Anyone happen to get the E-Manage ignition harness working yet?
Old Oct 29, 2003
opto_isolator's Avatar
I am curious to know if anyone who has the E-Manage has gotten the ignition harness working yet?
Old Oct 29, 2003
wannabeblown's Avatar
wannabeblown is an unknown quantity at this point
A friend and I installed it on an RSX-S and it works with no problems. My harness came in the mail last friday and will probably install it on saturday, i'll let you know how the wiring goes.
Old Oct 29, 2003
I'd like to see if it actually controls ignition timing - it would make it easy to fix problems up top....
Old Oct 30, 2003
C2i0v0i1C's Avatar
SuperMODrizd
yes
Old Oct 30, 2003
MadWheel's Avatar
Premium Boosted Member
Boosted2k2 has it. Works great on his car from what he tells me. I'm sure he'll see this post and inform you all.
Old Oct 30, 2003
C2i0v0i1C's Avatar
SuperMODrizd
i dont think boosted is in need of it right now, he might have it workin, but at 5 psi not really in need of it yet, i might be wrong though
Old Oct 31, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
That is... CORRECT. I have all harnesses hooked to the e-manage. The stock ECU can control 5psi worth. The stock injectors suck though. But I have no need at 5psi to change the ignition. But the fact that the ignition control works on the emanage is true. I'll be using it by december along with new injectors to complete everything for 9-10psi. The E-manage as a whole is still perfect IMO for cost and tunability.
Old Oct 31, 2003
That's my thoughts too! With the proper ignition timing control you shouldn't need alcohol injection at 10 PSI or so, just retard the timing a little up top and your good to go.
I don't like alcohol injection as much because you are not 100% certain that the alcohol is mixing completely with the air - which means that some cylinders may not be getting any, which means those cylinders could be detonating.....
You guys just sold me on the E-manage, I'm going to buy one - but I need some more info. Where did you all find wiring info for our cars? I have the helm manual, but I'm not sure if it would be a big help.
Old Oct 31, 2003
C2i0v0i1C's Avatar
SuperMODrizd
as long as u have the ecu pin out sheet, and the instructions for the emanage, just connect the wires accordingly i think, i have a big thick green book that has everything about the car in it, im also up to 13psi with the timing retard
Old Oct 31, 2003
WOW! 13 PSI? So far nothing wrong? Did you have your car tuned by someone or did you do it yourself?
Old Oct 31, 2003
The E-manage is simply amazing for the money. I got mine for $270 shipped, got the ignition and injector harnesses local for $45 + tax. The installation is easy with the nice bullet connectors that are supplied. I can't wait to try it out on my sub injector setup.
Old Oct 31, 2003
Boosted2k2's Avatar
I was going to make an E-manage DIY, but nobody else was using it so I didn't. But I'll make up a wiring diagram for it in a couple hours:
E-manage
Ignition Harness
Injector Harness
Rotary Settings
Old Oct 31, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
E-manage
Ignition Harness
Injector Harness
Rotary Settings
yo can i use the emange and not hook it up to the intectors..and just have my SF PFM do the fuel work?
Old Oct 31, 2003
C2i0v0i1C's Avatar
SuperMODrizd
no some one else did it, if i could do it i would save alot of money from the begining, i wish i could do it, i dont have the time to do it, with school and work, nothing wrong to bad, it over heats everynow and then but thats being fixed too, might do a fluidyne, i know they dont make one for our cars, but im going to SEMA tues wed and thurs, im leaving in the morn for VEGAS, and trust me they are on my list of people to talk to, otherwise, ill just make an existing one the make fit, just like everything else on my car practically
Old Oct 31, 2003
C2i0v0i1C's Avatar
SuperMODrizd
no some one else did it, if i could do it i would save alot of money from the begining, i wish i could do it, i dont have the time to do it, with school and work, nothing wrong to bad, it over heats everynow and then but thats being fixed too, might do a fluidyne, i know they dont make one for our cars, but im going to SEMA tues wed and thurs, im leaving in the morn for VEGAS, and trust me they are on my list of people to talk to, otherwise, ill just make an existing one they make fit, just like everything else on my car practically
Old Oct 31, 2003
C2i0v0i1C's Avatar
SuperMODrizd
i dont know WTF happened there
Old Nov 18, 2003
ccajun4real's Avatar
ccajun4real is an unknown quantity at this point
OsOBooSTed did you ever sell that body kit? If not I am interested and tried to PM you but your box is full and cant send you an email from this forum. Please contact me at ccajun4real@nc.rr.com. Thanks and sorry about jacking the thread guys
Old Nov 18, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
so with the e-manage if we retard the ignition timing we can run higher boost without using the alcohol injection? what all is needed to run 10 or more psi?
Old Nov 18, 2003
Theoretically yes - but you must be careful. Each car is different, and will need to be tuned differently. Remember also that you'll be approaching the limit of the head gasket as well.....
Old Nov 19, 2003
so what needs to be done to safely run 10 psi?
Old Nov 19, 2003
The E-Manage will need to be tuned.....You need to have the right fuel ratio, plus the proper ignition retard to prevent knocking. Once you have these you should be golden....
This is why tuning can be tricky, and also why you go a little at a time, making small adjustments - such as bumping boost by 1 PSI (if even that) increments when you get above 8 or so.
Old Nov 19, 2003
Damn i need to find somewhere in virginia i can get tuning
Old Nov 19, 2003
There is a place here in Greensboro, NC that does dyno tuning on imports. You are up by Fort Lee right? It would be about 3 hours straight down the interstate for you. If you are interested email me at ccajun4real@nc.rr.com and I will send you the link.
Old Nov 19, 2003
C2i0v0i1C's Avatar
SuperMODrizd
(GReddy Dealers listed in alphabetical order by city)
Evolution Autosports
13903 Metrotech Drive
Chantilly, VA 20151
(703) 961-9090
CDE Motorsport
8438 Lee Highway
Fairfax, VA 22031
(703) 560-9090
Autothority
3769-A Pickett Rd
Fairfax, VA 22031
(703) 323-6000
Vertex Motorsports
1524-F Spring Hill Rd.
McLean, VA 22102
(703) 883-0403
Intersport Perf. Acces.
1524 Spring Hill Rd. Unit H,S
Mclean, VA 22102
(703) 242-8680
In-Line Perf. Products
7958 B Cameron Brown CT
Springfield, VA 22153
(703) 644-1788
Performance Auto Salon
2428 Virginia Bch. Blvd. Suite 102
Virginia Beach, VA 23454
(757) 431-8848
from website, all these should be able to tune emanage
Old Nov 19, 2003
thanks a lot guys
ccajun i now live in Richmond so it will probably be shorter
Old Nov 19, 2003
Richmond.........hell yeah Shocco bottom (?spelling), that is the sh*t!
Old Nov 19, 2003
yeah man its awesome
Old Nov 19, 2003
Much *ss up there. My friend lives in Colonial Heights there by Fort Lee and I have spent a bit of time up at FT. Lee going to military schools. Always find a couple of honeys to keep me busy during my off time though.................lol...........Oh sh*t that was before I got married. lol
Old Nov 19, 2003
Jaykuai's Avatar
ish...
is a dyno completely needed?
there are no dynos around here.. i mean.. if there is a way you can tune it yourseld?
Old Nov 19, 2003
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
The dyno will show you if hp or torque drops off at a certain point and you will be able to fix it with tuning....so yes it's necessary
