boost controller, good or bad?
Old Dec 14, 2003
dKj's Avatar
dKj
dKj is an unknown quantity at this point
anyone ever heard of the hallman evolution boost controllers?
i was lookin around, and cudnt find anything about it. its sum kind of manual boost contrroller, but u can control it with a **** from inside the car. i cudnt really find anything about it.
link
sounds kinda kool cuz u can change it from inside the car, but i dunno if it works well or wutevr, but its cheaper than a electronic boost controller.
Old Dec 14, 2003
opto_isolator's Avatar
Yeah, I've seen those - nice, but pricey! Depends I guess on which look you are going for.....Those have cables which run from your wastegate to the cabin, vs an electronic controller's wiring. Supposed to be more accurate than an electronic boost controller.
Old Dec 14, 2003
dKj's Avatar
dKj
at least cheaper than electronic boost controllers, and its easier to hide too. i mite end up getting this then
Old Dec 14, 2003
civic01vtec's Avatar
i just bought ohmysac's MBC for $35 shipped. It would be nice to control it from the drivers seat, but kinda pricey.
Old Dec 14, 2003
C2i0v0i1C's Avatar
SuperMODrizd
but u could seriously get urslef into trouble with that by not know if someone turns the ****, if it gets turned too high and u dont know BOOM
Old Dec 14, 2003
dKj's Avatar
dKj
yea, and so i was thinking of putting it on the left of the steering column hidden somewhere so noone can touch it. and also the **** looks kinda ugly, but its all good if its hidden as long as it works.
Old Dec 14, 2003
C2i0v0i1C's Avatar
SuperMODrizd
if thats what u like, i personally like all the lights and the movement of numbers, and stuff that i can watch as i drive, besides the road
Old Dec 15, 2003
mndthegap1's Avatar
see i have a similiar question. is it better to get a manual or electric boost controller ? i mean ive heard the manuall ones are better more reliable, is this true ?
and as for the hallman i saw the es on ebay for 65 if your interested.
Old Dec 15, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
manual ones are nice cause they are set then DONE... as long as they dont lose setting over time due to coming loose??? ive heard it can happen.. im selling mine (turbo XS manual, $80 shipped).. like new if anyone wants it... im fine with one setting till i can afford the profecBspec ver. 2... nicetst and most relable boost controll on market imp, just its $300.. LOL... let me know if anyone interested...
Old Dec 15, 2003
Quiksilver09's Avatar
Quiksilver09 is an unknown quantity at this point
You'll be happier with an electronic. Although some people feel the manual is more reliable I don't feel that's the case. If you know your electronic controller it's more reliable. The only thing that could go wrong aside from total unit failure is that the solenoid could go bad, but most controllers have a default that if it detects the failure of the solenoid it will open the WG.
The profec B spec 2 is great I have it on my 7. Very easy to use. If it's too pricey for you and you don't want the light up display get the original profec B. These are nice because you've got two boost settings (hi and lo), you've got a gain function to control how fast your boost comes on. The only units that have more features would be the blitz and the Apex which both allow you to program boost gain per rpm and boost level per rpm. Those features aren't really worth the extra 300 bucks to me though.
-Nic
Old Dec 15, 2003
XxJDMCivicxX's Avatar
Anyone have any info on boost controllers that work on individual gears so you can have different boost settings in each gear? I know theyre pricey but anyone have any info on them?
Old Dec 15, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
AVC-R.
Old Dec 15, 2003
the AVC-R is like 500 bucks
Old Dec 15, 2003
C2i0v0i1C's Avatar
SuperMODrizd
but it does the trick , i had the gear judge going at one time
Old Dec 15, 2003
avc-r will do it as well as the blitz sbc. Both are nice units, pricey but nice if you feel that's something you need.
-Nic
Old Dec 15, 2003
avc-r and blitz units are both VERY nice.. but in numerous tests tehy had boost spikes and problems holing correct boost... profec speb B has tested mosdt reliable time and time again... 2 stages of boost is most controll for most people.. plus you can get the steering wheel switch top activate second boost so you dont need to hit a little button... VERY nice unit, never heard anyone that had it complain...
Old Dec 17, 2003
they only thing you have to watch with the profec b spec 2 is that if you have it set to read in psi the warning will come on a full 2 psi befor your set warning. IE if you set your boost at 8 and set your warning at like 8.5 then at 6.5 the warning will hit and ramp down the boost. In bars it will not do this. That may have been fixed by now.
-Nic
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
Tybonater
Apr 24, 2015 07:03 PM
dooner24
Apr 14, 2015 07:51 PM
