Dream Turbo Setup
Old Nov 18, 2003
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Dream Turbo Setup
Hi,
Based of the SF Turbo kit, what else would you put in your car to have a top of the line setup?
SF Upgrade Options?
Internals? ........ Pistons/Rods/Block ????
Gauges/Boost controller/Turbo timer/Ignition/Plugs/ECU ????
Clutch/Flywheel/LSD/Suspension ????
If you have a $ 5000 Budget for all this, how would you go about it?
Old Nov 18, 2003
C2i0v0i1C's Avatar
SuperMODrizd
5000 bucks wont get u all that much
3100 for sf kit
pistons 500
rods 500
block 1000
right there thats 5100 and u dont have it put on ur car yet
Old Nov 18, 2003
paolomonroe's Avatar
paolomonroe is an unknown quantity at this point
Dont forget bout da labor..thats gonna be a beeoootcchhhhh
Old Nov 18, 2003
C2i0v0i1C's Avatar
SuperMODrizd
that was my interpretation of labor
Old Nov 18, 2003
Ahtasham's Avatar
Yeah Labor charges in America are VERY high. Fortunately, where I live (Pakistan), Labor charges is the last thing we think of. Normally what we pay here for an engine overhaul is like $50 or $100 tops if its a big engine. So no worry there !!!
So lets say excluding Labor charges and also the $1000 block, wat else would one go for?
Old Nov 18, 2003
chrisgushue's Avatar
Bring Hockey Back!
chrisgushue is an unknown quantity at this point
youd need new breaks, clutch, flywheels, boost controller or e-manage, gauges thats prolly 2000 right there
Old Nov 20, 2003
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
brakes**
doesn't have too cost that much..shoop around
:cough; Ebay:cough;
manual or electric boost controller..( kinida optional)
clutch is a must
light flywheel would be hella nice ( less rotational mass just like wheels along with pulleys)
emange is you have the funds... AFC and bigger injectors on a budget.
my $.02
Old Nov 20, 2003
C2i0v0i1C's Avatar
SuperMODrizd
new brakes are not all that necessary to get a turbo up and running
boost controller i do find necessary (electric)
clutch is a must a stock one will go shortly after install of turbo
flywheel is not necessary
some sort of fuel management, emanage is excellent
the AFCs are ok but dont give u as many options as the emanage
if ur cost cutting u dont really have to have any guages as long as u have an electric boost controller to tell ur boost
turbo timer u dont have to have just sit there and let the car cool down before shutting it off
ignition, just leave alone, ignition solutions makes something, just get colder spark plugs 15-18 for a set of ngk
ECU just leave it alone
dont worry about LSD
or suspension if on budget
ull need exhaust fo sho
Old Nov 21, 2003
prototype's Avatar
x-factor
Originally posted by Speedracer32
clutch is a must
what about for us auto guys?
Old Nov 21, 2003
robbclark1's Avatar
Retired suspension supermod.
if you have an auto you need a torque converter or it will fry
Old Nov 23, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
I just finished my dream turbo system.......
Name:	civic front.jpg
Old Nov 23, 2003
Catalyst's Avatar
Stainless equal length manifold
Custom T3 w/ 56mm compressor wheel
Candy Blue powdercoated piping
31" core intercooler
3" cold air intake (to turbo)
Polished alcohol injection canister
Jettable Alcohol injection
Dual stage boost controller
3" downpipe
Turbo xs RFL bov
I see 7 psi at 2300 rpm with this setup. The compressor/exhaust combonation is INSANE! there are only 3 of these turbos in existence, and we have all of them! They are custom made just for us.
Old Nov 23, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
now that is some quick spoolup...what kinda dual boost controller setup do you have
Old Nov 24, 2003
Catalyst's Avatar
no dual controller, only the "ohmysac controller". It works great.
Old Nov 24, 2003
ohmysac's Avatar
haha sweet plug..thanks man
Old Nov 27, 2003
ohmysac's Avatar
i'm thinking of making a dual stage controller using two of my base boost controller...think theres a market for that?
Old Nov 27, 2003
civic01vtec's Avatar
wait.....u make boost controllers ?
more info please
Old Nov 28, 2003
ohmysac's Avatar
pm me for more info
Zygrene
Mar 22, 2016 12:36 PM
HondaGuy7
Feb 22, 2016 01:00 PM
