapse engineering.
Old Dec 22, 2003
C2i0v0i1C's Avatar
SuperMODrizd
does anyone or can anyone post a pict of the SF MAP isolation valve or whatever its called
^^^ now this is a good idea
i have one
Old Dec 23, 2003
MadWheel's Avatar
drive it for a while, it'll slowly drop down, takes about a couple days...
i idle at about 750-760 rpms (HKS digital readout)
Old Dec 23, 2003
MadWheel's Avatar
Keep messing with the MAP sensor. It took me 2 days to get it perfect. I made my own lil rubber seal that worked better than what SF sent me.
Old Dec 23, 2003
Your Parts Guy
i have one
Im pricing one right now. It's on the group buy center for 60 for the d17.
Old Dec 23, 2003
Your Parts Guy
did yours idle around 2k rpms even after you rev it?
Old Dec 23, 2003
Your Parts Guy
what would happen when it wasnt perfect? any way you can describe the rubber seal you made?
Old Dec 23, 2003
rscivic's Avatar
maybe the bleeder valve is on upside down? check the DIY section on turbo install or just call mike directly he is very good over the phone and has helped me out with my install
Old Dec 23, 2003
Your Parts Guy
the white part of the isolation valve is pointing down like it should.
Old Dec 23, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
if they are using the same setup they have been i cut a piece of that hose they sent and tapered it down with my knife so it would fight TIGHTLY in the hole for the stock map sensor
worked ok for awhile...
later on i got some strange idling problems...like sometimes it acted like it wanted to stall...i ended up getting the synapse engineering map sensor bypass valve (made for d17's and k20's, same part) and i havnt had a problem since...
