400 shot on a 350z?? video inside...
Old Oct 2, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
vid...
http://www.crownvic.us/movies/350z.wmv
Old Oct 2, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
holy ****... holes on both sides.... damn it was MOVING BEFORE IT BLEW TOO!
Old Oct 2, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
wow....that guy is a certified class A idiot.
Old Oct 2, 2003
zinkyroo's Avatar
cool beans
lol
Old Oct 2, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yea but whats funny is that they were like ' oh well '
Old Oct 2, 2003
zinkyroo's Avatar
cool beans
more money than brains...
Old Oct 2, 2003
civicvtec1ps's Avatar
Search and Learn
http://www.7thgencivic.com/forums/sh...hreadid=117771
he had good launch though.
Old Oct 2, 2003
zinkyroo's Avatar
cool beans
oops sorry
Old Oct 2, 2003
gotti's Avatar
lol, excellent.
Old Oct 2, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
how do you know what shot he was running? if it was indeed a 400 shot, he should be castrated
Old Oct 2, 2003
littlePman's Avatar
Me fail English? That's unpossible.
littlePman will become famous soon enoughlittlePman will become famous soon enough
OWN3D!!!!
hahaha "this is half of the connecting rod there should be a piston here" "oh **** where did you find that?" "lying in the track". lol
that launch was crazy though.
Old Oct 2, 2003
Deceit's Avatar
Deceit is an unknown quantity at this point
it was a 300 shot.. i've seen a vid of him running 11 something with a 250 shot
Old Oct 2, 2003
C2i0v0i1C's Avatar
SuperMODrizd
holy FFFFFFFFFFFFFFFFfffff......... that kid was proud of that all smiling and stuff, if i blew a rod out the side of the block and into the track i would be pissed like no other , not to mention shatter a piston so they think, that hole in the block was like the size of a fist
Old Oct 2, 2003
Deceit's Avatar
Straight from the 3fitty forums, it was a 375 (my bad)
http://www.my350z.com/forum/showthr...08&pagenumber=1
If you don't have an account:
hey everyone this is Andrew Rubio from Performance Motorsport.
first things first the things that did work:
got the full length headers from XERD. a very nice product that fit extremely well and actually kept the engine compartment noticeably cooler.
got the nismo cams in time also. a nice slighty lopey idle and a definite increase in response althouth a chore to put in.
while we were putting in the cams we decided to freshen the engine and put in new main and connecting rod bearings and new piston rings. but we left all other components stock; ie. pistons, con-rods, crankshaft, heads.
we also upped the shot on the direct port system to a 300 knowing that the engine could at least take that much from previous experience since we has a combined shot of 300 between both stages.
finally the runs.
first run off the truck was the 11.3 at 119. second run was an 11.4 at 118 but then we began to have problems with the nitrous controller. we're still trying to isloate them but as yet have been unable to ascertain the cause of the problem. we ran maybe 6 more runs with the nitrous cutting on and off the whole run and we were still running high 12. this was all without the 2nd stage by the way.
finally on sunday still not able to fix the problem with the controller we threw in a spare relay we had with us and wired the direct port system to come on with the button we used for the 2nd stage. so that meant that the full 375 shot would come on instantly. burnout, staged, light went green and you guys saw the video so u know what happened next. it launched like a saturn V rocket and had a combo of clutch and tire slip all through 2nd gear and when i looked down the tack said 7800 hehe. so i shifted into third, it hooked up finally and boom. i heard and felt something go clunk a bunch of times in the engine, followed shortly by a pop and the hood jumped about 6 or 8 inches up as the nitrous caused it to backfire pretty seriously. i pulled off to the side of the track figured out i wasn't really burnin and waited for the track guys to show up.
now for what failed,
now i know everyone says that the rods are the weak point in the VQ and in forced induction application that may very well be the case. but in a nitrous only application like we're running it's most definitely the pistons. 5 of the 6 pistons we broken into pieces, some large some small, and once the pistons broke i think u can figure out what happened next with the con rods. otherwise the con rods or what was left of them still spun on the crank and the crunk still spun in the mains. none of the main bearings pulled, the bolts were still tourqued correctly and the main bearings were so good we're keeping them as spares.
as to what it can take.
from our experience the engine is very tough and can take a 300 shot either staged or direct port. the other thing is that even though we weren't really using the progressive on the controller it still softenend the hit a little bit which seems to make it hold together. now im not saying that if u run a 300 shot on a street car it's not gonna break. but for a weekend or track application she seems like she can take it.
now for my last comment.
i know there are alot of you who have been following and supporting us here on this forum and to all of you i would like to say thank you, your support is much appreciated. what happened happens when you push to be faster and be number one. it's what racing is all about and when you are on the ragged edge sometimes you end up over it and something like this happens. it sucks we lost an engine but hopefully now you all may use this to your advantage and apply it to your own cars and not say i told you so.
i think that's it, if there's anything else let me know and i'll do the best i can.
thanks again
Andrew Rubio
Old Oct 2, 2003
MadWheel's Avatar
Premium Boosted Member
damn that kid was young too
Old Oct 2, 2003
7thgen Man-gina
so you could go buy a 350z, and immediately bolt a 300 shot to it "relatively safely" or whatever he said? ****, id be happy running a 200 shot, can you imagine running a 200 shot on a stock engine and it being safe.
Old Oct 2, 2003
Deceit's Avatar
those z's are built tough.
i've seen quite a few drifting too, quite wrecklessly.
either 350z owners are psychotic or the cars can just handle it.. maybe a combo of both
Old Oct 3, 2003
JCiv03's Avatar
DAYM! a 400 shot?!? crazy
alaga
25
Aug 13, 2015 04:42 PM
cizsak
Jul 21, 2015 03:39 PM
BootyDo
Jul 7, 2015 06:06 AM
