turbo for k20 7th gen
Old Jul 3, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
so, I think hasport has got one that fits their project k20 7th gen? What are the specs of that turbo? what company makes it? And did hasport rebuild the internals of their k20 b4 they put on the turbo? or did they just bolt it on to the stock k20?
Thanks
Old Jul 3, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
where did you read this?
Old Jul 3, 2003
Jaykuai's Avatar
ish...
no matter.. it's true...
there was an old thread about it..
EDIT: If i remember correctly, they installed Stage 1 of Cybernation Turbo Kit.
Old Jul 4, 2003
briang's Avatar
briang is an unknown quantity at this point
Rev Hard
Rev Hard mde the kit specifically for the K20 powered Civic, and it is available through them. The car pumps out about 275, 340 or 410 hp depending on whether or not I have the boost controller hooked up and which tune I have in the AEM ECU. That is on stock internals, although I have a sleeved lower compression block that needs to go in the car. We ran boost from 8 to 18lbs during various runs.
AEM is finishing the ECU for the application for the RSX and should have it out soon, ours was a prototype. After Doug at Hondata gets back we will do a Hondata program for the stock RSX ECU, so that program will be available too.
I will update our projects page some time witin the next month when we get the engine back in the car and crank the boost the rest of the way. We have been conservative so far.
brian g
Zygrene
Mar 22, 2016 12:36 PM
HondaGuy7
Feb 22, 2016 01:00 PM
Nalmonte
Sep 28, 2015 01:10 PM
John2009
Sep 10, 2015 09:53 PM
Donahue
Sep 8, 2015 10:43 AM
